Old 04-25-2011, 04:35 PM   #21
Signmaster
Default Re: Best 195/55-R15 Tire With Good Tread Life
Originally Posted by SkippyThorson View Post
To follow this up, I wanted to confirm something. If a tire is larger, and thusly, the diameter is larger, the tire will make less rotations on the same trip compared to a smaller tire which would make a greater amount of rotations.
So, if I want my Odometer to not add more miles than I'm actually driving, I would want a larger tire, with a larger diameter, making fewer rotations, correct? I know I'm over-thinking this one.
Your thinking is correct.
Regardless of which tire you choose in the end remember not only is the odometer slightly off, but the speedometer is as well. Go to know if you go through radar or something.
You can use one of these to quickly figure out the difference.
Tire Size Calculator
Something else to keep in mind is to use the correction factor if you figure your MPG, or for oil change intervals, etc. I run slightly taller than stock tires, and I just use the correction factor in my MPG spreadsheet so I have accurate miles driven and MPG calculations.
Old 04-25-2011, 06:05 PM   #22
spud42
spud42 is on a distinguished road
The 195/60 tire that I was set on was the BF Goodrich Radial T/A, RWL. I know it's a bit of a soft tire, but as long as it's not horrible, I absolutely love the look of it. Anyone have opinions on that one?
I just may go the 195/60 route after all... On the Michelin Pilot Exalto A/S, I'd be paying $116 a tire for the 195/55, compared to $100 a tire for the 195/60.
195/60 look at the Bridgestone Potenza Pole Position
I have the BF Goodrich Radial T/A now
can't wait till they wear out the only tire I've been
highly impressed with is the
the best tires I have ever owned.
everything I wanted from a tire but treadlife and
snow traction is not outstanding just slow down
still better then most all season"s and once the roads become a sloppy mess the great wet performance really shows
Put these on my parents car as it was scary when it rained like night and day how it made the car feel
Add to spud42's Reputation
Rate the quality of this post and help spud42 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spud42 is offline   Reply With Quote
Old 04-25-2011, 09:44 PM   #23
eRic 02sc2
eRic 02sc2's Avatar
I used 195/55R15 Dunlop Direzza Sport Z1 Star Spec tires on my 2002 Saturn SC2 in the past and they were awesome.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Add to eRic 02sc2's Reputation
Rate the quality of this post and help eRic 02sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-26-2011, 12:56 PM   #24
SkippyThorson
SkippyThorson is on a distinguished road
SkippyThorson's Avatar
2002 SL1
Well, I called up a local dealer today, and after all the work, he said he's having trouble finding anyone with Michelin Pilot Exalto A/S tires. A few places in the area have 1 or 2, but no one has 4. He says that he thinks they may be discontinued soon.
... After all that? ... Really?
Add to SkippyThorson's Reputation
Rate the quality of this post and help SkippyThorson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SkippyThorson is offline   Reply With Quote
Old 04-26-2011, 01:19 PM   #25
SaturnFix
SaturnFix will become famous soon enoughSaturnFix will become famous soon enough
SaturnFix's Avatar
1996 SC2
Discontinued tires are the best deal! I'm sure you can find them on eBay.
What is your Saturn's oil economy?
Canada Saturn owners REVOLT!!! Improper factory spark plugs! c.c
If you are in the Southern Wisconsin area, check out: facebook.com/SaturnFix
Add to SaturnFix's Reputation
Rate the quality of this post and help SaturnFix reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnFix is offline   Reply With Quote
Old 04-26-2011, 04:53 PM   #26
SkippyThorson
2002 SL1
That exact thought made me happy right after I considered it.
I gave Michelin a call, and the guy basically said that they don't make every tire all the time, and that the AS line is being used to make another tire. Coming up in May, the AS will be made again, and there is no foreseeable discontinuation of that tire.
The guy at the local Ford Dealer (not a gouging chain, a 1 family shop) said that places in the area have 1 or 2, but no one has 4, so I could still certainly get them, but they wouldn't arrive until well after the Buy 3 Get 1 promotion ends.
He also said that their place, as well as others, have them on backorder, so they'll be in soon, but not soon enough. It looks like I'll be waiting until another promotion comes up.
(In other news, a local Firestone guy quoted me almost $600 for the Wide Oval Indy 500s, from start to finish. Then he quoted me some 'house tire' at around $400... I think I'll stick to the Michelins. I told him about the Indy 500s on TireRack.com, and he basically told me that he couldn't match that price. It's only $84...)
Old 04-26-2011, 06:11 PM   #27
spud42
[QUOTE=SkippyThorson;1738325
(In other news, a local Firestone guy quoted me almost $600 for the Wide Oval Indy 500s, from start to finish. Then he quoted me some 'house tire' at around $400... I think I'll stick to the Michelins. I told him about the Indy 500s on TireRack.com, and he basically told me that he couldn't match that price. It's only $84...)[/QUOTE]
I've been thinking about the
Continental ProContact with EcoPlus+
Treadlife Warranty: 6 yrs / 80,000 Miles
Walmart online shipped to store Online
$79.00 Tire Mount (Tires purchased from Wal-Mart) Free
Old 04-27-2011, 12:49 PM   #28
SkippyThorson
2002 SL1
Thought about them, but having worked at Walmart, knowing what I know about their tires, I wouldn't ever buy them myself. Some tires are good and happen to be cheap. Walmart tires are made cheap to be cheap. For example, they have a Goodyear tire that's not actually made in a Goodyear plant - just branded by them.
My hunt continues...
Old 04-27-2011, 05:10 PM   #29
spud42
Huh
These are not sold at Any Walmart or made for Walmart tires
Have to buy them online at Walmart and then shipped to your store these are the
low rolling resistance tire see
http://www.tirerack.com/tires/tests/...y.jsp?ttid=133
the Bridgestone Potenza RE960AS Pole Position are
(Ultra High Performance All-Season)
The Michelin Pilot Exalto A/S tires.
ARE entry-level Performance All-Season
Treadlife Warranty: 6 Years / 45,000 Miles
Half mileage for rear if different size than front
Set of 4: $400.00
The MichelinPilot Sport A/S Plus Don't come in our size
The Bridgestone look good
Quit eand ride nice A great wet tire but
Treadlife Warranty 5 Years / 40,000 miles
Set of 4: $328.00
Old 04-27-2011, 08:24 PM   #30
SkippyThorson
2002 SL1
Huh
Set of 4: $400.00
Set of 4: $328.00
Ah, ok. You scared me, I thought these were the Wallyworld-Only tires. I didn't give them a look at first. The Bridgestones actually do look like decent tires. I'm liking the price and quietness for sure. Since the tread life is 40k, and I'd only use them in the Summer, I'd like to think they'd last me twice as long as that. The car only has 65k on it as-is, so even with half that amount as the rated tread life, they'd last me quite a while. Thanks for the suggestion!
On TireRack, they got an 8.1 out of 10. The issue is they come in 195/60s and not 195/55s. I could deal with that though, I suppose. They look like great tires, just not my preferred size. They're certainly second on my list now if I decide to bump up to the 60s instead of the 55s. The Goodyear ComforTread is definitely top for me in the 60s.
Stock 18" Pirelli Tire Life spencerb Astra General 5 04-28-2010 04:06 PM
Tire Shelf Life? DonP S-Series Tech 6 01-13-2009 03:56 PM
Aura XR tire tread wear e-man Aura General 4 12-15-2006 04:08 PM
Factory Brake and Tire Life? Jiveslug Ion Mods 10 03-18-2006 03:38 AM
tire life metgol S-Series General 3 04-06-2004 02:30 PM
