Old 04-19-2011, 07:45 AM   #1
kjtyo4
kjtyo4 is on a distinguished road
2000 SL
Default Turbo
I was wondering on putting a turbo on my sohc engine after I rebuild it. I do know it can be done because my dad had a spectrum turbo that had a a 1.5 liter in it with a turbo factory installed so I know it can be done and run good with the proper tunning with a 1.9 liter.
what kind of turbo should I put in it?
thanks
kenny.
Add to kjtyo4's Reputation
Rate the quality of this post and help kjtyo4 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kjtyo4 is offline   Reply With Quote
Old 04-19-2011, 07:58 AM   #2
Default Re: Turbo
Swap a DOHC in for much less hassle, more reliability, and the same amount of power as a turbo DOHC.
SOHC + 5-8psi = ~30hp increase to ~130-135hp. $3k-$4k
DOHC + bolt-on's = 5-10hp increase to 130-135hp. ~$500
DOHC + 5-8psi = ~50-70hp increase to 170-180hp. $3k-$10k+ (depending on how much power you want)
Depends on your tune with MegaSquirt or some other stand alone computer as well, no way to do anything with the stock one. People are working sporadically on the 1st gen PCM's but I don't think they've gotten anywhere useful.
Old 04-19-2011, 09:35 AM   #3
Default Re: Turbo
meant "turbo SOHC" in that first line...evil edit window
Old 04-19-2011, 03:46 PM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
Default Re: Turbo
As mentioned, of course you can turbo a SOHC, but it's not worth it at all. First step of any decent turbo S-Series build is a DOHC swap, and if that sounds like more than you can handle, then a turbo setup is more than you can handle as well.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Rate the quality of this post and help PurdueGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-19-2011, 05:40 PM   #5
madpogue
1996 SW2
Default Re: Turbo
Originally Posted by PurdueGuy View Post
First step of any decent turbo S-Series build is a DOHC swap....
And if the SOHC car is running well, the best way to do this is as a car swap. IOW, sell the SOHC car and buy a DOHC car. With today's gas prices (and the way they're going), good-running SOHC cars are desirable, and the difference in price between an SOHC car of a given age, condition, mileage, etc. and its DOHC counterpart is almost nil. Another option is to keep the SOHC car as a daily driver / parts chaser, since the turbo car can be expected to spend most of its time (esp. initially) on stands.
Add to madpogue's Reputation
Old 04-19-2011, 07:44 PM   #6
S3aturnR
S3aturnR is a jewel in the roughS3aturnR is a jewel in the roughS3aturnR is a jewel in the rough
S3aturnR's Avatar
1996 SL2
1999 SL1
Default Re: Turbo
thanks
kenny.
it's funny how often this question comes up. let me answer it with another... how much money do you have to spend on this install???
s3aturnr
"reno is a lot like maybury, except everyone's on crystal meth and prostitution's legal" - junior
Add to S3aturnR's Reputation
Rate the quality of this post and help S3aturnR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
S3aturnR is offline   Reply With Quote
Old 04-19-2011, 09:21 PM   #7
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
2006 VUE Red Line
Default Re: Turbo
uhhh, he gonna need about tree-fiddy
'02 SL1 [w/ a snail-shaped muffler]
'06 Vue RL
Saturn Night is Special ED.
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is offline   Reply With Quote
Old 04-20-2011, 12:10 AM   #8
kjtyo4
2000 SL
Default Re: Turbo
I was just wondering how hard it would be.I was told that the dohc had alot of problems with head gaskets. thats why i was going to stick with the sohc motor. would a dohc motor bolt up to the 5 speed i have know?
thanks
kenny
Old 04-20-2011, 06:21 AM   #9
Default Re: Turbo
It's not the DOHC with the problems....it's the SOHC. Either it cracks the head or you have to do the intake manifold gasket properly as the robot failed on most of them '00+. Might have head gasket problems with the DOHC at 300-500hp....but the SOHC will never see more then 200hp from what I've seen/read.
It'll bolt up fine but you'll lose cruise control. Saturn saved $0.50/car on the '96+'s by changing a physical switch on the clutch pedal to programming in the PCM.
Old 04-20-2011, 07:29 AM   #10
kjtyo4
2000 SL
Default Re: Turbo
I don't have cruse control know not with my 5 speed.
I am thinking of rebuilding a dohc and puting on in.
kenny
Old 04-20-2011, 08:06 AM   #11
eRic 02sc2
eRic 02sc2's Avatar
Happy Re: Turbo
thanks
kenny
where are you getting your information? the DOHC doesn't have any head gasket problems that I have heard of in my years 1992-2010 of Saturn ownership. your best bet is sell the SOHC and start with a DOHC then mod it. I mean sell the entire car, not swap the engine. swapping the engine at this point would be a waste of time and money. why bother modifying a 85-100 hp car when you can get a 124 hp car for cheap and it will come with better seats and suspension.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Add to eRic 02sc2's Reputation
Rate the quality of this post and help eRic 02sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-20-2011, 11:03 PM   #12
Recycled Saturn
Recycled Saturn has a spectacular aura aboutRecycled Saturn has a spectacular aura aboutRecycled Saturn has a spectacular aura about
Recycled Saturn's Avatar
Default Re: Turbo
If you are going to turbo ANY saturn s-series, you better have a LOT of money, time, and headache pills
It can be done but for anyone thats not rich, doesnt have very much free time, or doesnt have a huge passion to modify a saturn, its better off to find a different car
1998 SL2-AMR Strut Bar, AEM CAI, and 119,XXX
Add to Recycled Saturn's Reputation
Rate the quality of this post and help Recycled Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Recycled Saturn is offline   Reply With Quote
Old 06-24-2011, 04:42 PM   #13
Fear of Oneself
Fear of Oneself is on a distinguished road
Fear of Oneself's Avatar
1998 SW2
Default Re: Turbo
What do you mean by Bolt-on's
98 SW2 5-speed stick dohc, no more
Add to Fear of Oneself's Reputation
Rate the quality of this post and help Fear of Oneself reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Fear of Oneself is offline   Reply With Quote
Old 06-24-2011, 04:51 PM   #14
AlexofNazareth
2002 SL1
2006 VUE Red Line
Default Re: Turbo
Bolt-on modifications:
Intake
Throttle Body
Header
Cat back
Popcorn Machine
Stickarz
'06 Vue RL
Old 06-25-2011, 01:37 PM   #15
shadowspiyre99
shadowspiyre99 is on a distinguished road
shadowspiyre99's Avatar
1997 SC2
Default Re: Turbo
do the dohc swap and s/c it
Add to shadowspiyre99's Reputation
Rate the quality of this post and help shadowspiyre99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shadowspiyre99 is offline   Reply With Quote
Old 06-25-2011, 02:55 PM   #16
aaron95sl2
aaron95sl2 is on a distinguished road
aaron95sl2's Avatar
1995 SL2
Default Re: Turbo
As been said a million times on these forums, keep the Saturn as a daily driver (or sell it if you need the money), and buy a turbocharged car. That's what I'm going to do. I'm keeping my good ol' bone-stock Saturn and buying a MazdaSpeed 3 when I scrap up enough dough.
If you THINK you have enough money to turbo a Saturn, either you're wrong and you don't, or you have enough money to buy a much nicer turbocharged car (WRX, MazdaSpeed, Eclipse/Talon, etc.). So if you don't have $5,000 laying around, just forget it altogether. If you do, buy a car that came from the factory with a turbo.
1995 SL2 | Fully loaded | 165k on odometer |30k on new engine w/ KB-S pistons - not a single drop of oil lost so far!
Add to aaron95sl2's Reputation
Rate the quality of this post and help aaron95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aaron95sl2 is offline   Reply With Quote
Old 06-25-2011, 04:44 PM   #17
shadowspiyre99
1997 SC2
Default Re: Turbo
and then be like every one else lol individuality is why my saturn is s/c, its easy to just go out and by a factory turbo car but then theres no satisfaction in it just my 0.02
Old 06-25-2011, 04:51 PM   #18
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
Default Re: Turbo
I'd like to know where I can find a good WRX for $5k.
Old 06-25-2011, 07:44 PM   #19
aaron95sl2
aaron95sl2's Avatar
1995 SL2
Default Re: Turbo
It was a ballpark figure, and obviously referring to USED vehicles (unless you can find me a brand new SL2). Really, I know nothing of WRXs, but thanks for missing my point.
Old 06-25-2011, 07:46 PM   #20
aaron95sl2
aaron95sl2's Avatar
1995 SL2
Default Re: Turbo
The type of "individuality" you speak of is expensive. And people don't buy Saturns because they're rich.
WHat injectors can be used to turbo a 2.2L none turbo AlexLugones Ion Mods 9 09-11-2008 09:14 PM
would it be more worth it to buy a different car to turbo or should i turbo my 98 sc2 saturnguy125 S-Series Mods 24 05-23-2008 10:31 PM
FS: Turbo Exhaust Manifold with Saab Turbo amazinghl Classifieds 1 07-14-2004 07:54 PM
For sale SOHC turbo manifold, downpipe, & T25 turbo turbo98sc1 Classifieds 0 08-27-2003 01:05 PM
*!TURBO!*!TURBO!*!TURBO!*<-a must read!! Flash Mods and Performance 7 08-15-2001 03:53 PM
