#1 |
![]() Join Date: Nov 2010
I have a 2009 Saturn Aura XR that I have had for over a year and never had any problems with it. The front passenger door opened just fine and about 20 minutes later my friend tried to get out of the car and the door wouldn't open. The locks work just fine. I tried opening it from the inside and the outside and still it wont open. Any ideas??
#2 |
Has anyone had this happen to them? It seems to be hard to find information about on the web.
#3 |
![]() ![]() ![]() ![]() Join Date: Nov 2007
2008 Outlook XR
2007 AURA XR
ive never heard of this happening to anyone else.
#4 |
I had this happen one time on a Passat rear door. Part of the reason was that the child lock was enable so it could not be opened from the (which should not be an issue on your front door). The ourside handle linkage had failed. I ended up having to figure out a way to get the door panel off from inside with door shut. It has been about 10 years ago and kinda fuzzy but I had to ruin the door panel in doing so.
2008 Aura XR |
#5 |
![]() Join Date: Mar 2008
2008 AURA XE
I had this problem before I had the shift cable problem. It all ties in together (like the doors locking when you shift into drive, for instance). At least one time, I heard the door locks click while on the highway. I was going to take it in but I didn't have the issue anymore until my shift cable needed replacing. There is a recall for the shift cable for your MY. I'm almost willing to bet that's what your problem is.
#6 |
![]() Join Date: Oct 2009
2009 AURA XR
Funny story. My dad had to back my car down the driveway during the snowstorm last year so we could shovel the driveway. The doors unlocked when he turned the car off, but the drivers door would not open at all. He had to climb over to the passenger side and get out that door instead.
It hasn't ever happened to me at all, but I have heard it happen. I haven't ever had a problem with it since I got it...except for cold weather startups. |
#7 | |
2008 AURA XE
![]() Quote:
2014 Chevy Impala 2LT, 3.6L, Blue 2014 Chevy Malibu LTZ, Black (wife's ride) Then: 2008 Saturn Aura XE, 3.5L V6 (Traded in for Impala) 2011 Chevy Cruze 1LT, Gold Mist Metallic (wife's old ride) |
#8 |
![]() Join Date: Feb 2011
I just had this happen to my 2008 Aura XR. My drivers door first would not latch. After holding the door and driving to the nearest GM dealership, the door then shut. Now the door will not open, and I have to crawl over the shifter, to get out the passenger door.
#9 |
![]() ![]() ![]() Join Date: Mar 2010
2009 AURA XE
My money is on the actuator/lock assy since that is the most mechanical & trouble-prone part of the door lock system. A proper Tech 2 diagnosis can confirm it.
#10 |
![]() Join Date: Nov 2009
I had my driver side door not open, so I had to crawl out the passenger door, then after many locks and unlocks it worked again, until I drove down the street to stop by work for a minute, then I got out tried to close the door and it wouldn't latch. Took it across the street to the Chevy dealer, they tried to lubricate it, when the service tech said there were done I went to open and shut it, it bounced off the frame. They determined I would need a new door latch, $400 later, it works =/
#11 |
Hopefully that $400 was covered under warrenty. Especially since its a $70 part and taks a half hour to replace. And hopefully it was replaced with the updated unit.
Mike -1991 Turbo SL2. 11.809 @ 116.488 mph www.differentracing.com -2001 Limited Edition SC2 (#78) -2001 Chevrolet Suburban -2007 Saturn Aura XR -2011 Rally Yellow Chevrolet Camaro 2SS RS |
#12 |
2009 AURA XE
Agreed. $400 is an outrage. Just replace two door lock actuators on my Ford with aftermarket versions for under $20/each including shipping. I haven't seen aftermarket versions for the Aura/Malibu/G6 yet; but they may exist.
#13 | |
![]() Quote:
Heck, the third generation Saturn SC2 uses a similar design latch/actuator design. The car stopped production in 2002 and GM discontinued the part sometime in 2006. And there no aftermarket alternative. Also the latch has electrically more in it than just the lock/unlock motor. It senses if the door handle has been pulled or if the door latch is ajar. I was curious when I replaced mine why there were so many wires on the electrical connector. An acuator only has two. These have something like six.
Bookmarks |
2002 Saturn Vue Front Passenger door wont open | walboy | Vue Tech | 0 | 04-14-2010 07:01 PM |
Passenger door wont unlock / open | spartacus46 | Vue Tech | 5 | 10-17-2008 12:28 AM |
Passenger Sliding door won't unlock or open | mommybayer | Relay General | 2 | 04-15-2008 01:57 AM |
Any way to get passenger door open on an SC2? | TIMSPEED | S-Series Tech | 5 | 10-08-2007 05:04 PM |
Strange-Rear Passenger door will not open from the inside | JIM03VUE | Vue General | 2 | 06-09-2003 05:31 PM |
