Old 09-11-2010, 06:25 PM   #1
99SL2_Modder
99SL2_Modder is on a distinguished road
2009 AURA XR
Default Flasher relay
Where is it? Can't find the damn thing.
99SL2_Modder is offline   Reply With Quote
Old 09-12-2010, 01:16 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: Flasher relay
It might not have one.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 09-12-2010, 03:12 PM   #3
99SL2_Modder
2009 AURA XR
It has to. Whether it's a relay or a solid state module, I just wanna know where the ***** is.
Old 09-12-2010, 03:46 PM   #4
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Not really. The flashing and the flash rate can be controlled through the BCM. The click, click click sound comes through the left front speaker instead of a flasher module. So its quite possible that the car doesnt have a traditional flasher module.
Edit: Just looked up the parkinglight/turn signal schematics in the service manual. No flasher module. Signal goes from the multifunction switch to the BCM and out to the lights.
Mike
-1991 Turbo SL2.
Old 09-12-2010, 03:53 PM   #5
99SL2_Modder
2009 AURA XR
balls. So would LED's not really be an option without load resistors? I hate using them. =(
Old 09-12-2010, 03:57 PM   #6
Low Saturn
Low Saturn's Avatar
2007 AURA XR
I think I read that people on the Malibu forums used LED bulbs with no resistors and they worked. I have some spare wedge LED bulbs. Maybe I'll give it a try. I already have LED bulbs for the front fender markers with no strange effects.
Mike
-1991 Turbo SL2.
Old 09-12-2010, 04:28 PM   #7
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Well, forget that assumption. Popped in a couple of LED bulbs and it flashed like a Jack Russell terrier on crack.
Mike
-1991 Turbo SL2.
Old 09-12-2010, 07:35 PM   #8
99SL2_Modder
2009 AURA XR
Need someone with an FSM to get component locations and see if it's BCM, solid state, or hidden somewhere. I checked all 3 boxes, and didn't find one, but it could be one of those silent tie-in's that GM loves to use.
If it's BCM, maybe a TEC2 or HPTuners could get in and change the load settings so it doesn't think a bulb is out?
Old 09-12-2010, 07:51 PM   #9
Low Saturn
Low Saturn's Avatar
2007 AURA XR
I have the FSM's. What component do you need the location for? The BCM? Its on the passenger side kick panel. The interior fuse box and BCM are the same part. If the BCM controls flasher timing, then its software driven. Doesnt mean it can be altered though.
Mike
-1991 Turbo SL2.
Old 09-12-2010, 11:45 PM   #10
99SL2_Modder
2009 AURA XR
Is there anything in the FSM about the flasher functions and/or service?
Old 09-13-2010, 12:06 AM   #11
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Just how to change the multifunction switch.
Mike
-1991 Turbo SL2.
Old 09-13-2010, 02:37 AM   #12
99SL2_Modder
2009 AURA XR
Lllaaaammmee! No component location index?
Old 09-13-2010, 10:50 AM   #13
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Electrical components? These cars are full of electronic components. Do you want to know whats on the front, back and sides of the three fuse boxes or something?
Mike
-1991 Turbo SL2.
Old 09-13-2010, 02:50 PM   #14
99SL2_Modder
2009 AURA XR
Usually a component locator lists every relay and module in the car.
I know the Camry's have a solid state inside the dash, not near any fuses.
2002 Saturn L100 Flasher Relay Location Fever L-Series General 2 10-13-2011 11:25 AM
Where's the flasher relay clicker thingy? cfg83 S-Series Tech 5 04-27-2010 10:37 AM
LED Flasher? oceanjoe89 S-Series Mods 10 09-09-2008 12:06 PM
92 Sl1 four way flasher problem johnt671 S-Series General 1 07-09-2006 09:06 AM
flasher for DRL? ptolbert Miscellaneous Tech 8 06-03-2002 01:22 AM
