Old 08-13-2010, 02:47 PM   #1
d16tr
d16tr is on a distinguished road
1995 SW2
Default Car won't crank, need help kinda urgent ...
Hi All,
I changed CPS 10 days ago, after driving for a week with no problems it died once shortly after stopping by the mall for 15 mins. So I thought next step is to change the ignition module, and I did 2 days ago.
An hour ago I went to Food Lion (no problems cranking etc.) and after 10 minutes when I came back it won't crank at all. I hear the relay clicking but otherwise absolutely no movement. Can it be a fuse? Where should I start checking?
Audere est facere.
d16tr is offline   Reply With Quote
Old 08-13-2010, 02:52 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: Car won't crank, need help kinda urgent ...
Whack the starter with a 2x4 or metal pipe or something? If this works, your starter is toast.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 08-13-2010, 02:57 PM   #3
d16tr
1995 SW2
Thanks adventureoflink,
I will try that. Also I forgot to tell, I checked to see of there were any error codes, and were none.
Any other ideas?
Audere est facere.
Old 08-13-2010, 03:05 PM   #4
quantumech
quantumech is on a distinguished road
2000 SL1
Weak battery, loose or corroded ground someplace.
Sasha: 2000 SL1, Manual, cracked head Sept. 2014. Donated Dec. 2014
I learn from my experiences. If I screw up, I'm sorry.
quantumech is offline   Reply With Quote
Old 08-13-2010, 03:08 PM   #5
adventureoflink
+1, also check for possible loose/corroded battery connection.
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 08-13-2010, 03:19 PM   #6
d16tr
1995 SW2
Thanks quantumech and adventureoflink, battery has sideposts and I just changed the negative post so I doubt it but will do.
Is there a fuse that protects to the starter?
Audere est facere.
Old 08-13-2010, 03:38 PM   #7
madpogue
1996 SW2
No, only one for the low-current circuit to the solenoid. For the main starter motor, the wire goes directly from the battery + cable to the starter.
If the car in question is the one in your profile, there's no relay. If you're hearing a click, that's the starter solenoid, which means the low-current circuit (fuses, ignition switch, clutch/neutral switch, yellow/purple wiring) is all good. Either the starter is bad, or (can't rule this out) the engine is seized.
Old 08-13-2010, 04:31 PM   #8
d16tr
1995 SW2
Thanks madpogue,
Yes, that's the car on the profile. I don't see why the engine would be seized, it was running perfectly until today, never had any problems in the last 3 years, this is actually the second engine which has less than 120K on it. I must be the starter. I will let you know when I fix the problem.
Thanks madpogue and everyone else!
Audere est facere.
Old 08-13-2010, 05:45 PM   #9
d16tr
1995 SW2
Anyways,
My wife came from work, we went to the Food Lion parking lots and the car cranked the first time as if nothing ever happened, so I strongly believe it is the starter and I will change it.
Audere est facere.
Old 08-13-2010, 07:24 PM   #10
madpogue
1996 SW2
^^^^ Seems like the most common cause of death for our starters is "heat stroke". It probably cooled off enough to work again -- for the time being....
Old 08-14-2010, 12:16 AM   #11
adventureoflink
+1. I remember having to do this on my diesel van (though I never ever had to whack its starter).
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 08-14-2010, 07:49 AM   #12
spencerforhire
spencerforhire will become famous soon enough
spencerforhire's Avatar
2001 SC1
2000 SW2
I like the term "heat stroke" to describe a starter issue that magically goes away after sitting for an hour or 2; it's a very common problem with Saturns. I always referred to it as "heat SOAK" but now from now on I'm going to use this new term.
01 SW2-#1 son's
01 SC2-#2 son's
00 SW2-wife's
00 SL2-daughter's
99 SW2-mine
00 SL1-spare
98 SC1-parts
+ 25 scrapped
Visit www.spencerforhire.ca to see what I do other than fix Saturns
spencerforhire is offline   Reply With Quote
Old 08-23-2010, 10:53 PM   #13
d16tr
1995 SW2
Hi All,
Just wanted to share, I found a brand new starter from http://www.rareelectrical.com/
for about $57 which is a pretty good deal in my opinion.
P.S. Free shipping ...
Audere est facere.
2000 SL2 Cold Starting Issues [Crank crank crank...] RarestRX S-Series Tech 8 02-12-2012 12:58 PM
Urgent problem SC Saturn Owner Ion General 3 07-05-2008 09:11 PM
Need Urgent Help!!!!!! Suspension, Help!!!!!!! 97sleeper S-Series Tech 5 12-28-2006 09:04 PM
URGENT: Key stuck paulygon S-Series General 16 01-17-2006 12:30 PM
Urgent Girafro S-Series Tech 8 12-06-2004 01:43 PM
