#1 |
![]() Join Date: Feb 2007
1995 SW2
Hi All,
I changed CPS 10 days ago, after driving for a week with no problems it died once shortly after stopping by the mall for 15 mins. So I thought next step is to change the ignition module, and I did 2 days ago. An hour ago I went to Food Lion (no problems cranking etc.) and after 10 minutes when I came back it won't crank at all. I hear the relay clicking but otherwise absolutely no movement. Can it be a fuse? Where should I start checking?
Audere est facere. |
#2 |
![]() ![]() ![]() Join Date: Apr 2009
Whack the starter with a 2x4 or metal pipe or something? If this works, your starter is toast.
97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive, 1/2 exhaust 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, no heat |
#3 |
1995 SW2
Thanks adventureoflink,
I will try that. Also I forgot to tell, I checked to see of there were any error codes, and were none. Any other ideas?
#4 |
![]() Join Date: May 2009
2000 SL1
Weak battery, loose or corroded ground someplace.
Sasha: 2000 SL1, Manual, cracked head Sept. 2014. Donated Dec. 2014 I learn from my experiences. If I screw up, I'm sorry. |
#5 |
+1, also check for possible loose/corroded battery connection.
#6 |
1995 SW2
Thanks quantumech and adventureoflink, battery has sideposts and I just changed the negative post so I doubt it but will do.
Is there a fuse that protects to the starter?
#7 |
No, only one for the low-current circuit to the solenoid. For the main starter motor, the wire goes directly from the battery + cable to the starter.
If the car in question is the one in your profile, there's no relay. If you're hearing a click, that's the starter solenoid, which means the low-current circuit (fuses, ignition switch, clutch/neutral switch, yellow/purple wiring) is all good. Either the starter is bad, or (can't rule this out) the engine is seized. |
#8 | |
1995 SW2
Thanks madpogue,
Yes, that's the car on the profile. I don't see why the engine would be seized, it was running perfectly until today, never had any problems in the last 3 years, this is actually the second engine which has less than 120K on it. I must be the starter. I will let you know when I fix the problem. Thanks madpogue and everyone else! Quote:
#9 |
1995 SW2
Anyways,
My wife came from work, we went to the Food Lion parking lots and the car cranked the first time as if nothing ever happened, so I strongly believe it is the starter and I will change it.
#10 |
^^^^ Seems like the most common cause of death for our starters is "heat stroke". It probably cooled off enough to work again -- for the time being....
#11 |
+1. I remember having to do this on my diesel van (though I never ever had to whack its starter).
#12 |
![]() Join Date: Nov 2005
2001 SC1
2000 SW2
I like the term "heat stroke" to describe a starter issue that magically goes away after sitting for an hour or 2; it's a very common problem with Saturns. I always referred to it as "heat SOAK" but now from now on I'm going to use this new term.
01 SW2-#1 son's 01 SC2-#2 son's 00 SW2-wife's 00 SL2-daughter's 99 SW2-mine 00 SL1-spare 98 SC1-parts + 25 scrapped Visit www.spencerforhire.ca to see what I do other than fix Saturns |
#13 |
1995 SW2
Hi All,
Just wanted to share, I found a brand new starter from http://www.rareelectrical.com/ for about $57 which is a pretty good deal in my opinion. P.S. Free shipping ...
Audere est facere. Last edited by d16tr; 08-23-2010 at 10:54 PM. Reason: additional info |
Bookmarks |
2000 SL2 Cold Starting Issues [Crank crank crank...] | RarestRX | S-Series Tech | 8 | 02-12-2012 12:58 PM |
Urgent problem | SC Saturn Owner | Ion General | 3 | 07-05-2008 09:11 PM |
Need Urgent Help!!!!!! Suspension, Help!!!!!!! | 97sleeper | S-Series Tech | 5 | 12-28-2006 09:04 PM |
URGENT: Key stuck | paulygon | S-Series General | 16 | 01-17-2006 12:30 PM |
Urgent | Girafro | S-Series Tech | 8 | 12-06-2004 01:43 PM |
