Old 11-11-2019, 08:12 PM   #1
Cmarie3387
Cmarie3387 is on a distinguished road
Wrench Buzzing noise in throttle body
Okay.. I have posted several threads on my 2002 Saturn l300 v6 3.0
The other day my boyfriend cleaned out the throttle body it was filled with oil and dirt. He put the throttle body back on hoping thatís the reason why it is cranking but not starting...battery was almost dead from trying to start the car. The car fired up but only last a few seconds before shutting off. Tried again tonight with almost turning over but not completely. We are hearing a ringing noise coming from the throttle body, we think it may be the sensor? But are not for sure. We did not know that the car may start but will not drive if we unplug the throttle body. When he put the car in the run position I did not see the throttle body flap open at all and when he unplugged the throttle the ringing sound went off. Does this mean I need a new sensor? I also called autozone but they said I would have to replace the throttle body itself it doesnít come with just the sensor itís the whole assembly is that true? Any help is so much appreciated!
Add to Cmarie3387's Reputation
Rate the quality of this post and help Cmarie3387 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cmarie3387 is offline   Reply With Quote
Old 11-11-2019, 09:22 PM   #2
Default Re: Buzzing noise in throttle body
When the gas pedal is pressed, does the throttle plate respond?
Old 11-11-2019, 09:34 PM   #3
Cmarie3387
No it does not...the throttle plate does not open what so ever...this is when itís cranking but not starting
Old 11-11-2019, 09:55 PM   #4
02 LW300
02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Does this car still have the tps high code?
Add to 02 LW300's Reputation
Old 11-11-2019, 10:23 PM   #5
Cmarie3387
Iím not sure what the high code is? And the battery is dead and itís hard to keep the battery charged when trying to turn on the car to start it. The things that we see are car cranks but no start, ringing sound from the throttle bottle, when gas pedal pushed the throttle pedal does not open and we do not hear the fuel pump humming.
Old 11-11-2019, 11:29 PM   #6
02 LW300
02 LW300's Avatar
Sorry, I mixed up a couple L300s that donít run.
Cleaned Throttle Body-New Engine Noise tcndeb Vue General 6 08-26-2013 08:23 PM
03 L300 no start unless the throttle motor/ throttle body unpluged Woody117 L-Series Tech 2 12-25-2012 07:33 PM
Crazy Throttle Body Noise? JakeJD L-Series Tech 7 11-26-2011 05:22 PM
buzzing noise aperich2 S-Series Tech 3 07-10-2010 10:56 PM
Buzzing D2 after valve body replacement 959697SATURN S-Series Tech 4 05-03-2007 03:06 PM
