Old 10-19-2019, 01:49 PM   #1
SIRPAULGERMAN
SIRPAULGERMAN is on a distinguished road
SIRPAULGERMAN's Avatar
Default Radiator recommendation
The radiator started to have some leaks, this is my second radiator, I think the brand is Silla it only lasted around 50 000 miles.
Rock auto has the original for $129 is there another cheaper option for less money ?
what about the Denso ?
SIRPAULGERMAN is offline   Reply With Quote
Old 10-19-2019, 03:17 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Radiator recommendation
I've used both silla and denso and either will do the job for a long time.
Old 10-19-2019, 03:44 PM   #3
SIRPAULGERMAN
how long did the Denso last it ? where is the denso made ?
Old 10-19-2019, 11:00 PM   #4
toggenburg
toggenburg's Avatar
DENSO Corporation, headquartered in Kariya, Aichi prefecture, Japan.
Some of there better lines are OEM on Lexus models.
Old 10-20-2019, 12:50 PM   #5
If your replacement radiator failed in 50k miles, was it due to a faulty radiator, road rash damaging it, xmission fitting damage or worn/damaged/missing radiator rubber mounts?
I dont recall members here using Silla replacement radiators finding fault with it.
Old 10-20-2019, 06:58 PM   #6
hholbein
1997 SW2
50K failure on the Silla? Not so hot. At least on other parts, Denso has pretty decent quality control, and the $56 price seems pretty good -- essentially the same as the Spectra unit that doesn't seem to last so long according to other posts.
Regarding AC Delco, "OEM quality" ain't what it used to be -- sometimes it's truly the quality part that was originally installed and other times it's some low-cost value-engineered junk selected by some faceless dweeb in Purchasing. I'm curious what others have found with the Denso part -- or whether the Delco part is truly OEM quality.
Old 10-20-2019, 06:44 PM   #7
454cid
Denso is to Toyota what Delphi was/is to GM. Denso was spun off in the 50's. Last time I checked they were the #2 Tier 1 supplier behind Bosch. They have facilities all over the world. I believe their aftermarket radiators come from China, as that seemed to be the answer on other forums when I researched it a few years ago. If any company would demand quality from China, it would be them... they probably run/own the plant, not just buy radiators made there.
2000 SL2 Automatic (back on the road) 19X,XXX miles.
1999 Chevy K3500
ATF recommendation MikeNW S-Series General 22 01-30-2019 01:01 PM
Oil pan recommendation Liger95 S-Series General 4 08-18-2015 02:26 PM
SC2 tire recommendation? ninetynineSC2 S-Series Tech 30 09-07-2012 06:31 PM
NJ Mechanic Recommendation armpit94sl2 Miscellaneous Tech 4 06-10-2004 09:35 AM
A recommendation wolfman Miscellaneous Tech 5 03-03-2003 12:24 PM
