Old 06-21-2017, 07:20 PM   #1
Bubster
Bubster is on a distinguished road
Default Electrical issues
So Saturday, I noticed that my car wasn't starting until I released the key then it would crank right up. It continued to do this through Sunday. Monday morning I went out and the car would not start at all. I tried to jump it to no avail. I hear the solenoid click when I turn the key to start, but that's it. I also noticed that the headlights aren't coming on when you turn the key on or when you unlock the car with the fob. They come on with the manual switch just fine. A Mechanic buddy of mine came by with his portable jumping testing device and that wouldn't start it either, it did however say that the battery was good. At first he thought it might be the ignition switch, but now that the headlights aren't coming on with the key or the fob, He is second guessing that. Any help would be greatly appreciated. TIA
Bubster is offline   Reply With Quote
Old 06-21-2017, 08:48 PM   #2
Default Re: Electrical issues
Some background history is needed; year, mileage, maintenance done, parts replaced. Short cutting to one item - if the starter was never replaced with well over 100k miles on it, it may be worn out. Less mileage if this car is used frequently for short trips.
As usual, main power is considered the first place to start; battery, battery cables and their condition, main ground connections to chassis and engine block.
Old 06-22-2017, 07:19 PM   #3
gm7
gm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the rough
gm7's Avatar
2009 VUE Red Line
As fdryer suggested....start at the battery, remove the cables, clean and reattach. Borrow a multimeter and measure the battery output. How old is the battery?
Background on the vehicle helps. Mileage....northern car?...battery age...car keep inside or outside the garage?
gm7 is offline   Reply With Quote
Old 06-28-2017, 10:09 PM   #4
dmayorgap
dmayorgap has a spectacular aura aboutdmayorgap has a spectacular aura aboutdmayorgap has a spectacular aura about
dmayorgap's Avatar
2008 VUE 3.6L
Hi, i had the same issue a few weeks ago, one day the vue wouldnt start, just the solenoid click and norhing else, battery was fine tried to jump start with another car battery and nothing, dealer said there was a problem with the negative cable that goes to battery so they solder the cable in the place where it joins with the terminal, so far so good.
David M.
Chevrolet Captiva Sport AWD V6 3.6
dmayorgap is offline   Reply With Quote
Old 06-30-2017, 07:49 AM   #5
gm7
gm7's Avatar
2009 VUE Red Line
Soldering any cable is highly suspect. If a terminal is loose, typically a cable is re-terminated...or more commonly, the replacement cable which comes with terminals...one side for battery, the other to solenoid terminal...is replaced.
But I do agree, that this electrical issue maybe cable related. We haven't heard back from the OP with an update.
Old 07-10-2017, 02:24 PM   #6
dmayorgap
dmayorgap's Avatar
2008 VUE 3.6L
Hi, my VUE started again with the issue, when starting i hear only the solenoid click and no crank at all, the i try again and crank just fine, i've reattached the ground points that goes to the negative battery cable and cleaned the contacts, still happening sometimes, this behavior can be caused by a faulty battery?
Regards,
David M.
'03 Vue Electrical Issues Mhessert Vue Tech 12 09-22-2013 04:01 PM
03 vue electrical issues Turbokid16 Vue Tech 10 07-09-2012 10:59 PM
Electrical Issues c-dieckhoff S-Series Tech 7 07-16-2010 02:00 PM
Electrical Issues...? loadlitnr Vue Tech 6 10-14-2007 03:12 PM
Electrical issues SLVR_Saturn S-Series General 5 01-20-2004 07:25 PM
