#1 |
![]() Join Date: Jul 2012
I have a 2004 Saturn Vue. The entire radio stopped working including the clock.
I checked the owners manual and see the fuse for the radio in the front passenger fuse box. I took out the fuse but it doesn't look blown. I'm not sure if the fuse box under the hood has a fuse for the radio. Does it? So, what can I do to get my radio working again? Which fuse should I look at? Or could there be another issue? And, does anybody have a fuse diagram for the 2004 Saturn Vue that is more descriptive than the manual? |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2008
2005 VUE 3.5L
2007 VUE 3.5L
![]() Quote:
There are two fuses in the IP fuse block. There'll be a third in the underhood box if you have amplifier (doubt if this would affect clock). See attached thumbnail.
I visit forum monthly, if at all. Feel free to send private messages if you think I can help. Don't use visitor message as I never check those. |
#3 |
I would check the BATTERY 40A fuse in the underhood fuse block.
If your Vue came with a factory-installed subwoofer, you will also have a fuse labeled PREM AUD 20A at the underhood fuse block. There are two fuses in the instrument panel fuse block. One is RADIO 10A and the other is RADIO (IGN) 10A. If all fuses check out fine, the radio is probably defunct. You can take it out and double-check the plug going to it just to be sure though. Replacements can be found on ebay for under $50 unless you have an MP3-capable six-disc radio which goes for around $100.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone* 2007 Chevy Equinox LT 198K miles 2018 Chrysler Pacifica Touring L 56K miles |
Bookmarks |
Tags |
radio |
Battery died/radio stopped working | Badman | Aura General | 4 | 01-12-2010 01:54 AM |
Won't turn over & key fob stopped working while wiring radio | yottabit | S-Series Tech | 3 | 06-20-2009 08:56 PM |
XM radio stopped working... | REDLINE_IT | Vue General | 3 | 06-28-2008 02:14 PM |
'04 Vue Radio stopped working (but CD/MP3 still works) | russellhome | Vue General | 4 | 01-18-2008 08:03 PM |
radio stopped working | oldgoat | S-Series General | 3 | 08-11-2005 05:24 PM |
