![]() ![]() ![]() ![]() ![]() Join Date: Mar 2017
1995 SW2
Hello all,
Since I purchased my 95 SW2 and plan to daily drive it for a few years, I figured I would handle the rust issues before they spread. Here's the pictures of the process. Passenger Side ![]() ![]() ![]() ![]() ![]() ![]() ![]() Driver Side ![]() ![]() ![]() ![]() Essentially I removed the top layer, followed by the bottom layer. Then I cleaned everything up, primed and painted it, then assembled it layer by layer. It took me three or four nights working on it. It is nowhere near perfect and the paint does not match but with some body filler and proper paint this summer I should get it looking factory. But for now this will do as it is now 95% rust free on the entire chassis. I also had to wire wheel and scrape out the seam under the passenger seam where the rear floor pan meets the front floor pan, as it was rusting and the seam sealer was peeling up. I got it down to metal, filled the pin holes with weld, and primed and painted it. Once everything was semi dry, I put a thick layer of seam sealer on the inside and outside. So, hopefully it will last another 26 years before rusting again! If anybody has questions about this repair, just ask! Thanks for viewing, Chris
1994 Sl2 5spd First Car, Stock: 56,576 (Totaled 1/10/2018) 1995 Sl2 5spd: Retired Daily, Not Stock: 192,000 1998 Sl2 5spd: Family Car, Stock :135,000 1995 SW2 4spd: Daily, Stock: 91,000 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
Very nice. So that is no new parts? Just rip it apart, clean it up, and weld back together? I may do this to my SC2 someday.
Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018 |
![]() ![]() ![]() Join Date: May 2019
Nice work!!!
2000 SL2 Automatic 200,XXX miles. 1999 Chevy K3500 |
1995 SW2
#5 |
Looks like new! Mine are currently covered in a layer of oil, lol. If I do ever decide to repair them, it doesn’t seem like it will be that hard
Did you use an angle grinder to cut them out? All I have is a cheap reciprocating saw and it’s definitely not good enough to take out the door sills.
97 SL2, auto, 123K miles |
This tool with a cutoff wheel goes through steel like butter.
https://www.harborfreight.com/corded...der-69645.html I have an actual Milwaukee one. For $13 it seems hard to go wrong. I have a real sawzall too. The purpose of the hobby is to collect tools.
#7 | |
1995 SW2
Then a welder, grinder, and wire wheel to clean it all up.
#8 |
1995 SW2
You will need a donor rocker segment from a car that is not rusted. The ones I used were from a 99, into my 95 frame. The shape was the same until about 6-8" up from the rear. The clips for the trim pieces are in different locations, so I had to fill the old ones in with weld and drill new ones to accommodate the trim pieces. Overall it is not a bad job.
rusted rear door sill repair | targettuning | S-Series General | 1 | 03-30-2012 09:13 PM |
1995 Sl1 door sill repair | SRGW | S-Series Tech | 3 | 11-29-2011 04:21 PM |
rear door sill repair | spencerforhire | S-Series Tech | 5 | 10-23-2010 12:51 PM |
FS rust rocker repair panels | saturnhacker | Classifieds | 0 | 10-20-2005 08:58 PM |
Rusty door sill RR,got one yet? | auxmike | S-Series Tech | 2 | 09-02-2002 10:57 AM |
