Old 12-11-2006, 01:55 PM   #1
kx250ryder
kx250ryder will become famous soon enough
Information Unlocking Theft Deterrent Radio
I was troubleshooting a dead driver side power window on my girlfriend's 1998 Saturn SL2 and it killed the battery.
Upon hooking up the battery charger, I noticed that it triggered the LOC code on her radio (CD player w/ EQ). I was surprised because I figured nobody ever bothered to set their radio lock code (since they might forget and lock themselves out). Well, apparently the previous owner did set a code (just my luck). Anyway, I guessed all the popular codes, and apparently after too many tries, it locks the radio into INOP mode.
I found a link to a forum thread (below) that described the process for GM vehicles, however Saturn and Geo use 4 digit radio codes instead of 6 digit codes like the rest of GM so the process is different than what you see spread all over the internet:
http://forums.carreview.com/showthre...?t=1839&page=4
***Read all steps before attempting. You are on a time limit when entering codes, so knowing what to do in advance will save alot of frustration***
1.) To begin, if your radio is displays LOC, then proceed to step 2. If your radio says INOP, then turn your ignition to the RUN position, and turn the radio ON. You must leave it like this for a minimum of 1 hour (not 59 minutes) to clear the INOP message. I would wait 1 1/2 hours just in case doing it too early causes the timer to start over.
2.) Turn your ignition to RUN (if not already), and your radio to OFF. Press and hold preset buttons 2 and 3 for around 5-10 seconds to obtain a scrambled version of your radio's original factory set code.
3.) Call 800-537-5140 and ignore whatever you are promted to do (something about different dealer brands Chevy, Pontiac, Saturn,etc.), and type the number 202108 into your phone and then press the # button.
4.) Input your radio's 4 digit code into your phone when prompted, then press the * button (NOT pound symbol like above step) and be ready with a pen and paper to write down the unscrambled code. Keep this code somewhere you WILL NOT lose it. I wrote mine in the notes section of the owners manual.
5.) Once you have the code written down, press and hold 5 and 6 on your radio's preset buttons for 5-10 seconds.
6.) Then press the seek down button once to start the entry process.
7.) Using the following key, repeatedly press the buttons to set your code:
seek down = first digit
seek up = second digit
tune down = third digit
tune up = fourth digit
NOTE: I just checked a picture of the stereo out and discovered the buttons have arrows facing left and right and not up and down. For the purposes of this process, left represents down, and right represents up.
8.) Once you have the code entered, press AM/FM to set it.
Presto, you have kept your local dealer from screwing you out of $30-100 dollars.
Note that the code given in step 3 belongs to a Pontiac dealer out there somewhere (judging by the number 2 at the beginning of the code if you listen to the voice prompts on the 800 number), so if they go out of business or wise up to their code being used, this method may eventually not work. However, the post I dug it up from is over a year old, so there is hope that it will last a while.
If you are not comfortable with the above process, I believe Saturn of Tempe (Arizona) will help you reset your radio over the phone for free; not sure though, I wanted to know how to do it myself, since service departments aren't always open especially on nights and weekends. I wouldn't go in person (since you will be easier to charge standing there with your wallet/purse- just call, and be very very VERY nice so that the tech doesn't feel like screwing you into paying.
Add to kx250ryder's Reputation
Rate the quality of this post and help kx250ryder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kx250ryder is offline   Reply With Quote
Old 12-11-2006, 02:42 PM   #2
bc3tech
bc3tech will become famous soon enough
bc3tech's Avatar
2007 AURA XR
Default Re: I Did It!!!! Theft Deterrent Radio Unlocked, No Dealer Help!!
sweet thanks for posting it on the web so the theft deterrent's now moot!
shoulda said u kno how to do it, and instructed ppl to PM you.
Add to bc3tech's Reputation
Rate the quality of this post and help bc3tech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bc3tech is offline   Reply With Quote
Old 12-11-2006, 02:57 PM   #3
94sc2boy
94sc2boy is on a distinguished road
1994 SC2
Um ya, if some thief is going to take 1.5 hours to find out your code...keep in mind your SATURN STEREO! Then you leave in a very interesting neighborhood.
Thanks kx250
Add to 94sc2boy's Reputation
Rate the quality of this post and help 94sc2boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
94sc2boy is offline   Reply With Quote
Old 12-11-2006, 03:15 PM   #4
kx250ryder
I wrote this guide because there are others out there who have gotten locked out of using their own legitimately purchased stereo. And some swindling dealers took what should have been a free fix and turned it into a for profit scheme.
Why should they have to wait for me to check my PMs or call a hundred dealers to find one who would help for free? How would you like it if you came searching for help and I made you jump through hoops, when I could have just as easily given you the answer?
There is no way that I would restrict information based on the assumption of what people "might" do with it. Just because there are instructions on the web for how to build a bomb, doesn't give you license to use it maliciously.
Old 12-11-2006, 04:47 PM   #5
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
1994 SL2
Its not like this is super secret information. Any thief that is going to steal a STOCK radio already knows how to do this. This is ONLY helping people that locked themselves out of their own radio. There was a thread a couple of years ago about this, and that code stopped working a while back, so this will help alot of people. I am personally against any sort of lockout, because it only helps keep honest people honest, and hurts everyone else.
You can tell Linux is made by geeks.
Add to RangerRover's Reputation
Rate the quality of this post and help RangerRover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RangerRover is offline   Reply With Quote
Old 12-12-2006, 12:58 AM   #6
eRic 02sc2
eRic 02sc2's Avatar
yeah this is better than the video online that shows how to open a U-lock with a Bic pen.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Add to eRic 02sc2's Reputation
Rate the quality of this post and help eRic 02sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-12-2006, 06:40 AM   #7
alfieferenzo84
alfieferenzo84 is on a distinguished road
2004 ION-1 Sedan
wow that sucks the dealer hear in ohio unlocked my dads 98 when the batt got replaced it locked the radio, What a scam!
I dont think anyone would steal a stock saturn radio but who know and thanks for posting in case anyone needs it!
I wish it would end and just run like a normal car without somthing going wrong everytime i drive it!
Add to alfieferenzo84's Reputation
Rate the quality of this post and help alfieferenzo84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
alfieferenzo84 is offline   Reply With Quote
Old 05-17-2007, 04:01 PM   #8
SL2sleeper
SL2sleeper is on a distinguished road
SL2sleeper's Avatar
It doesn’t matter MOFO*******S will bust into any car just too look and see what is inside.
Case in point is my Nissan Murano that got broken into just to look since THERE AINT *****NIT INSIDE EVER. All that was taken was a whopping .75 cents out of the change holder. So for the cost of the .75 cents theft I got to pay 150 for glass and another 400 for paint since they enjoy scratching up the car as they climb into it.
ER OUT
No traction control but no need it is a 5 speed
In the end ride quality means nothing performance is everything!
Add to SL2sleeper's Reputation
Rate the quality of this post and help SL2sleeper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2sleeper is offline   Reply With Quote
Old 12-12-2006, 11:34 AM   #9
RangerRover
1999 SW2
1994 SL2
Or how to bump-key. All good information for us normal folk, that the criminals long since knew. It forces the lock manufacturers to stop lying and staying their lock is good, since no one knows better.
Old 12-12-2006, 02:41 PM   #10
madpogue
1996 SW2
I got two of my four U-locks open with a Bic pen, and helped bust the story open on bikeforums. Funny thing is, it was known about, but obscurely, for over 10 years. Kryptonite and Planet Bike offered to replace ALL such locks for free (I got all four of mine replaced). Of course, this is a little different, as a U-lock provides real security for something that could be a real theft target, unlike the "theft deterrent" factory radio. (Wanna know what its true "theft deterrent" is? The fact that it's a factory radio!)
Add to madpogue's Reputation
Old 12-11-2006, 05:45 PM   #11
eljefino
eljefino will become famous soon enough
eljefino's Avatar
1995 SW1
2000 SL1
Note that 2000+ saturn radios have a different procedure.
I also agree that 1.5 DIN GM stock radios aren't quite that cool to the thieves. The curvy 95-99 stereos won't even fit other cars properly. This lockout thing is, as stated above, mainly a GM dealer kickback, despite marketing/brainwashing to the contrary. Same as those $60 passlock/passkey key fobs.
My dealer doesn't even know how to unlock the 2000+ radio... despite that I could get the pre-code myself. They offered me a stock GM parts brand new radio for $470 or so. Er... no.
Add to eljefino's Reputation
Rate the quality of this post and help eljefino reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eljefino is offline   Reply With Quote
Old 12-12-2006, 12:53 AM   #12
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
Saturn of Puyallup helped my dad out for free over the phone. They're good there, though. Saturn of Renton told my dad to bring his car down there, so they could do it (and of course charge labor) so my dad called Puyallup when he got home, so make an appointment, and they did it over the phone.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 05-18-2007, 07:36 PM   #13
waremock
waremock is on a distinguished road
Can someone please tell me what this procedure is?
I have an 2001 SL-2 With a CD and Tape deck radio.
Thanks
Add to waremock's Reputation
Rate the quality of this post and help waremock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
waremock is offline   Reply With Quote
Old 06-01-2007, 10:40 PM   #14
eRic 02sc2
eRic 02sc2's Avatar
Wrench Re: I Did It!!!! Theft Deterrent Radio Unlocked, No Dealer Help!!
Thanks
If you forget your personal code, if the radio theft deterrent feature is accidentally activated with an unknown number, or if the radio is in the locked mode, contact your Saturn retailer. Your Saturn retailer is authorized to obtain the factory programmed code that is assigned to your radio to reset your system.
eRic 02sc2
Old 09-28-2007, 07:23 PM   #15
kickinazz
kickinazz is on a distinguished road
Default Re: Unlocking Theft Deterrent Radio
Just to let anyone know, this method still works. I didn't know what to do after i took my stereo out and put it back in to see "loc". Number to call works great and the code worked great for my 97 saturn. Thanks to who ever found this method.
Add to kickinazz's Reputation
Rate the quality of this post and help kickinazz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kickinazz is offline   Reply With Quote
Old 06-22-2008, 05:32 PM   #16
ProfessorU
ProfessorU is on a distinguished road
1995 SL2
1993 SL1
This method still worked for me today, 2008-06-22. Thanks!
http://www.jonkline.com
Add to ProfessorU's Reputation
Rate the quality of this post and help ProfessorU reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ProfessorU is offline   Reply With Quote
Old 01-05-2007, 03:50 PM   #17
SaturnGirl33
SaturnGirl33 is on a distinguished road
Happy Re: Unlocking Theft Deterrent Radio
Thanks for the help!!! I have been riding around for 4 weeks with no radio,,, although their nothing to brag about, it's still nice to have some sound. Glad I didn't have to pay to get it fixed. Works perfectly!
Add to SaturnGirl33's Reputation
Rate the quality of this post and help SaturnGirl33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnGirl33 is offline   Reply With Quote
Old 07-14-2008, 12:50 AM   #18
kb7010
kb7010 is on a distinguished road
I am very late on this one.. but it has already been said.. you think a thief is going to steal a radio he can't un-lock.??? come on.. in fact I use to work at a Honda Dealership as a mechanic.. we would get calls ALL the time on radio codes.. how where we to know if it was a thief or a honest person that needed help..?? we didn't ..!!!!! bottom line.. the info was given to the person EVERY TIME..!!!!
great post IMHO.. I don't need it as my radio doesn't have that function..
that is one function the car manufacturers need to do away with IMO..!!!! as ALL it does it make it harder on the honest person..!!!!
just my .06 cents worth.. as .02 cents won't get you anything nowadays.. lol
Rex
Add to kb7010's Reputation
Rate the quality of this post and help kb7010 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kb7010 is offline   Reply With Quote
Old 08-01-2008, 07:04 PM   #19
cwt580
cwt580 is on a distinguished road
so frustrating........i can get the radio now to the "_ _ _ _" screen but the code i got from the above number creates the err code. i am waiting another hr for it to get to that screen. ive tried that code,2x and 1234 once.
any ideas?...........anyone?
Add to cwt580's Reputation
Rate the quality of this post and help cwt580 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cwt580 is offline   Reply With Quote
Old 08-04-2008, 04:54 PM   #20
cwt580
ok got it working...........not w/ our local yocal dealership(Saturn)
The steps above work but for 2000 and newer the number listed doesnt give you the right code. A tried to deal with Saturn dealership. They wanted the car and $30 to unlock. drove to my local Chevy dealership(1 mile) with the code and vin# and he called and talked to Saturn. They gave him the correct unlock code after telling him the above info. He talked to someone direct and they told him about the 2000 and beyond.........
gave the guy $10 tip for the FREE info........now i have a real sour taste from my local saturn dealership(25miles). Next closest is 75 miles!!!!!!!! at least good old Chevy worked with me to fix an issue.......
How to tell - Theft Deterrent Radio. Red97sc2 S-Series Tech 5 09-16-2008 11:48 PM
Theft-deterrent Radio Installation? d_rock S-Series Tech 11 07-05-2008 10:22 PM
Theft Deterrent Cd Player stang50 S-Series General 5 08-06-2007 01:46 PM
A different theft deterrent radio question BarnOwl S-Series Tech 9 05-22-2007 06:27 PM
Theft Deterrent malfunction? smull333 S-Series General 3 03-16-2005 07:41 PM
