Closed Thread
Old 10-12-2004, 05:17 PM   #1
max1
max1 is on a distinguished road
Default rattling noise
I have a 94 1.9lt sohc that has 177,000 on it. I just started hearing a rattle sound coming from around the water pump area. It is not leaking any fluids., could it still be the pump? Is the changing of the pump the same as the dohc, that's all I could find in the posts.
max1 is offline
Old 10-12-2004, 05:30 PM   #2
Lucas1
Lucas1 is on a distinguished road
Default
very possible. and yes its the same.
Lucas1 is offline
Old 10-13-2004, 02:09 AM   #3
sierrap615
sierrap615 is on a distinguished road
sierrap615's Avatar
Default
check the heater return pipe, it may hit the firewall(if so i have the repair info)
http://www.saturnfans.com/photos/sho...p/photo/15888/
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 10-14-2004, 01:02 PM   #4
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
1996 SC2
Default
Check your tensioner pulley. Mine sounded like the water pump area but it had just been replaced. It turned out that the tensioner pulley was bad.
-96 SC2 gets 35 mpg mix city/hw.
sps SOHC is offline
Old 10-26-2004, 12:07 PM   #5
rapidnet_rick
rapidnet_rick is on a distinguished road
Default sound....
So, what does it sound like?
I have a strange sound that from inside of the car you would almost swear is a valve tap. However it is not, it seems loudest over by the power steering pump, and the alternator. (Interesting is that it is harder to hear outside of the car, even with the hood up, and listening in the engine compartment.)
However, the idler, and tensioner pulleys are both in the same general area. Mine sounds like a tapping, or clicking coming from the passanger side of the car. If you rev the engine it starts making the noise arounf 1200-1500 RPMs. It does NOT seem to be comming from the engine. Not sure about the water pump area, but I'll check.
rapidnet_rick is offline
Old 10-26-2004, 12:46 PM   #6
94sl2guy
94sl2guy is on a distinguished road
1996 SL1
Default
I have a '94 SL2 and I'm having the exact same problem. Still not convinced it is not the yalves but when I remove the oil cap, they volume does not increase as I would have thought it would. The noise sometimes comes and goes but when it is not rattling and I put load on the alternator, the noise seems to re-appear so I'm thinking it may be alternator related. But the load could also make one of the other belt-related items get noisy as well. I'm going to pull the belt off tomorrow and run the car to see if the noise disappears. I'm also going to pull the valve cover and check the cams, lifters and oil supply to those parts.
How loud is your rattling? Mine is very loud, almost deafening but my car also has 452,000 kms so it could be anything. I'll post a reply with what I find.
94sl2guy is offline
Old 10-26-2004, 07:44 PM   #7
Nowhere Man
Nowhere Man is on a distinguished road
Nowhere Man's Avatar
1995 SW2
Default
I think you're on to something here. When my belt tensioner went out, I thought my car was pininging but the noise appeared to be comming from around the belt area. I took a flashlight and shone it on the belt tensioner. Sure enough it was vibrating with the noise, so that was it.
95' SW2
131,000 Miles
32-MPG avg.
Nowhere Man is offline
Old 10-27-2004, 01:57 AM   #8
my99sl1
my99sl1 is on a distinguished road
my99sl1's Avatar
1999 SL1
Default
it could be also a cracked rod
my99sl1 is offline
Old 10-27-2004, 05:25 PM   #9
rapidnet_rick
Default
UPDATE:
I just replaced the tensioner pulley and the idler pulley, and that cured my problem.
I would have never guessed/ Sounded almost like a valve tap to me at first... Until I poked under the hood...then seemed to come from PowerSteering pump...
BTW... on my 95 SC2, it was a royal pain in the *****.... I am not new to working on cars...there was zero room to work. I spent about 30 minutes just getting the bolt back in/on the idler pulley!
If access to the parts wasn't an issue, this would have taken perhaps 10 minutes. It tool almost 2 hours!
Next time I am taking the upper motor mount off to get room. BTW, I did jack vehicle up, removed tire and wheel well....still no room to work.
Old 10-27-2004, 11:29 PM   #10
94sl2guy
1996 SL1
Default
Pulled the valve cover gasket and the timing chain is pretty much shot - it appears to have stretched and the upper chain guide (top of the motor on the left hand side (looking from the front)) has had the teflon runner (I think it's teflon or some plastic material) worn away. The chain sags down about 1/2" between the two gears. The upper guide is $45.00 Cdn but to do it properly I believe I should replace the chain and the tensioners as well. Not sure if it is worth it as the engine has 453,000 km and is also using a liter (1 quart approx. for those south of the border) every 250 km - that's why Ive been looking for a nice SC2 in around the 2001 vintage. Other than the engine, CV joints and clutch, the rest of the car is in great shape so I may sell her to someone who needs a good body and has a motor to put in. CRAP! Hate to see her go!
94sl2guy is offline
Old 10-28-2004, 05:27 PM   #11
Lucas1
Default
if you do decide to go through with changing the timing chain, get the timing chain set from saturn. it comes with a chain, guides, sprockets, and tensioner. if your going to do it, you should do it right. you will also need a tube of the saturn silicone, or its aftermarket equivelant, i think the saturn stuff is made by permatex, but im not 100% on that.
as far as you oil consumption goes, you should do a search for saturn internal cleaning TSB. it is a thread i posted that has a cleaning procedure that ive had great success with. i would recommend giving it a shot if you decide to keep the car.
Lucas1 is offline
Old 10-29-2004, 08:10 PM   #12
FrozenPilot
FrozenPilot is on a distinguished road
FrozenPilot's Avatar
Default
Sounds like I'm not the only one who's had a rattling tensioner after having bad luck with the NAPA/Gates tensioner went with Dayco and have had no problems since.
Another rattling belt tensioner problem solved!!!
Its all about the coffee...
'06 Mazda 6i & '95 Saturn SL1
FrozenPilot is offline
Old 10-31-2004, 04:31 PM   #13
dwp
dwp is on a distinguished road
dwp's Avatar
Default
My rattling noise started a couple of weeks ago. It seems to do it only in the morning when the engine is cold. And then after ideling for 5 mins. it's quite. Sounds like a Mercedes deisel, when it's making the noise. It seems to be coming from under the rocker arm cover but when I pull the oil filler cap off there is no extra noise coming from the opening.
It's a 98 SL2 with 103,000 miles on it.
dwp is offline
Old 10-31-2004, 06:10 PM   #14
sierrap615
sierrap615's Avatar
Default
sounds like a timing chain starting to go. i would say use thicker oil, but winter is coming.
Old 10-31-2004, 07:25 PM   #15
dwp
dwp's Avatar
Default
Thanks sierrap615. I've always used Castol GTX 20-50 in it since it was new. And changed the oil every 3000 miles religiously for the last 7 years.
dwp is offline
Old 10-31-2004, 07:42 PM   #16
sierrap615
sierrap615's Avatar
Default
20-50 may be a little to thick, i ran 10w-40 this summer with my bad chain(spec is 5W-30 or 10W-30)
Old 10-31-2004, 08:38 PM   #17
emptypockets
emptypockets is on a distinguished road
emptypockets's Avatar
1999 SC1
Default
I was hearing a clicking/grinding sound in my 99 SC1. It turns out that the plastic cover over my AC clutch was ripped almost all the way off.
emptypockets is offline
Old 11-01-2004, 11:15 PM   #18
Lucas1
Default
thinner oil is actually better for the timing chain because the tensioner has a very small passage that operates the hydraulic tensioner and adjusts it. using thicker oil can actually cause the tensioner to allow excess slack in the chain causing premature wear. saturn recommends 5w-30 or 10w-30 depending on climate. you should NEVER use 20w-50 in a newer car that is not designed for it.
Lucas1 is offline
Closed Thread
AC rattling noise liarliar17 S-Series Tech 7 03-11-2014 05:11 PM
A/C Rattling Noise mirandm S-Series Tech 15 07-08-2008 01:36 AM
AC Rattling Noise mirandm L-Series Tech 1 06-30-2008 12:26 PM
Rattling noise is still there Son93SL2 Miscellaneous Tech 6 08-15-2002 08:44 PM
rattling noise sc295 S-Series Tech 5 12-10-2000 04:11 PM
