Old 03-08-2007, 05:53 PM   #1
illuminati63
illuminati63 is on a distinguished road
2005 ION-2 Quad Coupe
Default Sometimes it hates me other times it doesn't
Ive had my Saturn Ion 2 QC since april of 2006 and it been fine, except recently. This originated in the fall but then happened more later but not at a constant rate. I would turn my key and nothing would come from the engine. all my lights came on, everything was fine just nothing mechanical worked ha. the first time it happened i thought it was a dead or weak battery so i jumped it and then it worked fine. but it continued to happen so i had it looked at by one of the local gas stations. they said nothing was wrong and if happened again to call them. I don't want to get ripped off so my question is this: Have any car owners had a problem similar to this? My car will start if it is jumped but not alone so i have no idea what the problem is.
BTW my mileage is 15500 ish, the only mod i have is a flip out screen, other than the look at the gas station, ive only had the oil changed three times.
I've been looking at other posts and i didn't see the same problems so i figured i might post a new thread with my exact problem. sorry if this is a repeat i didn't find anything else about this. and if it is a repeat please reply with the link to the correct thread
illuminati63 is offline   Reply With Quote
Old 03-08-2007, 06:02 PM   #2
synthkat
synthkat is on a distinguished road
synthkat's Avatar
2004 ION Red Line
Default Re: Sometimes it hates me other times it doesn't
Does the odomoter/status display show "Service Engine" on it and the "Car Lock" icon stays lit? If so, it'll probably be your ignition switch. It started happening to me again after it had gone away. Except for me all I have to do is take out the key, reinsert it and it turns on like nothing was wrong.
If you take it to the dealer, most likely this will be your woes. I've just been procrastinating taking it to the dealer but I've seen on here and on the RL forums that this is usually the case.
- Synth
synthkat is offline   Reply With Quote
Old 03-08-2007, 06:39 PM   #3
illuminati63
the only thing is that occasionally the car lock icon stays lit while im driving but i never really knew what that icon meant i guess i should have looked it up hah. I don't want to go to the deal cause i don't want them ripping me off by saying i need something new that is too expensive. i dont have alot of money im only in high school soo..
Old 03-08-2007, 06:47 PM   #4
synthkat
synthkat's Avatar
2004 ION Red Line
Actually, this should be covered by the standard warranty. I'm not sure if you bought the car used or new but the warranty is fully transferrable and you shouldn't have to pay a penny on this issue. Since the Passlock icon is lit (actually that is what it's called...heh, not Car Lock) it is a problem with the ignition switch or the BCM for sure. Take it in, they should take care of it without you having to pay anything plus you'll get a rental since this fix should take more than an hour.
- Synth
Old 03-08-2007, 07:43 PM   #5
illuminati63
OKay thanks soo much i really appreciate it
Old 03-08-2007, 07:47 PM   #6
synthkat
synthkat's Avatar
2004 ION Red Line
No prob!
- Synth
I think my car hates me... jengler S-Series Tech 13 06-25-2008 09:06 PM
My Sl2 Hates Me!!!!! gpopple S-Series Tech 3 07-17-2007 07:58 PM
Ya know god hates you when.... Phredawgy S-Series Tech 10 04-10-2007 10:23 PM
my sl1 hates cold mornings infernalservice S-Series Tech 1 11-15-2005 12:08 PM
SL1 hates the cold - and who doesn't ! SATSL1 S-Series General 4 10-04-2004 03:36 PM
