Old 01-31-2009, 11:25 AM   #1
pimpin88
pimpin88 is on a distinguished road
1996 SL
Default Tensioner/Idler pulley bolt torque
Guys, I left my manual at home and I am going to be replacing the upper motor mount (TAM) so I figured I'd replace the belt and put new bearings in the tensioner and idler pulley since the idler pulley wobbles.
What are the torque specs for the bolts for the idler and tensioner pulleys?
Add to pimpin88's Reputation
Rate the quality of this post and help pimpin88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pimpin88 is offline   Reply With Quote
Old 01-31-2009, 11:41 AM   #2
Growser
Growser is on a distinguished road
Growser's Avatar
Default Re: Tensioner/Idler pulley bolt torque
This link should help you out. http://www.saturnfans.com/forums/sho...ght=water+pump
7 Saturn Car Family with + 900,000 miles.
2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Add to Growser's Reputation
Rate the quality of this post and help Growser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Growser is offline   Reply With Quote
Old 01-31-2009, 12:00 PM   #3
The idler pulley bolt is 20ft-lb and the tensioner pulley bolt is 22ft-lb. These are for the bolt through the bearing that holds the pulley.
Old 01-31-2009, 01:31 PM   #4
hholbein
1997 SW2
Interesting. I didn't know that the bearings on the idler and tensioner pulleys were replaceable separately. Anyone know the Saturn part numbers for these???? Or are you just planning to find a match once you disassemble it?
Add to hholbein's Reputation
Old 01-31-2009, 05:05 PM   #5
The bearing is a standard alternator front bearing, 6203 double sealed. You can buy it at any decent parts store.
Are the serp belt idler pulley and tensioner pulley the same part - 93 DOHC?? 93goldsl2 S-Series Tech 6 04-10-2010 02:03 PM
Idler pulley or tensioner? JerryHughes S-Series General 9 02-02-2008 05:53 PM
Idler pulley and/or tensioner pulley replace nmsaty S-Series General 11 03-20-2006 07:02 PM
tensioner pulley=idler pulley? bhall10 S-Series Tech 32 05-24-2004 08:37 PM
Idler or tensioner pulley? RBH S-Series Tech 2 11-27-2001 10:28 AM
