![]() Join Date: Apr 2005
1994 SC2
Where is the neutral safety switch located on a '94 Saturn SC2, and how do you replace it??
The Park/Neutral Position Switch is attached to the rear side of the automatic transaxle case just above driver's side axle.
It must be installed very carefully or the internal part of the new switch could be damaged. It also requires adjustment when installed, using an ohmmeter or continuity tester to check for continuity across terminals on the switch, before tightening the switch to case bolts. |
Neutral safety switch help | Highmile | S-Series Tech | 2 | 12-15-2009 02:15 PM |
how to change neutral safety switch | shur35 | S-Series Tech | 3 | 07-17-2009 11:06 PM |
Neutral Safety Switch????? | Clickety_Clack | S-Series General | 10 | 12-03-2008 10:24 PM |
Transaxle Range Switch\Neutral Start Safety Switch | lonelywolf8588 | S-Series Tech | 2 | 07-20-2006 08:55 AM |
Neutral Safety Switch | Marlin Liew | S-Series Tech | 7 | 11-04-2004 12:55 AM |
