Old 08-07-2010, 06:10 PM   #1
LarryBean
LarryBean is on a distinguished road
Default Astra using coolant
Hello forum; about 6 weeks ago the belt broke on my 08 Astra. I didn't initially realize and drove until the temperature light came on. I stopped and had the car towed. The Chevy dealer replaced the belt and a coolant bypass they said had been fried by the overheating.
Since that time the Astra is a) using about 2 inches of coolant a week (not leaking) b) has the check engine light on most of the time c) when starting especially after overnight it chugs for 15-20 seconds then seems to "clear it's throat" and runs well and d) there is not white smoke from the exhaust but I frequently get a whiff of coolant
I suspect a head gasket but had it back to the dealer and they could not find a head problem; they pressure tested etc. Any thoughts? Could there be something pushing a small amount of coolant into the engine instead of a failing head gasket.
I am puzzled. Thanks for any input!
Add to LarryBean's Reputation
Rate the quality of this post and help LarryBean reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LarryBean is offline   Reply With Quote
Old 08-07-2010, 10:46 PM   #2
Astra La Vista!
Astra La Vista! has a spectacular aura aboutAstra La Vista! has a spectacular aura about
Astra La Vista!'s Avatar
2008 Astra XR
Default Re: Astra using coolant
I'd suspect head gasket as well, since that is the most likely junction where coolant can enter the combustion chamber (short of a cracked head or cracked block), and rough running on initial start-up sounds like fouled plugs. If you're adding coolant, you're losing coolant -- plain and simple. The coolant system is either leaking externally or the engine is burning it (ie: leaking internally). A proper pressure test should determine either/both, but depending on how much driving you do per week, that leak might be so small that only the most patient technician would be able to spot it.
Did they say what code(s) were responsible for the SES light being on? Do you park indoors where you could possibly monitor any coolant leaks on the ground?
"That's a Hruck Bugbear, manufactured in Eastern Europe in the eighties and imported to the States. People mock it as a poor man's Yugo. I consider it the pinnacle of Cold War Balkan engineering."
Add to Astra La Vista!'s Reputation
Rate the quality of this post and help Astra La Vista! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Astra La Vista! is offline   Reply With Quote
Old 08-10-2010, 12:07 PM   #3
JAC
JAC is on a distinguished road
I would keep following up with the dealer. No matter what the problem is, they should not be giving you a car back with the Check Engine light still on.
Add to JAC's Reputation
Rate the quality of this post and help JAC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JAC is offline   Reply With Quote
Old 08-23-2010, 08:50 AM   #4
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
I am currently replacing the head gasket on my Astra. I ordered the gasket and bolts which won't be here till Sept 1st. When I suspected a problem, I did a compression test and plug reading, neither of which confirmed a leak. I did however have excess pressure on the coolant side, which for some reason made the vehicle hard to start until the reservoir cap was loosened. Coolant was also entering the crankcase. I have since removed the head(one of the more difficult head removals) and read the head gasket- still nothing obvious. Placing a straight edge on the head I came up .004-.005 distortion- I'm hoping this is the culprit. The head is now milled and I am waiting for the gasket to arrive. I will put a temp gauge (which the factory should have done) on this vehicle before it goes back on the road. I think the problem started with a front end accident which took out the radiator. That was before I owned the car.
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
Old 12-03-2010, 03:39 PM   #5
adammsu
adammsu is on a distinguished road
adammsu's Avatar
2008
I recently got the "coolant level" idiot message as well, just ticked 36k miles. It was indeed below the line when cold. I added, maybe a couple ounces, of the red stuff and it filled to the line when cold.
do you think its reasonable in 36k miles for the coolant level to drop a little? i recognize its possible that it is a new "feature" but after i topped it off, i did a 200 mile drive, and seems topped off still. No floor marks that i have noticed, but its a garage spot, so the area where the spot would be is always covered..... with the car, lol.
i also had an alero with a gasket leak in the past, so i am pretty sensitive to the smell..... i havent noticed the tell tale smell of coolant burning....
glad the powertrain warranty is 100k/5 years... i might try and take it in, we'll see if it drops again.
2008 Astra XR5 Twilight Blue
---I hate being a mod-inclined person w/o the money/time to do any of it---
Add to adammsu's Reputation
Rate the quality of this post and help adammsu reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adammsu is offline   Reply With Quote
Old 12-08-2010, 03:52 PM   #6
Nightwalker
Nightwalker is on a distinguished road
Nightwalker's Avatar
2008 Astra XR
2005 ION-2 Sedan
I just rolled over 38k and I've been getting the creck coolant message too.
Granted, we just hit the below-freezing part of winter, so that is a factor too.
Is there a special type of coolant to use, or is plain antifreeze safe?
Add to Nightwalker's Reputation
Rate the quality of this post and help Nightwalker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nightwalker is offline   Reply With Quote
Old 12-09-2010, 08:25 AM   #7
72gssaturn
72gssaturn will become famous soon enough72gssaturn will become famous soon enough
72gssaturn's Avatar
2008 Astra XR
if the collant is red, then it is dexcool.
Your engine must have gotten very hot. if u are losing coolant after the engine overheated, then the head has warped and will need milling. there could also be a crack in the head. and if coolant entered the crankcase, u could have furthur problems with main bearings.
wouldn't it be great to have both an analog temperature & an oil pressure gauge!!
Gerry
72 Buick GS red
2008 Astra XR black 3dr
99 SL1
Add to 72gssaturn's Reputation
Rate the quality of this post and help 72gssaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
72gssaturn is offline   Reply With Quote
Old 12-09-2010, 11:32 PM   #8
Lunchbox1984
Lunchbox1984 is on a distinguished road
Lunchbox1984's Avatar
2008 Astra XR
2003 L-Series 2.2L Sedan
Originally Posted by 72gssaturn View Post
if the coolant is red, then it is dexcool.
Your engine must have gotten very hot. if u are losing coolant after the engine overheated, then the head has warped and will need milling. there could also be a crack in the head. and if coolant entered the crankcase, u could have further problems with main bearings.
my question too that is why we don't have those gauges in the first place? Ive been thinking about getting that ODB plug thing from eBay and a Netbook and using the software from Linux to show live gauges at all time via the Netbook.
Bertha [2008 F250 S.D.] 4dr|6.4ltr Diesel 350HP|4x2|6ft bed.
RED [2008 Sat. Astra XR] 2dr|1.8ltr Ecotec 140hp (will be missed)
Oggly [1984 Isuzu Trooper II] 2dr|2.0Ltr G200 89HP|White|4sp manual
Add to Lunchbox1984's Reputation
Rate the quality of this post and help Lunchbox1984 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lunchbox1984 is offline   Reply With Quote
Old 12-10-2010, 08:17 AM   #9
72gssaturn
72gssaturn's Avatar
2008 Astra XR
it is cheaper to install and use idiot lights, easier to design a dash. too bad they didn't have an option programmed into the "dic" centre that u could select to display the oil pressure, temp, voltage all the time.
Gerry
72 Buick GS red
99 SL1
Old 12-10-2010, 09:22 PM   #10
Astra La Vista!
2008 Astra XR
Cobalts and Pursuit/G5s lack coolant temperature gauges as well. If all they were going to give us was an idiot light, it would have been nice if they followed Toyota's and/or Subaru's lead and integrated an idiot light that lit up red when it was too hot, and lit up blue when it was still cold. Would have been cheaper than a gauge, and only a few pennies more than what we have now.
Old 12-10-2010, 10:24 PM   #11
Nightwalker
2008 Astra XR
2005 ION-2 Sedan
Default
What is this software you speak of, and what disto is it compiled for?
Astra-nomical: Road Tripping in New Brunswick with a Saturn Astra Charlie Astra General 20 02-09-2018 06:21 PM
New Astra making me sick (2009 Astra XE Automatic) burp Astra Tech 21 01-29-2010 02:44 AM
Low coolant level and High coolant/transaxle fluid temperature nls S-Series Tech 2 08-30-2009 09:46 AM
...Astra Turbo..Astra Convertable...& Wagon .. missan astra Astra General 1 05-10-2009 10:28 PM
2010 Astra VXR (Saturn Astra Redline?) GM Sky Man Astra General 2 06-09-2008 11:37 AM
