Old 10-20-2010, 01:18 AM   #1
blen_to
blen_to is on a distinguished road
Default BC without Radio
Hi all,
Can I do this? I would replace my radio, but would like to keep BC controls, is this doable?
Thanks
Add to blen_to's Reputation
Rate the quality of this post and help blen_to reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blen_to is offline   Reply With Quote
Old 10-20-2010, 08:06 AM   #2
Nightwalker
Nightwalker is on a distinguished road
Nightwalker's Avatar
2008 Astra XR
2005 ION-2 Sedan
Default Re: BC without Radio
As far as the BC is concerned, you do not need the factory radio for it to work. It is a stand-alone system, separate from the radio. They do interact with each other, but they are ultimately separate.
My audio system thread, how to replace speakers: http://www.saturnfans.com/forums/showthread.php?t=137456
2008 Astra 3 door XR, 5-speed MT Black Sapphire, custom audio system
Add to Nightwalker's Reputation
Rate the quality of this post and help Nightwalker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nightwalker is offline   Reply With Quote
Old 10-20-2010, 04:58 PM   #3
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
The BC remains fully functional, except that you can't access the settings menu. The settings button on the radio is the only thing not emulated on the steering wheel controls. You won't be able to set your clock with an aftermarket radio.
However, I think there is a kit that will make a steering wheel button function like the settings button.
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra, 02 L200.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline   Reply With Quote
Old 10-20-2010, 05:02 PM   #4
phatfire6
phatfire6 will become famous soon enough
phatfire6's Avatar
2008 Astra XR
This is the reason I kept my stock CDC40 and wired a subwoofer amp to it. I wish it had bluetooth though.
Add to phatfire6's Reputation
Rate the quality of this post and help phatfire6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
phatfire6 is offline   Reply With Quote
Old 10-20-2010, 09:55 PM   #5
tallNewfie
tallNewfie is on a distinguished road
2009 Astra XE
2009 Astra XR
Hey Spencerb,
What is this kit? I haven't heard of it before.
~~ Bryan ~~
2009 Astra XE - manual, wired FM mod
2009 Astra XR - auto
2001 SC2 - manual, sunroof (retired)
Add to tallNewfie's Reputation
Rate the quality of this post and help tallNewfie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tallNewfie is offline   Reply With Quote
Old 10-21-2010, 11:02 AM   #6
tackepj
tackepj's Avatar
2008 Astra XE
How did that work out for you? Was it difficult?
Current: 2008 Astra XE
Add to tackepj's Reputation
Rate the quality of this post and help tackepj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-21-2010, 04:50 PM   #7
phatfire6
phatfire6's Avatar
2008 Astra XR
Not hard at all - then again, I did it a different way than others would have. I used the Auto-Antenna pin (AR) to turn the amp on and off, and back-probed the front right line out for the RCA connection, leaving the speaker still connected.
I also used a y-splitter to halve the signal and connected both to the right and left channel of the amp. I wired a Dayton 10" Titanic Mk III subwoofer to the amp, and used the equalizer on the head unit to adjust the levels. Basically everything below 300hz, I rolled back, while everything above I rolled up. I also bumped up the treble a few notches higher. Then I tuned the amp to the levels so everything sounded even and so that the subwoofer was doing all the work at the lower levels. At the dealer, I had them turn the fade off with the Tech2. There are pluses and minuses to doing so. The plus is that the head unit will no longer automatically drop the volume. The minus is that you can't adjust the front and rear speaker levels. All fine with me! I really like the way everything sounds. Pwise952 actually got to hear it when we met up in Portland when he bought my old set of 18" wheels from me.
New radio is in! Goodbye XM radio and all your price hikes fireman591 Vue General 5 05-18-2010 06:05 PM
Can I replace my 01 SL1 CD/Radio with a newer GM Stock radio? SuperCujo S-Series General 46 01-27-2009 10:13 PM
96 SL SOHC radio wire to light on clock/radio turner dddaaa S-Series Tech 1 06-21-2008 04:53 PM
Need factory radio harness/plug for SAAS CD/Cass/FM/AM radio JButler1983 L-Series General 2 12-03-2006 05:48 PM
'05 Radio Wiring Harness for Aftermarket Radio Crawdaddy Ion General 16 05-12-2005 01:33 AM
