Old 09-13-2017, 11:39 AM   #1
dennis1972
dennis1972 is on a distinguished road
2006 VUE 2.2L
Default 2006 saturn vue external fuel filter
I own a 2006 saturn vue with the 2.2 liter, yesterday I went to an auto parts store to pick up some parts, while I was there I got a external fuel filter. Came home raised the suv, put stands under it, I can not for the life of me find the fuel filter, usually on the drivers side rail. Looked both drivers and passengers side. I phoned the Chevy dealer, was told by parts lady she shows no external fuel filter for it. Would like to know who is correct the dealer or the other parts store
Add to dennis1972's Reputation
Rate the quality of this post and help dennis1972 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dennis1972 is offline   Reply With Quote
Old 09-13-2017, 01:23 PM   #2
Chazberry
Chazberry's Avatar
Default Re: 2006 saturn vue external fuel filter
I'm pretty sure all the fuel filters went inside the fuel tank after 2003.
Add to Chazberry's Reputation
Old 09-13-2017, 01:25 PM   #3
Most likely the Chevy dealer parts lady. While I don't have info for '06 Vues, '05 Vues use a saddle fuel tank with a built in fuel filter in the pump module - the filter is in the fuel tank. Normally, external fuel filters are mounted near the fuel tank on either left or right side under open areas of the chassis where fuel lines can pass and conspicuous when looking for it. Since you cannot find anything resembling an external fuel filter, its most likely in the fuel tank. Below are drawings of an '05 fuel tank and fuel pump.
Old 09-16-2017, 08:59 AM   #4
gm7
gm7 will become famous soon enoughgm7 will become famous soon enough
gm7's Avatar
2009 VUE Red Line
Anybody know if there is a service interval for replacing the fuel filter connected to the fuel pump inside the gas tank on a Vue?...like 100k miles?
Anybody change theirs as a matter of preventive maintenance? Hard job?
Thanks
Add to gm7's Reputation
Rate the quality of this post and help gm7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-16-2017, 12:53 PM   #5
None. According to service manuals;
Fuel Strainer
The fuel strainer attaches to the lower end of the primary fuel tank module. The fuel strainer is made of woven plastic. The functions of the fuel strainer are to filter contaminants and to wick fuel. The fuel strainer normally requires no maintenance. Fuel stoppage at this point indicates that the fuel tank contains an abnormal amount of sediment or contamination.
Fuel Filter
The fuel filter (1) is located in the primary fuel tank module. The paper filter element traps particles in the fuel that may damage the fuel injection system. The filter housing is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature.
Old 09-16-2017, 03:03 PM   #6
gm7
gm7's Avatar
2009 VUE Red Line
Thanks fdryer...appreciate it.
2006 Saturn Vue 2.2L AC inline filter? DennisH Vue Tech 4 08-21-2017 12:05 PM
Saturn SC2 with P0171. Replaced Fuel Pump and Fuel Filter. Natelancer S-Series Tech 13 03-16-2017 04:13 PM
2006 Saturn Ion Fuel Pump saturnion2006 Ion General 5 02-25-2014 07:56 PM
2006 Ion 3 Fuel Filter / rust pezcore64 Ion Tech 2 10-17-2011 03:07 AM
External Fuel Pump. Mikey10235 S-Series Tech 2 07-02-2009 08:51 PM
