Old 05-17-2002, 12:02 AM   #1
useffects
useffects is on a distinguished road
Default Loss Of Power
On my Saturn, when braking or when stopped at a red light or stop sign, the lights dim slightly (instrument cluster and headlights), the motors slow down ( HVAC blower and windshield wipers), and when a turn signal is on- the instrument cluster lamps dim in sync with the turn signal. This is a 1999 SL1 with approximately 17,000 miles. This loss of power occurs even without the A/C on. I have read in other posts about the premature failure of alternators on Saturns- but could this be the case at only 17,000 miles? Or, is this a common trait with Saturns? Thanks for any input on my situation.
Add to useffects's Reputation
Rate the quality of this post and help useffects reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
useffects is offline
Old 05-17-2002, 12:30 AM   #2
VentureForth
VentureForth has a spectacular aura aboutVentureForth has a spectacular aura aboutVentureForth has a spectacular aura about
VentureForth's Avatar
2006 ION-3 Sedan
Default
It definitly sounds like an alternator problem, and no it shouldn't be happening at 17,000 miles. Try taking it to the dealer. It's between the two bumpers so it should be coved.
Add to VentureForth's Reputation
Rate the quality of this post and help VentureForth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VentureForth is offline
Old 05-17-2002, 09:16 AM   #3
toeachitsown
toeachitsown is on a distinguished road
Default
youll know for sure if its the alternator if you cant shift out of first or second, or cant pass like 3000 rpm...and then u turn the a/c and everything else you can off...including the headlights ect and it runs normal again... **** sux...ull br drivin and ur power steering goes and everything else too
Add to toeachitsown's Reputation
Rate the quality of this post and help toeachitsown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
toeachitsown is offline
Old 05-17-2002, 09:39 AM   #4
Qlara
Qlara's Avatar
Idea
While the car is idling (after warming up first!), disconnect the Ground Battery Cable connection (Black connector).
Then turn on everything you can find electrical, headlight, AC, HVAC blower, turn signals, defroster blah blah......see if the car die or not.
If not, replace the battery it's weak.
Otherwise, the alternator is not cranking out enough juice.
Add to Qlara's Reputation
Qlara is offline
Old 05-17-2002, 11:10 AM   #5
useffects
Default
Thanks for the replies. Do you think it could be a voltage regulator module or is that built into the alternator? In other words, shouldnt there be a constant smooth source of power regardless if the car is idling or at 2000+ rpms?
Old 05-17-2002, 01:13 PM   #6
VentureForth
2006 ION-3 Sedan
Default
You're right about the voltage regulator. It limits to around 13.8 - 14v. However, it can't produce electricity if the alternator is putting out less than 14.
At lower RPMs, the voltage isn't high enough to charge the battery, so the power flow to the electrical system is still FROM your battery until the RPMs increase. If the battery is weak, then you will notice a 'dimming' effect until your alternator is producing enough power to compensate.
If there was a problem in the voltage regulator, then you would need to replace the entire alternator. The VR is more likely to fail than the coils, but that's how they make their money. I would much rather just replace an offset VR by unscrewing it and clipping it into a wiring harness.
Sigh. Those were the good ol' days.
Old 05-17-2002, 02:29 PM   #7
Qlara
Qlara's Avatar
Roll Eyes
Even just the VR is bad, the whole Alternator still need to be replaced regardless. Thanks for today compact integrational design of car electronics.
Before you are judging the alternator, take the above test first and see if the battery is weak. Most of the time it's the battery in low-mileage cars......
Qlara is offline
Old 05-17-2002, 04:17 PM   #8
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default
Umm, that can blow up the ECU.... I know of a few people on my Beretta sites that have done it.
~D.J.~
OhioVueBoy is offline
Old 05-17-2002, 09:20 PM   #9
Default
The best thing about the battery when the car is running is that it acts much like a giant capacitor for the alt. It absorbs voltage spikes that the alt can produce. So like OhioVueBoy says DON"T disconnect the battery with the engine running.
useffects:
When the lights etc go dim at idle do you have a full electrical load going? The alt does not produce full amperage at idle. So under full load there can be a certain amount of dimming or slowing of electrical devices. If everything comes up ok at higher RPMs then chances are that you are running normal. We don't see that many problems with the newer style (yours) alternators as we did with the old. If you are concerned enough get the charging/battery systems checked out. This will reveal if there is a problem.
"You're right about the voltage regulator. It limits to around 13.8 - 14v. However, it can't produce electricity if the alternator is putting out less than 14."
Unless the alt is producing 0 amps then it is producing electricity. An analogy for the production of DC current is much like water through pipes. If you have flow you have current. It takes extra flow to push up hill, a discharged battery is like trying to go up hill. You need extra umph to get the battery charged. This is why most automotive systems can run well on 12-14 volts. 12 volts from the battery at rest with no charging. 14 volts with the alt going to push the charge into the battery, you can't push the electrons into the battery if they are equal on both sides. As for the RPMs most alternators produce power very nicely at about 2000 RPM but still can and do at idle or high RPM.
Add to ssicarman's Reputation
ssicarman is offline
Old 05-18-2002, 06:05 PM   #10
DarkAngel
DarkAngel is on a distinguished road
DarkAngel's Avatar
Default Is Your Car a Manual Tranny?
I was wondering if your car was a manual transmission because if it was a manual then its normal for the lights to dim when downshifting, or when turning especially when there is a lull on the engine such as the a.c. or head lights. If its not a manual you will want to take a look at the alternator. I've had a friend's alternator go out and it wasn't fun sometimes its not just the alternator but it depends on the car. Hers was a kia, need I say more other than she totaled it twice. And my boyfriends alternator in his mustang went out I think but his engine was already bad and his connecitons were old since it was an 84 so you can see how "way leads on to way" just like Robert Frost in The Road Not Taken. Good Luck and I hope this Helps. Another thing to check would be your connection to the battery and make sure its well connected, you know while your under the hood. It made me late for work one day when the car wouldnt start for that reason....
Add to DarkAngel's Reputation
Rate the quality of this post and help DarkAngel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DarkAngel is offline
Old 05-18-2002, 10:51 PM   #11
useffects
Default
The loss of power occurs at idle with the headlights being the only major load. It will occur without the A/C on and without the blower motor on. Also, on a side note- the dome light flickers sometimes when the vehicle is not running. Yes, this is an Automatic not a manual.
Old 05-19-2002, 08:51 PM   #12
DarkAngel
DarkAngel's Avatar
Default
Sounds like a voltage problem. Probably the voltage regulator or the alternator. Good Luck.
Old 05-20-2002, 08:50 AM   #13
woowoo
woowoo is on a distinguished road
Default
Put a voltmeter across the battery terminals.
Have somebody start the car
It should read
With the car off 12-13 v
Cranking engine 9-12 v
After it starts 13-15 v
Does it read low when its running?
It will slowly go down if the alternator is bad
Add to woowoo's Reputation
Rate the quality of this post and help woowoo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
woowoo is offline
Old 05-20-2002, 09:22 AM   #14
Luke
Luke's Avatar
Default Dome Light flickering
Useffects: The Dome light flickering is most likely due to the micro-switch controlling & sitting on the door frame (when you open the door, the switch pops out) has a buildup of dust/dirt on it. Press it and let it "Pop" out should help in cleaning it out.
Add to Luke's Reputation
Luke is offline
Old 05-20-2002, 01:19 PM   #15
94sc293sl1
94sc293sl1 is on a distinguished road
94sc293sl1's Avatar
1994 SC2
Default
useffects, the symptons you describe sound like the ones I had in March when my alternator went out--dimming lights, wipers slowing, etc. I also had my "anti-lock" light stay on.
But you're right--it does seem early to have an alternator problem, and I thought the problem with alternators had been fixed by 1999.
Craig
Saturn owner no longer as of 12/21/05, sold my SC2.
www.insidetrackmagazine.com
Add to 94sc293sl1's Reputation
Rate the quality of this post and help 94sc293sl1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
94sc293sl1 is offline
power loss The Student S-Series Tech 4 03-16-2009 11:17 AM
loss of power in L4 boomerang86 L-Series Tech 9 08-01-2005 10:05 PM
A/C and power loss Applefool S-Series Mods 26 01-20-2005 09:23 PM
Loss of power THX712517 S-Series Tech 5 05-30-2003 06:34 PM
Power Loss. hotrodSC2 Miscellaneous Tech 2 04-10-2003 11:15 PM
