Old 04-15-2010, 06:03 PM   #1
infinitewisdumb
infinitewisdumb is on a distinguished road
Default Transmission cooler/radiator replacement when transmission is bad?
Hello forum members. Long time troller, first time poster.
I need to repalce my tranny in a 1994 SL2. I had hard shifting and no reverse. After trolling the forum and learning, i replaced teh VB and input shaft nut and still get no love. Just a rattle when in park. No reverse. Looks like its time to swap the tranny. A shop I deal with stated that they will only warrantee the tranny if the radiator is replaced too. Something about metal shavings in the tranny cooler/radiator. Truth? Seems to me a simple flush may do the job, but Im not sure, having never done this before.
Thank you!
Add to infinitewisdumb's Reputation
Rate the quality of this post and help infinitewisdumb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
infinitewisdumb is offline   Reply With Quote
Old 04-15-2010, 10:25 PM   #2
Signmaster
Default Re: Transmission cooler/radiator replacement when transmission is bad?
Sounds like they are trolling to make a bigger job out of things. I've dealt with shops rebuilding trannies to hold big torque and have never heard of them requesting such a thing.
If their prices are good and you trust them, I'd just skip the radiator replacement (unless it's old anyway) and go with an aftermarket tranny cooler. Cheap and easy, and even a small one will cool better than the radiator cooler.
Old 04-16-2010, 08:59 AM   #3
infinitewisdumb
Thanks Signmaster. Thats what I thought too. They said the metal shavings will clog the trans cooler because the cooler lines are so small. I think I will check teh fluid for metal shavings and then see what to do from there. As you suggest, aftermarket coolers are a good idea.
Transmission cooler line replacement? dildog S-Series Tech 29 03-12-2018 11:11 AM
radiator transmission tube (manual; radiator replacement) sw87 S-Series Tech 3 03-27-2010 08:15 PM
S-Series Radiator replacement w/ Transmission Cooler Luke S-Series Tech 14 12-22-2006 12:12 PM
Transmission Fluid flow from Transmission into the radiator ? Luke S-Series Tech 5 11-10-2005 10:52 AM
Wanted: Radiator and transmission fluid cooler lines stevenmara Classifieds 0 10-11-2005 10:01 AM
