Old 09-17-2012, 09:11 AM   #1
RedGeminiPA
RedGeminiPA will become famous soon enough
RedGeminiPA's Avatar
2004 VUE 3.5L
Default Weird sound/feel in Park at idle after driving - 05 3.5
I've noticed this within the last couple of days. After driving for a little while, when I put it in park, it has an odd *feel* at idle in park, and I can hear something that is hard to explain. It's almost like an intermittent grunt sound. The first time it did it was after I started it after sitting for about 15 minutes on Saturday, when we were leaving a friend's house on the way back into town.
When we went to my aunt's for dinner and when we got home yesterday, it was doing it again when I put it in park. I popped the hood to see if I could hear it better, but I couldn't hear it at all, really. It can only be heard from inside.
I'm totally stumped. My buddy looked at the mounts a little while back, and he said they all looked good. None looked smashed from the dealer dropping the tranny. We also did the brake/gas torque check to see if there were any odd excessive movements of the engine under load. All looked normal, and we used my '04 as reference.
I should note that I had just got back into town after a 300 mile round trip Saturday. I got gas at the station I always buy from, and I've never had any issues with their gas. I didn't notice this behavior during the trip.
I've also noticed some roughness/shaking when starting and shutting off for about a month or so, maybe a little longer.
No MIL lights. 124k on it. Prop shaft is still out of it.
Any ideas or help is greatly appreciated.
I'm uploading a video now of startup. You probably won't be able to tell the rough starting. I'll post the link as soon as it finishes uploading.
Avid Apple, car and vacuum enthusiast. Don't hate! ;)
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
http://www.facebook.com/SaturnFansNorthEast
Add to RedGeminiPA's Reputation
Rate the quality of this post and help RedGeminiPA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedGeminiPA is offline   Reply With Quote
Old 09-17-2012, 09:42 AM   #2
RedGeminiPA
2004 VUE 3.5L
Default Re: Weird sound/feel in Park at idle after driving - 05 3.5
I'm having trouble uploading. I'll work on it when I get home this afternoon.
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Old 09-17-2012, 09:56 AM   #3
far2grumpy
far2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to all
far2grumpy's Avatar
I'll offer an off-the-wall thought.
One thing that happens periodically - when engine is at operating temperature - is EVAP purge valve activates to slurp stored fuel tank vapors from the carbon canister.
You probably should not notice on a V6 if the valve opens and closes correctly. However, if the valve is leaking - the engine could idle rough and may make an unusual noise when manifold vacuum changes with the pruge cycle.
Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
Old 09-17-2012, 12:53 PM   #4
RedGeminiPA
2004 VUE 3.5L
That makes sense. It would explain why I can hear it inside (above/behind exhaust/manifold) and not really under the hood. Any way to know for sure? Is there anything I can do to rule it out, or confirm it, or fix it?
Here's the video, though this isn't really the problem/sound. This is just startup.
http://www.youtube.com/watch?v=lfi_pryYz40
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Old 09-17-2012, 01:27 PM   #5
far2grumpy
far2grumpy's Avatar
Since its just between us ... I'd wait until the issue is happening and then try - temporarily - pinching-off the hose between manifold and purge valve.
I used a hemostat to demonstrate. You could also squeeze right at the manifold exit-port or temporarily remove the tubing from the manifold (plug hole of course).
Old 09-18-2012, 12:36 PM   #6
RedGeminiPA
2004 VUE 3.5L
I haven't had a chance to try this yet... I gotta get a hemostat.
I'm curious... if this does do the trick, what's the next step?
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Old 09-18-2012, 02:15 PM   #7
far2grumpy
far2grumpy's Avatar
If poor idle is an issue - and purge valve is the culprit - you could swap it.
If the noise is the only bother I could learn to live with it (new valve at RockAuto is $112 - gulp).
Old 09-18-2012, 07:20 PM   #8
RedGeminiPA
2004 VUE 3.5L
Ouch... well... I kinda hope that's the problem, but I kinda don't. Know what I mean? At least I'd know what it is.
I'm going to see if I can find a hemostat tomorrow and give it a try.
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Old 09-18-2012, 09:22 PM   #9
far2grumpy
far2grumpy's Avatar
You could use needle nose pliers or even vise-grips. The goal is to pinch the hose while the flaky idle and/or noise is occurring. The noise should cease almost instantly once the hose is crimped.
If it does not stop - we can consider plan B (EGR valve), or plan C (pcv valve).
Old 09-18-2012, 09:49 PM   #10
RedGeminiPA
2004 VUE 3.5L
Okey dokey. Now, THAT I can do. I'll get my other half to squeeze it while I sit inside and listen.
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Old 09-27-2012, 09:03 AM   #11
RedGeminiPA
2004 VUE 3.5L
So, yesterday, I was pulling down the driveway, and stopped at the bottom (downhill). I put it in Park, and lifted my foot off the brake. I normally pull the parking brake when on a hill, but kinda forgot this time. When I pulled it out of Park, it made one hell of a bang, and the whole thing shook.
Should I maybe be looking at an engine/transmission mount? Could that be the source of this whole issue?
I got to thinking about something. Before I bought my Red Line, I was talking to a guy who had one for sale in NJ (an '04). One thing he noted was an odd, intermittent, vibration at idle. He said he was told it needed a mount, but never got around to having it investigated further.
I can easily see the one on the passenger side and bottom front on the crossmember. Where are the others located so I can attempt to check them?
Is there a good way to test them, maybe using the engine torque method? Would Reverse be more prominent that Drive? I've also noticed it feels a little rougher when in Reverse - accelerating.
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
weird buzzing driving me crazy! sattyluvr S-Series General 2 11-03-2010 10:33 PM
1999 SL1 weird noise while driving fieldguy73 S-Series Tech 3 05-28-2010 11:56 PM
Weird Sound while driving Wifey's Ride S-Series General 16 04-16-2008 09:04 PM
Pinging sound when in park virtualryan Vue Tech 1 08-25-2007 08:19 AM
