Old 11-09-2018, 03:38 PM   #1
claybear
claybear will become famous soon enough
2002 L-Series 2.2L Wagon
Default Brake Line Diagram?
Hi all
I'm making new brake lines for my 2002 LW200 from the firewall back by copying the originals as closely as I can. Unfortunately, I didn't mark which line hooked up to each of the lines on the firewall before I took them out. I may be able to figure it out by finding another L series car and comparing or by tracing from the master cylinder through the ABS box to the firewall connection. But, if anyone has a diagram or could take a picture of the lines at the firewall and note which one goes to the driver rear and which one goes to the passenger rear, I could save some time. Thanks in advance.
Add to claybear's Reputation
Rate the quality of this post and help claybear reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
claybear is offline   Reply With Quote
Old 11-09-2018, 08:36 PM   #2
GregS&L
GregS&L is a jewel in the roughGregS&L is a jewel in the roughGregS&L is a jewel in the rough
GregS&L's Avatar
2001 L-Series 3.0L Sedan
Default Re: Brake Line Diagram?
The attached from the FSM may assist you. You may need to blow it up a bit to see the individual lines better.
This past summer one brake line going to the rear brakes sprung a pinhole leak. It was heavily rusted around the middle part of the car.
My friend who manages a busy indi repair shop (with 3 lifts) replaced both rear brake lines for me. He had problems duplicating the long line going to the driver side rear brake. That line was originally routed over the fuel tank. He said he could not reach the original brake line clamps without dropping the tank, so he routed the new line around the fuel tank. You could possibly run into this issue.
Add to GregS&L's Reputation
Rate the quality of this post and help GregS&L reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GregS&L is offline   Reply With Quote
Old 11-09-2018, 10:55 PM   #3
claybear
Thanks Greg.
The reason I am replacing the lines is that the fuel pump sprung a leak and I had to drop the tank. When I saw the brake lines I knew I had to replace them and when I started to remove them I knew that I had made the right decision. I've been bending up the long lines tonight. Kind of fun but tricky, as you might imagine. Thanks for the diagram.
Old 11-10-2018, 12:55 PM   #4
MerrittK54
MerrittK54 will become famous soon enough
MerrittK54's Avatar
2009 VUE 2.4L
2009 AURA XR
Claybear, I'm doing the same thing on my 2002 L200. Nearly had an accident yesterday when one of my brake lines ruptured during hard braking. Fortunately I was able to stop. but had no braking power after that. A friend of my hauled it home for me.
Now I have both rear brake lines removed from the car. Both were severely corroded. Surprised they lasted this long. I'm going to replace them with Nicopp. Hopefully, Advance Auto has new fittings as well. I will need to bypass the old line going to around the fuel tank to the LH rear brake as GregS&L pointed out. I should be able to route the RH brake line nearly the same as the original.
I've never done this before, so I'm taking my time and thinking things through. I'll let you know how it turns out.
-Merrittk54
2009 Aura XR 2.4L (Wife's)
2009 Vue XE 2.4L(Mine)
2002 L200 (Daughter's)
Add to MerrittK54's Reputation
Rate the quality of this post and help MerrittK54 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MerrittK54 is offline   Reply With Quote
Old 11-11-2018, 07:00 PM   #5
MerrittK54
MerrittK54's Avatar
2009 VUE 2.4L
2009 AURA XR
Didn't mean to hijack this thread, but I promised an update. I was able to remove (read that "tear out") the old rear brake lines in my L200. Kept 3 of the 4 end fittings, the 4th was corroded beyond use. Made new brake lines out of Nicopp. Although very strenuous, not really too bad. I bled the rear brakes with a pressure bleeder and now I have solid pedal with no leaks. As a precaution, I'm going to bleed the front brakes.
Claybear, I hope your project is going well. I've made a number of repairs over the years, but I've never made my own brake lines. Gotta keep this car going for a little while longer!
Old 11-12-2018, 06:27 PM   #6
claybear
I have all the lines bent up and have flared and installed the two that are on the rear trailing arms. All went smoothly so far. I'm still trying to figure out which connector on the firewall goes to the driver side rear by trying to find an port output diagram of the ABS module. Without seeing the internals I just can't tell. I will post pictures as I get the lines in and also when I figure out the correct hookups. I knew I was in too much of a rush when removing them . . .
Old 11-14-2018, 08:27 PM   #7
soulsurvives
soulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to all
If you look at your abs module you will se RR and LR. I believe that stands for right rear and left rear.
Old 11-15-2018, 01:50 AM   #8
You can be confident, soulsurvives! You've correctly identified what RR and LR stand for here. I saw this when working for my father at his service station and in various auto parts catalogs over the years.
304,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 11-16-2018, 02:43 PM   #9
claybear
Thank you so much. I should have cleaned off my module and looked a bit harder. Plan on installing the lines tonight.
I've attached a picture of the tools I used for bending the lines and a couple of the lines themselves.
Old 11-17-2018, 12:49 PM   #10
claybear
Hey all, need a little help again. Connecting the rear ABS sensors and realized that once again I forgot to note which side goes to the driver's side. Need to see a wiring diagram with wire colors to get it correct. One pair is Red and Black and the other is White and Brown. Anyone have a schematic/diagram?
Old 11-18-2018, 10:55 PM   #11
claybear
Update on brakes. Attached images show left side rear and two from the right side rear. Sensor harness is now correct and wire tied to line - all the original clips were distorted from age and didn't clip well onto brake line tubing.
Edit: can't get the left side photo to upload.
Old 11-19-2018, 07:10 PM   #12
claybear
left rear
Old 11-27-2018, 01:28 PM   #13
claybear
Almost everything is complete now. The car is back on the road ad safe. I plan on reverse modeling and 3D printing a few of the fuel/brake line 'looms' that hold and separate them as they run under the car. Some broke as they were removed and I think that it would be good to have them all in place. I will post a link for the parts once I have some printed and tested. Shapeways is probably the site that I will use as I have used them in the past and my guess is that I will print the parts from nylon.
Old 11-27-2018, 01:52 PM   #14
What were you intending for the viewer to see specifically, if that was your intention, from the picture of the underside of the car?
Vacuum line diagram? flyhop S-Series Tech 1 12-28-2016 12:23 PM
Can someone show me the vacuum line diagram on top of the L300 engine? Farmboyethan18 L-Series General 3 12-04-2014 11:30 PM
Saturn ion2 4dr need brake line diagram ken121858 Ion General 3 04-06-2014 08:25 PM
Anyone have an AC System Line Diagram for a L300? thepat L-Series Tech 2 06-30-2013 06:55 PM
brake lines diagram echostar S-Series Tech 1 04-28-2012 12:52 AM
