Old 07-31-2020, 05:31 PM   #1
cam
cam is on a distinguished road
cam's Avatar
2007 VUE 2.2L
2007 ION-3 Sedan
Default Moisture in plastic headlamp assembly unit
Hello all. I had this posted in the ION TECH section but no replies there so trying it here. As indicated we have a 2007 ION 3 and I've only noticed moisture accumulation one other time in the front passenger side lens. The driver's side is bone dry. I can't recall what I did last time it happened because it was so long ago. It occurred as a result of driving for approximately an hour or so in torrential rain. Is there anything I can do to resolve it? I am concerned about a possible electrical problem. Has anyone else experienced this problem and does it go away on it's own.
Thank you all..Love those Saturns!!
cam is offline   Reply With Quote
Old 08-04-2020, 03:40 PM   #2
ddemier7
ddemier7 will become famous soon enoughddemier7 will become famous soon enough
ddemier7's Avatar
2004 ION-1 Sedan
Thumbs Up Re: Moisture in plastic headlamp assembly unit
Best thing to do is remove the housing (super easy to do) and remove both light bulbs and stick a fan in front where the light bulbs twist into. That will force the humidity out of the housing and you are good to go. Leave the fan on overnight. .
Old 08-05-2020, 09:58 AM   #3
sc2 saturn
sc2 saturn will become famous soon enough
Default Re: Moisture in plastic headlamp assembly unit
i would take headlight off u can use a fan but i left my headlight overnight with all bulbs out and it got moisture out and i used clear silicone and put it around lens where it seals and never had a issue since fixed lots of different models and brands of vehicles to
sc2 saturn is offline   Reply With Quote
moisture in head lamp assembly cam Ion Tech 0 07-30-2020 08:16 PM
pop-up headlamp assembly diagram VUEmaniac S-Series Tech 4 09-12-2010 07:00 PM
01 SL2 headlamp assembly removal shanecrow99 S-Series Tech 2 08-23-2010 04:51 PM
How do I replace the Headlamp assembly in a 2001 SC2? Usumgal S-Series Tech 16 01-19-2010 03:56 PM
Hella H4 Headlamp Conversion Unit David 93 SL2m Mods and Performance 15 04-04-2003 04:58 PM
