Old 06-02-2011, 10:24 PM   #1
scottt
scottt is on a distinguished road
Default 99 SL2 stutter
Yesterday my sl2 began stuttering when I would give it the slightest throttle. It is to the point where I can't go over 10 mph. I put quarters under the egr with no change. Today I unscrewed the front oxygen sensor without unplugging it and saw no change for about 5 minutes, then it ran much better. Not perfect but much better. I would think the sensor would do the trick, but don't know since it took a few minutes. I don't want to buy a sensor if it's not needed. Thanks.
Add to scottt's Reputation
Rate the quality of this post and help scottt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scottt is offline   Reply With Quote
Old 06-02-2011, 10:46 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: 99 SL2 stutter
Bang on your cataclyctic converter and listen for a bunch of rocks in there. If so, there ya go. Alternatively you can check for a glowing red cat and/or exhaust while the car is running..
Old 06-03-2011, 05:10 PM   #3
scottt
I'll try that this evening. Unfortunately I'm only able to work on the car an hour each day so this may take a while. Any thoughts on why it ran smoother after about 5 minutes? Does the computer take a while to get used to the oxygen sensor being removed?
Old 06-03-2011, 07:00 PM   #4
adventureoflink
by removing the front O2 sensor, you're basically creating a bung-hole for the car exhaust gases to escape, thereby allowing a power restoration.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 06-03-2011, 09:56 PM   #5
scottt
Default
The cat didn't rattle and the exhaust wasn't red hot, just the stumbling with any throttle. I bought the car about six months ago and there has always been a strong gas smell if that helps.
Old 06-04-2011, 07:48 PM   #6
jhonky
jhonky is on a distinguished road
sounds like the cat con to me
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
Add to jhonky's Reputation
Rate the quality of this post and help jhonky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhonky is offline   Reply With Quote
Old 06-04-2011, 10:03 PM   #7
scottt
How can I check this without paying a lot for a new cat? I banged on the cat and didn't hear the rattle adventureoflink mentioned. I've read a lot of post here and just don't know where to look next.
Old 06-04-2011, 10:55 PM   #8
ehunter
Location: Pacifica by San Francisco – 5sp – Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
Sign up under Bob Stoops as punter for the Sooners. Soon enough a booster at the dealership will give you a CAT for washing his hubcaps. Then just quit the team. You could have done the same in Columbus except the party is over there now… All the other teams just have not got caught yet.
Add to ehunter's Reputation
Old 06-05-2011, 01:56 PM   #9
scottt
Default
I think ehunter is onto something. I just need to convince them to give me a cat before they see me punt!
This morning I removed the quarters from the egr and reinstalled the oxygen sensor. The car ran great for about a minute and then back to stumbling with any throttle. Just wanted to give an update in case any of this helps.
Old 06-05-2011, 02:09 PM   #10
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
Check your fuel injectors and your fuel pressure. You can rent or purchase a cheap fuel pressure tester. Also, the problem should correct itself instantly if you remove the O2 sensor, which leads me to believe it's not your cat!
cheap pressure tester:
http://www.harborfreight.com/fuel-in...ter-92699.html
You can also test fuel pressure by turning the key on (but not starting it). You'll hear the fuel pump buzz while building pressure then turn off. This lasts a couple seconds. You then turn the key back off and go find the schrader valve before the fuel rail/injectors and push in on the schrader pin. Fuel should spray everywhere as the pressure is released. If you get a small dribble I would replace your fuel filter and go from there.
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 06-06-2011, 01:44 AM   #11
scottt
I got a code reader from my father in law and got a 0134 and 0300. This was just after removing the quarters from the egr and reinstalling the front oxygen sensor. The engine was cold when the codes were read. Since I thought the 0134 was from having the sensor removed, I disconnected the battery to reset the codes and drove the car for about 20 minutes. The car had the same stumbling at first but after about 15 minutes it ran great with no hesitation. I read the codes again and now I'm getting a 0302. I found these thing to try in another post:
Possible things to try:
* remove the #2 spark plug, inspect, and report back what you find
* replace the spark plugs, if they haven't been done in a while
* replace that spark plug wire, or all wires, if they're old
* swap the coil packs - if it switches to a P0304, suspect that coil pack
* swap the #2 injector with another, to see if the problem "moves"
* compression test -- see if #2 is lower/higher than the others
Does this look correct? Again, this issue started suddenly, one day the car just wouldn't allow any acceleration. Thanks
Old 06-06-2011, 02:53 AM   #12
MacG
MacG is on a distinguished road
1992 SL2
I don't know about the codes (or The Code, for tha matter ) but I have heard of a muffler baffle collapsing. I have alocal muffler shop (not a chain) that will help diagnose by checking the flow through the muffler while on the car. They check the cat the same way.
Good Luck.
Add to MacG's Reputation
Rate the quality of this post and help MacG reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MacG is offline   Reply With Quote
Old 06-07-2011, 12:26 AM   #13
scottt
I'm starting a new thread after seeing the poor results from a compression test. Test results: 140 0 80 0
The original issue is no longer my problem. Whether to keep the car is now the issue.
Old 06-07-2011, 01:38 PM   #14
ehunter
I feel for you brother...
Brake Stutter? SL2 latestgood S-Series Tech 7 12-23-2008 11:50 AM
stutter and stalling janay3 S-Series Tech 0 04-17-2008 11:05 PM
98 SL1 stutter Imagyne S-Series Tech 2 01-25-2008 07:04 PM
stutter DHOOP S-Series General 3 02-12-2006 02:41 PM
stutter in 4th gear chrislk02 S-Series Tech 2 07-11-2002 10:03 PM
