Old 11-26-2019, 12:55 PM   #101
trottida
trottida's Avatar
Default Re: Well darn, my '99 SL2 laps oil like a BMW
Originally Posted by cantom View Post
Okay. It is the valve cover gasket. Leaking like a good thing. I paid to get it done a year ago but will not be going back there again. They also used a fair bit of black RTV...a very sloppy job. I hope they even put a new gasket in.
I just watched a video on youtube on replacing the gasket and 2 grommets. Simple enough but...did I read on here that the OEM covers warp and cause leaking?
Someone suggested getting the cast cover from an earlier Saturn because it's less likely to warp?
This is a 2001 SL1 SOHC.
Likely that I need to source a different cover?
I wonder if someone has one of the good covers they'd sell and ship reasonably?
PCV valve rattles and is like new.
I see you specified SOHC (2001 SL1).
I believe the warped covers affect only the DOHC engine and specifically 95-98 (maybe 94) where they were made of composite rather than aluminum. You can put an aluminum from an earlier model on to resolve. The 99-02 DOHC used composite as well an you cannot use an earlier model as the head changed to the narrow head. If I recall they aren't an issue like the 95-98's as far as warping goes.
The SOHC on the other hand had aluminum valve covers throughout its entire run 91-02.
<< you may want to update your profile to add the 2001 SL1 so others don't think you are talking about the 99 SL2. Look in the left sidebar of your posts.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
trottida is online now   Reply With Quote
Old 11-27-2019, 12:38 PM   #102
This is a how to written by a (at the time) trained Saturn tech
http://www.saturnfans.com/forums/showthread.php?t=26532
At one point, apparently there was no gasket for SOHC engines and they used RTV only, but since then a gasket became available.
Instead of Brake Kleen, I'd use something that member OldNuc recommended - plain acetone ($3 or so at Walmart, in the nail polish section - make sure is unscented, no stuff added, etc) for cleaning the surfaces
Aluminum, as trottida mentioned. Although it will not warp, if there is a chance it has been dropped or something, you can place it on a perfectly flat surface and move it around, looking for gaps in contact
Note that several people say that the book spec for torque is too tight (resulting in snapped bolts) and suggest a lower value
http://www.saturnfans.com/forums/sho...d.php?t=222157
edit: I've also never washed the inside of the covers when doing this. I guess I am not that particular, or my covers weren't that dirty? Though wiping / scraping off big chunks isn't a bad idea
Old 11-30-2019, 03:15 PM   #103
cantom
cantom is a jewel in the roughcantom is a jewel in the roughcantom is a jewel in the rough
Ah, okay, originally no gasket?
At any rate, apparently using a Fel Pro blue gasket, the job was done yesterday by my local shop and I see no sign of leaking. Maybe I can stop adding oil now...I hope.
2001 SL1 SOHC
Canada
cantom is offline   Reply With Quote
Old 12-02-2019, 09:57 AM   #104
Correct, from what I have read - no gasket originally. But apparently, removing the cam cover was a real PITA because of the RTV - involving razors, prying, hoping nothing cracks, and cussing.
Good news that it seems to have fixed the worse leak, thanks for the followup. Keep an eye on the oil level, though - AFAIK, I have no leaks and I am adding 6~9 oz of oil a week (about 250 miles hwy) to keep it slightly above the FULL mark on the dipstick
Old 12-02-2019, 03:22 PM   #105
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
You are filling to just above FULL or just above the hashmarks?
1999 SL2 A4 -92k miles
Currently sipping Valvoline NextGen HM 10w-30
TCW3 dosed fuel
1993 SL2 SOLD @189k
NWSaturn247 is offline   Reply With Quote
Old 12-02-2019, 03:53 PM   #106
Whoops, I phrased that poorly. Just above the hashmarks, around the "U" in the word FULL
By the time I check the next week, I am usually back down to the top of the hashmarks, maybe one diamond below
Not my pic, but this is what I am calling the FULL mark
Old 12-02-2019, 05:13 PM   #107
NWSaturn247
Thank you for the clarification. For the record, I often topped off my oil to FULL on my '93. Did not seem to be an issue to the day I sold it at 189k miles
The first person to see and test drive it, purchased it
She drove it quite aggressively putting the car through a torture test. SOLD LOL
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 12-02-2019, 07:40 PM   #108
Pitcher
Pitcher's Avatar
I always fill to the "U" or 1st "L" of FULL on all 4 of
my S-Series for the past several years. Zero issues.
BTW I can hear when it's down to the 2nd or 3rd
crosshatch; engine sounds slightly more "raw".
Owned 4 other S-Series.
Old 07-30-2020, 03:22 AM   #109
NWSaturn247
So into this OCI with Delvac Super, consumption is about 1350-1400 miles per quart. Small improvement. Soon, I will perform a soak and valve cover gasket procedure, and install some NGK G-Power plugs.
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 07-30-2020, 07:06 AM   #110
cantom
The Blue Gasket is excellent and stopped any oil leak from the cover.
Now, my 2001 SL1 continues to use oil...I drive it a lot.
So, because oil has gotten so expensive in the last few years, I look for a jug of the cheapest I can find now...and it's 10W30 lately.
Funny thing is, the consumption has decreased using 10W30. Last couple of times I was surprised to see the level not down much. Cool.
BTW, as for Saturns around here...they are about gone. I haven't seen another one for a while to be truthful. I'm the only holdout.
2001 SL1 SOHC
Canada
Old 08-30-2020, 08:09 PM   #111
NWSaturn247
Seems the HDEO is slowly cleaning up the pistons. Looks like about 1500 miles per quart now.
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 10-22-2020, 01:37 AM   #112
NWSaturn247
Re@ ~3250 into the OCI which received 2 quarts of top-off, I performed a daring experiment (replicate at your own risk) I sprayed small amounts of Chemtool into the valve cover via the PCV port before each drive until the can was empty. This I am sure, thoroughly cleaned the PCV system passageways and served as a budget kreen treatment for the engine.
Then I finally performed a piston soak.
Step 1, I added 2 ounces of Chemtool B12 to each cylinder, engine slightly warm. I let it soak overnight.
Next day, 2,3,4 were drained. 1 had a little still on top, pumped it out and then filled each cylinder with 2 ounces of Rislone Engine Treatment pn100QR
After 3+ hours, with pcm-b fuse removed, cranked the engine several times, then sopped up more with folded papers.
Chemtool and follow up Rislone cleaned up the piston tops darn good.
Now the sump had quite a powerful brew! Maybe I should have drained the oil first, but no, I started the engine, with a few long cranks then pressing foot to floor for clear flood mode. Varooom. Right up the ramps, run to the back to admire the smoke show, then shut it down, less than a minute. The oil that came out was quite rich and creamy. Also smokey steam was wafting out the drain hole. Weird science.
So I decided to leave the filter on, and refill with Mobil Super and a bit of Rislone for a one day OCI for more flushing.
The next day I drained the oil and it was fairly dark.
Refilled with Valvoline MaxLife NextGen high mileage and a Napa Gold 1516
305 miles later, engine is purring, perfect idle, no buzz at all at traffic lights.
Too early to be sure but doesn't seem to have used any oil yet. Fingers crossed.
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 10-22-2020, 09:02 PM   #113
Pitcher
Pitcher's Avatar
Well laid out testing, thank you!!
Darn it, Saturn, you've done it again :) dulino Vue General 5 11-12-2007 01:42 PM
cant get the darn air box out !! blazer Ion Mods 8 08-06-2007 11:32 PM
Texas Motor Speedway Laps for Charity Dante Events 0 05-09-2006 09:50 PM
Vue Red Line doing laps at the TX Motor Speedway Dante Vue Red Line 9 11-08-2004 03:49 PM
Darn cat SpiderWebb Ion General 23 01-23-2004 05:38 PM
