Old 11-01-2016, 04:08 PM   #1
deca5423
deca5423 will become famous soon enoughdeca5423 will become famous soon enough
2004 VUE Red Line
2006 ION-2 Quad Coupe
Default Saturn ion manual - awkward 3rd and 4th shifts
2006 2.2 manual
Not really sure where to start with this one.
1. 3rd and 4th gear are noticeably 'notchy'. No grinding just not as smooth as it used to be with a very noticeable 'click' engagement. 1st, 2nd, and 5th are fine.
2. If I take the shifter out of 1st, 2nd, or 5th gear it doesn't naturally center anymore. So if i pull it out of 1st it will stay more to the left pointing towards me instead of centering and being straight up. I noticed this oddity soon after the notchy shifting.
The transmission fluid had been changed at 102k or so with GM manual transmission fluid 88861800. Around 103k I started noticing notchy shifts in 3rd and 4th. Now at at 104k and it's annoying me more. Fluid level is good.
deca5423 is offline   Reply With Quote
Old 11-01-2016, 07:46 PM   #2
Default Re: Saturn ion manual - awkward 3rd and 4th shifts
Transmission fluid is for lubricating all moving parts and have no real effect on shift feel in general. Mechanically, manual xmissions last almost forever with reasonable care. Wear items; xmission shift cables, linkages and plastic used in some shift mechanisms for the shift lever. External wear to manual xmissions; clutch disc, throwout bearing, pressure plate and clutch hydraulics (master/slave unit).
Manual tranny only shifts with engine off! papayamon2 S-Series Tech 4 05-19-2013 10:04 PM
Manual only shifts 1st, 3rd, 5th aaron95sl2 S-Series General 8 02-08-2012 10:26 PM
97 SL1 Transmission shifts rough when starting slow but it shifts smooth when startin foo S-Series Tech 20 07-30-2008 02:00 PM
awkward startup EvilCody S-Series General 4 03-29-2005 10:28 PM
Awkward stutter EvilCody S-Series General 4 11-29-2004 08:34 PM
