Old 03-11-2020, 10:51 PM   #1
Astrofarian
Astrofarian is on a distinguished road
Default HP ignition wires?
I am looking for a link or a part # for something similar to Accel's 8.8mm wires....but there's a catch. I want YELLOW wires (my car is yellow). Anyone got some info for me?
-M!ke-
Astrofarian is offline   Reply With Quote
Old 03-12-2020, 01:05 PM   #2
toggenburg
toggenburg's Avatar
Default Re: HP ignition wires?
Do you mean something like these?
https://www.ebay.com/itm/Accel-Spark...EAAOSwWspbNFJi
These are for an 8 cylinder GM 305 CI engine, so maybe you will find 4 in the set that can match up with the saturn plug lengths?
Or you will have several extra ones leftover.
Old 03-13-2020, 07:47 AM   #3
Astrofarian
Yes, and thanks Toggenburg. BUT....the only thing that was holding me back from pulling the trigger on those was that I wanted to be sure that the plug boots would fit down into the "Tunnels" in the cam cover on my DOHC 1.9L.
Has anyone done anything like this and which wire set did you use? My car is almost 20 years old...I CAN'T be the first person who wanted to do something like this?
-M!ke-
Old 03-13-2020, 08:58 AM   #4
toggenburg
toggenburg's Avatar
Well, if anything, these appear to have an even smaller diameter than the plug boots on my 98 SW2 and the 2001 SW1 cam cover.
Old 03-13-2020, 09:26 PM   #5
Astrofarian
OK, thanks again. This wire looks like it just might work for me. I just need to get to a speed shop and bribe the counter guy into opening a box of SBC-wires lol. I'm still hoping to hear from someone who's done this mod.
-M!ke-
(pronounced "MIKE!!!")
Old 03-13-2020, 11:45 PM   #6
I'm not sure where the problem is.
https://www.amazon.com/dp/B07BLQGXF2/
Cut to length & reuse the stock boots into the valve cover.
If you have to have the Accel brand, they're about $10 more on Amazon than the ones I linked to.
Old 03-14-2020, 12:18 AM   #7
Astrofarian
I don't know that there IS a "problem". I was simply looking for an answer to a question.
Thanks for the link, I may end up going with the "Super Stock" set, I was really wanting to go with the 8.8mm (heavier) wire but it's probably overkill. Planning to do plugs again in a week or so and hoped to do this as a "one and done" scenario. One of the plug boots on the existing set is damaged at the top...son-in-law isn't very patient with stuff that isn't made of wood lol.
-M!ke-
Old 03-31-2020, 05:18 PM   #8
Saturn Night
-M!ke-
Granatelli Motorsports makes an 8mm wire with 0-ohm/ft of resistance. You don't get to choose color and they cost close to $90. They work great. I averaged 35mpg with automatic and my oil guzzling twin cam.
Old 03-31-2020, 06:49 PM   #9
laser3kw
laser3kw will become famous soon enough
2000 SC1
I got Granatelli's for my 2000 SC1 from Jeg's. Actually Jeg's just drop ships from Granatelli's and does not stock very part number. Took almost three weeks to get (not Jeg's fault), mine were blue color and fit very well - even worked with the stock plug wire clips.
laser3kw is offline   Reply With Quote
Old 03-31-2020, 09:47 PM   #10
sc2 saturn
sc2 saturn will become famous soon enough
https://www.ebay.ca/itm/Yellow-High-...kAAOSwNIpcktMk
there is one that i seen on ebay that is yellow or you can get some other plugs that aren't yellow buy some high temp tape and tape the wires yellow to match
sc2 saturn is offline   Reply With Quote
Old 03-31-2020, 11:04 PM   #11
Zeebins
Zeebins's Avatar
I've got those same ones, just in red. They seem to work well. They are kinda pricey, but the boot does slide to adjust to fit the plastic or aluminum valve cover, so that's nice.
97 SL2, auto, 118K miles
Zeebins is online now   Reply With Quote
Old 04-01-2020, 12:06 AM   #12
Waiex191
Waiex191's Avatar
Zero ohms/foot is pretty awesome. We should be using them for electric transmission lines.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 04-01-2020, 03:38 AM   #13
sc2 saturn
i used Belden Max there 170ohm wire wound core 5mm but there lifetime warranty for the life of the motor well worth the 45$ ish i spent
Old 04-06-2020, 09:23 AM   #14
Astrofarian
Thank you, everyone, for the replies and information. I'm still on the fence as to how I'm going to go ahead with this....I will update this thread once I move forward with this. Thanks again, All!
Stay Healthy-Stay Safe!
-M!ke-
Ignition wires MeMongo66 S-Series General 2 06-06-2013 10:12 AM
About those Magnacore ignition wires ... John Head S-Series Tech 4 03-16-2011 09:52 AM
Ignition wires, again Tom of Detroit S-Series Tech 4 11-16-2009 09:52 PM
Ignition Wires? richpor S-Series Tech 4 06-22-2007 07:41 PM
ignition wires chulo Mods and Performance 1 05-14-2001 10:12 PM
