Old 03-08-2020, 05:07 PM   #1
Hiisi
Hiisi is on a distinguished road
Hiisi's Avatar
Default Alignment Shim - minus what degrees?
Please see the screenshot. Which one do I choose as a passionate driver?
Hiisi is offline   Reply With Quote
Old 03-08-2020, 05:25 PM   #2
Default Re: Alignment Shim - minus what degrees?
There's nothing on the S-Series that those will do anything useful for. Get the bolts, those will actually do something.
Old 03-09-2020, 04:36 AM   #3
Hiisi
Hiisi's Avatar
What bolts?
I have ordered MCQUAY-NORRIS AA2940Rear; Up To Plus / Minus 1 Degree Toe
Old 03-09-2020, 09:25 AM   #4
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by Hiisi View Post
What bolts?
I think fetchitfido was thinking “camber”.
In my opinion, buy a bunch. Get the small ones and stack them if needed.
Check the “track” of the car: Push the car over a big sheet of paper that you’ve taped to the driveway. On the paper, using a pencil and small carpenter’s square, mark the edges of the tires. Verify that the front and rear wheels follow each other...
Dire warning: You will never find driving joy if your tires are not round.
Old 03-09-2020, 10:47 AM   #5
Front & Rear camber use bolts, rear toe use's bolts. What are the shims good for then? These aren't useless Toyota's that need shims sandwiched between the bearing face and hub to change the alignment which requires a new bearing every single time you need an alignment change.
If the track is off...unbolt the offending sub-frame and slide it whichever way it needs to go.
Old 03-09-2020, 03:49 PM   #6
lrbraner
lrbraner is on a distinguished road
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
What alignment issue are you trying to correct ?
Old 03-09-2020, 04:38 PM   #7
Hiisi
Hiisi's Avatar
None. I'm planning a complete suspension rebuild. Bought EVERYTHING new. Thought those things are to be installed by default. Seems they are not. Everyone, thanks for your answers.
alignment shim
Pep Boys Claim I need $400 Shim Package For Alignment- Legit sgoti S-Series General 48 06-14-2013 03:49 PM
OT, Buick alignment shim source? sdowney717 S-Series Tech 1 06-30-2010 09:06 PM
World minus 1 SW2 - Part 2 john95SW2 S-Series General 1 09-30-2007 03:19 PM
World minus 1 SW2 john95SW2 S-Series General 17 09-29-2007 12:07 AM
Shim Kit Diago L-Series General 8 03-28-2003 01:00 AM
