#1 | ||||
![]() I've had my Delphi pump assembly for 6 months now and its not impressive. Now its indicating full fuel down to the first 1/2 of the tank and its leaking down immediately. If I plug the rail I see the pump pressure drop off to zero within a second of the pump shutting off. It makes starting annoying.
I know there are a lot of bad quality pumps out there and I really don't want to get stranded 100 miles from home so I'm looking for a quality pump. I"ve had good luck with Delphi's in the past. So should I roll the dice on another Delphi or go with the Spectra. I see Spectra is a favorite on Rockauto. -Robert
#2 | ||||
![]() I'd review old threads here for advice on brands. I seem to recall that Carter and/or Airtex were the preferred brands for reliable/properly inspected fuel pumps.
On other parts like radiator replacements, Spectra's reputation has been mixed. And Delphi has been eroding its reputation as a lowest-bid part reboxer.
#3 | ||||
![]() Carter ONLY, avoid all the rest -- junk
#4 | ||||
![]() Thanks, OldNuc! Redoing a fuel pump because of crappy replacement parts would have to be one of the worst!
#5 | ||||
![]() Put the Carter in this weekend. Issues seem to be resolved. Car starts up right away after sitting. Of course the Delphi pump worked well for 6 months too though. I did notice that the Carter pump makes more noise than the Delphi but you can't hear it once the car is running.
-Robert
TYC or Spectra radiator | cityhawk | L-Series Tech | 4 | 01-16-2015 03:02 PM |
Fuel Pump Troubleshooting results. Bad pump? | saladdin | S-Series Tech | 13 | 02-14-2013 10:39 AM |
spectra cold air kit | sl2owner80 | S-Series Mods | 3 | 08-17-2012 02:45 PM |
Delphi or Silla water pump???? | rich_d | S-Series Tech | 40 | 02-23-2012 10:52 PM |
Fuel Pump 2011: PT3 - Bosch Fuel Sending Unit Part Number? | x-angel | S-Series Tech | 4 | 03-23-2011 12:34 PM |
