Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 11-18-2019, 06:25 PM   #1
MikeNW
MikeNW's Avatar
1997 SL
Default General brake question
So I was installing a new master cylinder and rear wheel cylinders in my 97 SL.
And wondering, brake fluid has several + qualities.
But it also removes paint and is hygroscopic.
So why isn't some type of thin oil used in brake systems? For example, hydraulic fluid is incompressible. It has a reasonable boiling point. But it's not corrosive.
08 Burgman 400
Add to MikeNW's Reputation
Old 11-19-2019, 01:38 AM   #2
Default Re: General brake question
Mineral oil isn't compatible with rubber seals in brake systems. If hydraulic fluid is used in brake systems, the incompatibility will swell rubber seals. Hydraulic pressures create a flammable fluid when sprayed out near an ignition source. Extreme heat is another flammability hazard. Past history may have shown early brake systems using regular oil and if fires and broken brake lines sprayed brake fluid, it probably fed the fire. Glycol based brake fluid may have resulted from as an alternative - DOT3 brake fluid is inflammable.
general question sirlarkspur L-Series Tech 7 11-15-2016 08:23 PM
General Sunroof Question bumpdraft S-Series General 20 12-28-2010 02:57 PM
General A/C question Insulator S-Series Tech 3 04-23-2009 04:34 PM
General SKY question... 2NDSOUT Sky General 3 07-07-2006 05:52 PM
General Brake Questions JarredW S-Series Tech 3 01-17-2006 08:23 PM
