Old 10-26-2019, 02:55 PM   #1
98SatSl2
98SatSl2 is just really nice98SatSl2 is just really nice98SatSl2 is just really nice98SatSl2 is just really nice98SatSl2 is just really nice
1998 SL1
Default Mystery coolant leak
Hi everyone,
My 98 SL1 with ~160k miles has a mystery coolant leak.
About three weeks ago I noticed my coolant light on. Waited for the car to cool down, topped it off. Didn't think much about of it. Three days later, I checked and it was low. Three days later again, low. I've only seen one puddle of antifreeze so I know it is leaking and the oil is clean. And the puddle was weird. I pulled up to a driveway, person got out of my car, and then I was backing up and he waved me down. Got out and it was antifreeze.
Last weekend, I did a pressure test on the system. Could not make it leak. took the front passenger wheel off and the plastic to see if there was a leak from the water pump. When I was pressure testing it, I didn't see any other components leaking. I've looked everywhere for coolant. I didn't see any leaks, couldn't see a trail of coolant.
I'm just lost on what it could be. I can drive three days, and then on the third day it seems to just dump half the coolant.
98 Forrest Green manual SL1- Rufus
-198,500
-06/14/11-5/25/14-rear ended
98 Maroon manual SL1- Daphne
-96k miles-115k (10/23/15)- 140k (4/9/18)
-06/12/14-current
98SatSl2 is offline   Reply With Quote
Old 10-26-2019, 03:21 PM   #2
onlinebiker
Default Re: Mystery coolant leak
Sometimes it won' t leak when cold. Try pressure testing it warmed up.
Currently owned
93 SC2
96 SC2
97 SL2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 10-26-2019, 03:52 PM   #3
edlee
edlee will become famous soon enoughedlee will become famous soon enough
1999 SL1
Your intake manifold gasket might be failing. Coolant might be leaking into an ignition chamber and evaporating.
edlee is offline   Reply With Quote
Old 10-26-2019, 04:02 PM   #4
SlayZombi
SlayZombi is a jewel in the roughSlayZombi is a jewel in the roughSlayZombi is a jewel in the roughSlayZombi is a jewel in the rough
2001 SL
I like this one ^^^ BUT he did say he's found a puddle once. When I changed out my lower radiator hose a while back I tightened it juuuust a little too lax, causing a slow leak that created no puddle or obvious trail, but it kept activating the "Low coolant" light, so I might also consider tightening up all of the hose clamps just to be sure.
SlayZombi is offline   Reply With Quote
Old 10-26-2019, 04:07 PM   #5
98SatSl2
1998 SL1
Damn, I didn't let it warm up so if I found a leak I wouldn't have to wait for the block to cool down. Thanks, i'll try that whenever it stops raining.
-198,500
-06/12/14-current
Old 10-26-2019, 04:09 PM   #6
98SatSl2
1998 SL1
I probably would have a puddle more often but gravel hides everything, expect oil. I did have to change out my radiator last summer. Maybe a hose or something is loose. Also, I should have added, the puddle seemed to have come more from the passenger side.
-198,500
-06/12/14-current
Old 10-26-2019, 04:15 PM   #7
SRGW
1997 SL1
Post Re: Mystery coolant leak
Passenger side is where the water pump is under the AC compressor. The bearing has a weep hole and that is where they start to leak.
1995 SL1 236,300 2005>2018
1997 SL1 79,181 2014>????
CHECK YOUR OIL!!
Old 10-26-2019, 04:35 PM   #8
Waiex191
Waiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really nice
Waiex191's Avatar
What I'd do is to look at the weep hole with the car running. Don't get caught in the belt.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 10-26-2019, 05:15 PM   #9
98SatSl2
1998 SL1
I will definitely look at the weep hole. Would the weep hole dump almost a quart or so just in 15 second of someone getting out of the car and me backing up to leave?
-198,500
-06/12/14-current
Old 10-26-2019, 05:25 PM   #10
Waiex191
Waiex191's Avatar
When my water pump went, it went in a spectacular fashion.
http://www.saturnfans.com/forums/sho...9&postcount=24
So it is a likely spot.
Bryan Cotton
Old 10-26-2019, 07:48 PM   #11
454cid
That would be quite a leak, for it to be intermittent.
1999 Chevy K3500
Old 10-27-2019, 08:13 AM   #12
98SatSl2
1998 SL1
That's why I'm lost. I can go about 3 days, and then it just dumps.
-198,500
-06/12/14-current
Old 10-27-2019, 09:05 AM   #13
Signmaster
If it's intermittent, it could be a heat soak thing, or only happening when your temp rises up near fan on conditions or something.
I had one recently that took some digging to find. The reservoir had a very small crack that would only vent at above normal operating temp, and then in the form of steam. The crack was on the fender side, so the vapor puddled as it cooled, ran down the fender and inner liner, and came out at the body panel to bumper seam up near the front of the car.
I had cleaned and dried the "usual" areas a couple days before, but until I saw evidence of the liquid coming out the bumper I was still checking those usual areas.
It was so small at first that I might not have even noticed the steam.
Old 10-27-2019, 12:31 PM   #14
98SatSl2, with a gravel driveway hiding coolant leaks, pick a dry day or two and place cardboard under the engine right after parking with a warn engine. Either a leak shows up in the next hour or the next morning.
If you can remove the serpentine drive belt you can rock the water pump pulley. Bearings never have any play in good condition. When bearings wear, it will be obvious when hand turning and rocking the pulley.
Old 10-28-2019, 01:47 PM   #15
blueknigh7
blueknigh7 has a spectacular aura aboutblueknigh7 has a spectacular aura about
While heat makes things expand, it does seem weird to only dump fluid every three days. I would more suspect that there's a slow leak that only gets noticed every three days, or when the fluid is low enough to throw the light.
Are you able to lift the car or view it from the bottom? It's probably the fastest way as Anti-freeze fluid is pretty visible, even if it's only the dried traces.
So you've checked the water pump, and recently replaced the radiator. Did you replace the hoses as well? My latest leak was from the bottom of the lower radiator hose, where it connects to the thermostat housing. Slow leak where I never saw any drips, but saw it when I was under the car. By now, those guys are over 20 years old if you've never touched them, and it would kinda be toward the passenger side.
Good Luck!
blueknigh7 is offline   Reply With Quote
Old 10-28-2019, 02:11 PM   #16
98SatSl2
1998 SL1
I will find some cardboard to find the leak, and wiggle the water pump pulley. Thank you!
-198,500
-06/12/14-current
Old 10-28-2019, 02:14 PM   #17
98SatSl2
1998 SL1
Good Luck!
It is very strange. I check it every morning before I leave for work. I filled it up Wednesday, drove Thursday, and today, so I will have to fill it up before work tomorrow. I can almost guarantee it.
I didn't wiggle the pump pulley, but I'll do that this weekend. Nope, original hoses. I'll have to double check those. Thank you
-198,500
-06/12/14-current
Old 10-28-2019, 05:04 PM   #18
pickettt
pickettt is on a distinguished road
pickettt's Avatar
I just went through this: Coolant temp light kept coming on every couple of days. No coolant on the ground or anywhere else, BUT I could see that the reservoir was low each time. One day, immediately after parking, I open the hood and steam and coolant is coming out of the reservoir cap. However, it's evaporating almost immediately once it hits the outside surface of the reservoir (which is why I never saw any coolant wetness before). The underside of the cap had some little plastic bits broken and/or missing. I bought a new cap.....problem solved. I hope your problem is just as easily solved.
pickettt is offline   Reply With Quote
Old 10-28-2019, 06:32 PM   #19
Jon Boy
Jon Boy has a spectacular aura aboutJon Boy has a spectacular aura aboutJon Boy has a spectacular aura about
Jon Boy's Avatar
One easy way to find the source of a leak is to put a little UV dye in the coolant. It's only a few bucks at an auto parts store. Then look under the hood with a UV flashlight, and you should see the leak light up pretty clearly.
Jon Boy is offline   Reply With Quote
Old 10-28-2019, 07:14 PM   #20
Waiex191
Waiex191's Avatar
Great idea. I've used it for air conditioning leaks.
Bryan Cotton
2001 SL2 Mystery Coolant Leak Upstate Saturn S-Series Tech 6 01-28-2019 01:02 PM
Mystery coolant leak in my 2001 SL2 the_tim S-Series General 12 10-13-2016 03:33 PM
Mystery coolant leak rtread L-Series General 2 05-04-2014 04:53 PM
Mystery coolant leak (2003 Vue V6) ncinerate Vue Tech 10 02-26-2013 07:10 PM
Where's the Mystery Coolant Leak ? SalemCat S-Series Tech 26 11-01-2010 01:57 PM
