Old 10-16-2019, 02:15 PM   #1
Gr8Scott
Gr8Scott is on a distinguished road
Gr8Scott's Avatar
2006 ION-2 Sedan
2002 L-Series 2.2L Sedan
Default Dual caliper setup
Hey all, I'm interested in doing a dual caliper brake setup on the front of my 2002 L200. I haven't managed to find any dual caliper back plates for my car, so would anyone know how I might go about it? Think I'd have to fabricate? Also, would it be more worth the dual caliper setup than just installing a dual piston caliper?
Add to Gr8Scott's Reputation
Rate the quality of this post and help Gr8Scott reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gr8Scott is offline   Reply With Quote
Old 10-16-2019, 03:10 PM   #2
SC2Sick
1995 SW2
Default Re: Dual caliper setup
Can the L series even go fast enough to justify the need for one?
sixthsphere.com owner
2002 Saturn SL2 - RHD
Add to SC2Sick's Reputation
Old 10-18-2019, 12:29 AM   #3
pierrot
pierrot's Avatar
What is the existing brake hardware at the rear wheels: drum or disc? (Yes, there is a reason for asking this question.)
322,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 10-18-2019, 04:38 PM   #4
What do you mean 'dual caliper' setup? Most daily drivers have single piston front disc brakes and others having four wheel disc brakes - all single piston and more than sufficient for emergency braking as long as the vehicle is used on regulated roads and highways. For track and auto crossing, a street car can benefit from suspension and brake changes. For racing only purposes, anything can be used to go from stock to racing.
There are dual piston brake calipers as well as four piston calipers but they're designed for continuous high speed braking. A light weight car like the S-series doesn't need two pistons per caliper unless you intend to drive on race tracks all the time. Dual piston calipers are simply a waste of money when upgrading to a different brake pad should increase braking performance of existing disc brakes. I can be wrong but someone will have to provide actual data, not hearsay, on replacing single piston calipers with dual piston ones.
Old 10-20-2019, 02:48 AM   #5
pierrot
pierrot's Avatar
I have seen cars with a dual caliper set up, but that was at the rear wheels. These were on very high end sports cars. The "secondary" caliper was actually the parking brake and was much smaller than the brake pedal related caliper. Most cars having rear disc brakes have their parking brakes located in the raised center of the rear rotors and are simply a smaller form of a drum brake set up. Of course, our L-Series cars use that system.
With regard to the front brakes the L-Series cars use a well-sized caliper, pads, and rotor. The calipers and pads are quite effective and need no improvement from a differently designed product. The L-Series cars with the four cylinder engine are relatively light and as a result the braking response tends to be very quick. In my view it would be a waste of time and resources to do anything more than upgrading to drilled and slotted rotors and sport/racing style brake pads which have the same shaping as the OE part.
Old 10-20-2019, 07:25 AM   #6
Sir Wagonsky
Sir Wagonsky is a jewel in the roughSir Wagonsky is a jewel in the roughSir Wagonsky is a jewel in the roughSir Wagonsky is a jewel in the rough
Sir Wagonsky's Avatar
2008 SKY
2002 L-Series 3.0L Wagon
Scott, I agree with Pierrot , just get slotted drilled rotors with ceramic brakes. That's what I did. They're like $80 a set, and work fine. I have multiple cars, and my LW300 had the worst braking, although nothing particularly wrong with them. I feel the new rotors helped. I'm on my second set. Just do the "burn-in" procedure, and expect to replace them every 5-7 years or so on the fronts. ( you'll start to see edge corrosion on the inside surface radius start to work it's way in.)
Add to Sir Wagonsky's Reputation
Rate the quality of this post and help Sir Wagonsky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sir Wagonsky is offline   Reply With Quote
First Dual Alternator Setup in 2006 Saturn VUE NJ FRR Vue Mods 6 08-28-2013 04:41 PM
Dual-Alternator Setup 97 SL2 Pioneer_Saturn S-Series General 49 05-17-2009 12:16 PM
Dual horn setup blue98sl2 S-Series Tech 4 04-07-2006 04:52 PM
setup on my sl1-1/2 Saturnaddict S-Series Mods 5 01-13-2005 07:35 PM
