Old 09-14-2019, 10:45 PM   #21
WrightMan
WrightMan is on a distinguished road
2004 ION-2 Sedan
Default Re: Sudden Leak
Here is the video with dye in the oil. The large gasket is mostly dry. Nothing by the output shafts.
https://youtu.be/gSaiR-g5hJg
2004 Saturn Ion AEM CAI, Aftermarket Head and Taillights, ZZP 2.5" Cat and Custom 2.5" Complete Exhaust
2000 F150 Off-Road 3" Duals and K&N Intake SCT Livewire Tuner
2013 Escape 2.0T AWD CAI
Add to WrightMan's Reputation
Rate the quality of this post and help WrightMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WrightMan is offline   Reply With Quote
Old 09-23-2019, 08:11 PM   #22
WrightMan
2004 ION-2 Sedan
Pretty sure this is the leak any ideas? Clutch was slipping when trying to grab 2nd today now.
Old 10-07-2019, 08:06 AM   #23
WrightMan
2004 ION-2 Sedan
So the transmission took 8 oz of the ATP stop leak and 1 qt of max life high mileage ATF which based on the manual meets the requirements. The leak now smells like tranny fluid even though it is still leaking from the same location. The old fluid that was in the tranny was blackish and didn't smell like any normal tranny fluid which is usually a strong smell if it is good or bad. Was the OE fluid not similar enough to smell near the same?
Old 11-22-2019, 06:41 PM   #24
WrightMan
2004 ION-2 Sedan
So this is still an issue and now that I updated to just transmission fluid leak the dye shows up previously it was just the color of transmission fluid with the light. Here is the leak and it seems to be coming from by the hose but from what I can find that is just brake fluid going to the clutch. Any ideas?
Old 11-22-2019, 10:39 PM   #25
WrightMan
2004 ION-2 Sedan
So the leak seems to be behind where the hose connects and might be hitting the clutch and spraying around it then draining from the clutch inspection opening or what ever the opening is for. I have searched for a good diagram but can't find any to see what gaskets are used and how it is assembled.
Sudden massive transmission leak terminal89 S-Series Tech 30 04-12-2018 01:23 PM
sudden major oil leak 3.5 with 72k jbanderson Vue Tech 8 04-06-2016 08:43 AM
Sudden Tranny leak on my 98 SL1. Is it a differential pin going bad? OgdenSaturn S-Series Tech 18 09-19-2014 02:22 AM
Sudden Transmission Fluid Leak emacsp S-Series General 6 12-16-2010 12:17 PM
Sudden clutch trouble and leak capotoo S-Series Tech 8 07-22-2008 01:30 PM
