Old 05-19-2019, 04:42 PM   #1
carlito
carlito is on a distinguished road
carlito's Avatar
2004 VUE Red Line
Default Broken shock bolt
I've already asked this on Facebook, so sorry if you are reading it twice. Both my lower shock mounting bolts broke. What's the best move from here? A cut off wheel will probably damage the cv boot. A drill would take forever. Someone recommended knocking them off with a hammer and chisel. So my thoughts are try the chisel, if that's doesn't work maybe a sawzall cutting away from the CV boot to avoid damage. Any other ideas?
carlito is offline   Reply With Quote
Old 05-20-2019, 01:00 AM   #2
Default Re: Broken shock bolt
Is either the bolt head or nut exposed enough to use a dremel cutoff wheel? You didn't state what part broke. To ensure no weight is borne on the lower bolts, I use a jack to lift the shock just high enough to compress the shock a little. This removes most of the weight off the shock for easier bolt removal. A dremel with a one or two inch fiber backed cutoff wheel should make it easy to cutoff most of the bolt head or nut. Using a straight punch and heavy ball peen hammer should knock the broken bolt thru. Unweighting the shock helps so loads aren't on the lower mounting bolts. The same when replacing with new nuts and bolts. Hopefully you have replacements (8.8, 10.9, or 12.9 grade). The bolt head should have grade markings.
Old 05-27-2019, 05:59 PM   #3
carlito
carlito's Avatar
2004 VUE Red Line
Well I nothced the bolt with a sawzall, then hammered it off with a chisel. Now I'm having a hard time finding a new bolt and not. Hardware store grade 8 just isn't going to cut it. I'm hoping the chevy dealer will have something. Otherwise I might try fastenal, but I really dont like that company.
Old 05-27-2019, 07:38 PM   #4
Try these two sites;
https://www.belmetric.com/12mm-coars...6_510_406.html
https://www.boltdepot.com/Metric_tap...m_x_1.5mm.aspx
Old 10-11-2019, 04:20 PM   #5
DC_Nikita
DC_Nikita is on a distinguished road
Thank you for posting the links for the bolts. We heard what turned out to be our Aura's rear lower shock bolt come off the other night. We replaced both shocks 2 years ago and it somehow worked it's way out. This old fart loves her Saturns!
Thank again,
DC
DC_Nikita is offline   Reply With Quote
Broken Bolt Help StrnWolf S-Series Tech 9 11-30-2018 03:10 AM
Shock bolt Cavell Vue Tech 8 03-12-2017 03:45 PM
Bolt fell out of rear shock? nikkatnight Ion Tech 15 06-15-2016 09:24 PM
broken bolt jjdrinane S-Series Tech 7 06-03-2011 10:42 PM
Broken Bolt - TB Red97sc2 S-Series Tech 7 02-13-2005 07:59 PM
