Go Back   SaturnFans.com Forums > Site Information > Community Center > Introductions & Greetings
Old 05-10-2019, 08:47 PM   #1
denverjb7
denverjb7 is on a distinguished road
Default Saturn 2003 l200 indicator lights and starting problem!!
I pulled in my driveway...had to replace a vent on the car and in doing so i removed the radio and climate control panel...when i reinstalled everything the indicator lights do not come on when the key is in the run position and the car starts for about five seconds and than shuts off..any ideas..? And the five seconds it is running all the indicator lights come on...?
Add to denverjb7's Reputation
Rate the quality of this post and help denverjb7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
denverjb7 is offline   Reply With Quote
Old 05-11-2019, 11:43 AM   #2
Default Re: Saturn 2003 l200 indicator lights and starting problem!!
You might get more replies if you post this thread in the L-series tech forum. For now, maybe examining radio and climate control connections is needed - disconnecting and checking for bent/shorted pins. If you can leave both disconnected, try starting again. Some climate control signals passes thru the body control module and may interfere with bcm functions. The bcm runs security, interior/exterior lighting, instrument gauges and monitors all modules to pass error codes to the OBD II port. The bcm is second in importance to the engine computer.
If this is a power problem, main power and distributing it consists of; battery, battery cables and their connections. 12.5v on standby, 14.5v worth engine idling. Battery cables should be free of corrosion and tightly connected to the battery. If unsure of battery condition, have it tested at any store selling car batteries.
Starting issues 2003 Saturn L200 Norwal L-Series Tech 1 07-12-2017 08:43 PM
2003 Saturn Vue Intermittent Starting Problem halo14 Vue General 9 06-05-2012 06:25 PM
2003 L200 some interior lights out zsh1175 L-Series General 1 03-14-2009 10:10 PM
My lights go off 2003 L200 fdryer L-Series General 1 12-04-2008 03:47 PM
2003 L300 indicator light/speedometer problem drprnces L-Series General 2 08-18-2003 07:43 PM
