Old 02-28-2015, 01:55 PM   #1
bdemmon
bdemmon is on a distinguished road
Default Using Torque (Android) to read OBDII codes
I've been using Torque on my Android phone to create an extra instrument cluster for things like Oil Temp, Coolant Temp etc. It works pretty well, but is also limited to (some of) the standard universal codes, plus a handful of GM specific codes that are included as *extra* settings. In case anyone's interested, here's a list of active codes I got by logging absolutely everything and seeing what reported a value. Some of these values are read from the phone, not the vehicle, and some require inputting some vehicle data so the program can calculate the value. These codes are for an XE, 4-cyl 2.4L.
47 Absolute Throttle Position B(%)
ff1223 Acceleration Sensor(Total)(g)
ff1220 Acceleration Sensor(X axis)(g)
ff1221 Acceleration Sensor(Y axis)(g)
ff1222 Acceleration Sensor(Z axis)(g)
49 Accelerator PedalPosition D(%)
4a Accelerator PedalPosition E(%)
ff124d Air Fuel Ratio(Commanded)(:1)
221564 AirCon High Side Pressure(bar)
46 Ambient air temp(°F)
ff1263 Average trip speed(whilst moving only)(km/h)
ff1272 Average trip speed(whilst stopped or moving)(km/h)
33 Barometric pressure (from vehicle)(kpa)
3c Catalyst Temperature (Bank 1 Sensor 1)(°F)
44 Commanded Equivalence Ratio(lambda)
ff1258 CO2‚ in g/km (Average)(g/km)
ff1257 CO2‚ in g/km (Instantaneous)(g/km)
ff126a Distance to empty (Estimated)(km)
31 Distance travelled since codes cleared(km)
5 Engine Coolant Temperature(°F)
ff1273 Engine kW (At the wheels)(kW)
4 Engine Load(%)
43 Engine Load(Absolute)(%)
0c Engine RPM(rpm)
32 Evap System Vapour Pressure(Pa)
ff125c Fuel cost (trip)(cost)
2f Fuel Level (From Engine ECU)(%)
0a Fuel pressure(kpa)
ff126b Fuel Remaining (Calculated from vehicle profile)(%)
7 Fuel Trim Bank 1 Long Term(%)
14 Fuel trim bank 1 sensor 1(%)
6 Fuel Trim Bank 1 Short Term(%)
ff1271 Fuel used (trip)(l)
ff1239 GPS Accuracy(m)
ff1010 GPS Altitude(m)
ff123b GPS Bearing(°)
ff1006 GPS Latitude(°)
ff1005 GPS Longitude(°)
ff123a GPS Satellites
ff1237 GPS vs OBD Speed difference(km/h)
221145 H2OS Sensor(mV)
ff1226 Horsepower (At the wheels)(hp)
221141 Ignition 1 Voltage(V)
221538 Inlet air temp2 (IAT2)(°F)
0f Intake Air Temperature(°F)
0b Intake Manifold Pressure(kpa)
ff1203 Kilometers Per Litre(Instant)(kpl)
ff5202 Kilometers Per Litre(Long Term Average)(kpl)
2211a6 Knock Retard(Deg.)
ff1207 Litres Per 100 Kilometer(Instant)(l/100km)
ff5203 Litres Per 100 Kilometer(Long Term Average)(l/100km)
10 Mass Air Flow Rate(g/s)
ff1201 Miles Per Gallon(Instant)(mpg)
ff5201 Miles Per Gallon(Long Term Average)(mpg)
ff1214 O2 Volts Bank 1 sensor 1(V)
ff1215 O2 Volts Bank 1 sensor 2(V)
221154 Oil Temperature (Engine)(°F)
221161 Outside air temperature(°F)
45 Relative Throttle Position(%)
1f Run time since engine start(s)
ff1001 Speed (GPS)(km/h)
0d Speed (OBD)(km/h)
11 Throttle Position(Manifold)(%)
0e Timing Advance(°)
ff1225 Torque(ft-lb)
221940 Transmission Fluid Temp (GM Method 1)(°F)
221940 Transmission Fluid Temp (GM Method 2)(°F)
ff120c Trip distance (stored in vehicle profile)(km)
ff1266 Trip Time(Since journey start)(s)
ff1268 Trip time(whilst moving)(s)
ff1267 Trip time(whilst stationary)(s)
ff1202 Turbo Boost & Vacuum Gauge(bar)
42 Voltage (Control Module)(V)
ff1238 Voltage (OBD Adapter)(V)
ff1269 Volumetric Efficiency (Calculated)(%)
Does anybody know if codes exist for the tire pressure sensors, and the oil life data?
Thanks
B
Add to bdemmon's Reputation
Rate the quality of this post and help bdemmon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bdemmon is offline   Reply With Quote
Old 11-09-2019, 06:21 PM   #2
TroubleFree
TroubleFree is on a distinguished road
Default Re: Using Torque (Android) to read OBDII codes
Anyone know the codes for the ABS on the aura ? They might be similar?
4 Engine Load(%)
0c Engine RPM(rpm)
Thanks
B
Add to TroubleFree's Reputation
Rate the quality of this post and help TroubleFree reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TroubleFree is offline   Reply With Quote
OBD2 reader - torque pro app for Android Jeeprz! S-Series Tech 13 07-08-2019 02:28 PM
elm 327 + torque android app- question about readings jhonky S-Series General 4 04-19-2013 01:33 AM
Anyone use a bluetooth OBDII with Torque? vanilla sky Astra Tech 4 11-17-2012 08:09 PM
2005 ION Quad Coupe can't read codes with OBDII kim_lombard Ion Tech 6 03-05-2010 02:37 PM
