Old 11-22-2019, 06:32 PM   #1
ratwhisperer
ratwhisperer is a jewel in the roughratwhisperer is a jewel in the roughratwhisperer is a jewel in the rough
ratwhisperer's Avatar
1997 SL1
Default Transmission Question
Hi! It's been forever since I've been on here Things are mostly going well. Sooo... we attempted to cell Cinnamon a few months ago, our 1997 SL1 (manual). This was a crazy experience.
So a 'friend' 'bought' the car. I will NEVER do this again. I should have just asked for cash up front and sent him on his way, but I felt bad for his situation and we told him he could pay us $50 a month and we would give him the title after he paid us $600. Yes that is probably cheap, but this is someone who was in a bad situation, and we felt for him. Plus we had just gotten our 1996 SL2 with only 36,000 miles on it, so we were in happy Saturn land for ourselves.
ANYWAY. I just towed it back to the house. I'm in tears. He only ever gave us $30 for it, and he DESTROYED it. This car was my baby. Cinnamon ran beautifully when this guy drove her away, despite having 288,000 miles. He shredded the interior (or his dogs did) threw about a billion cigarettes all over the place, and there is like an inch of dog hair on EVERYTHING.
Yes, I was dumb to have let him do this in the first place, I admit that.
The worst part is this.
The car has NO oil in it.
Two, he says that the transmission is destroyed. I had put a brand new clutch in it less than a year ago. He says "all the fluid drained out of it," and this is after he drove over something because apparently he was taking the car out logging roads or something.
So! My question is this.
Is it really the transmission? I don't know much about transmissions at all. I took the tow strap off of my truck on one side of my property and put some oil in the car, and actually drove it to the other side of my property with no issue. It shifted fine, and drove fine. So I'm perplexed.
Could it be the oil pan?
HOWEVER! The pictures that he sent me (which I am attaching here) show dark fluid dripping from what does in fact look like the transmission.
I will put it up on ramps when I have a bit more time and give it a full once over, but I wanted to ask you here first what you think.
Please be kind, I'm already in tears over this.
Past:
1995 SW2 - Cynthia
2000 SW2 - Ruby
2004 Vue - Jade
1996 SL2 - Ursula
1994 SL2 - Nelly Belle
Current:
1997 SL1 - Cinnamon - 285K
1996 SL2 - Blanca - 36K
Add to ratwhisperer's Reputation
Rate the quality of this post and help ratwhisperer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ratwhisperer is offline   Reply With Quote
Old 11-22-2019, 07:26 PM   #2
SC2Sick
1997 SC2
1995 SW2
Default Re: Transmission Question
Probably blew the diff-pin
You'll need a new transmission. It's common enough on these
sixthsphere.com owner
2002 Saturn SL2 - RHD
Add to SC2Sick's Reputation
Old 11-22-2019, 11:29 PM   #3
ratwhisperer
1997 SL1
Thank you for that insight! I will read up on it.
Past:
1995 SW2 - Cynthia
2000 SW2 - Ruby
2004 Vue - Jade
1996 SL2 - Ursula
Current:
Old 11-23-2019, 12:09 AM   #4
ratwhisperer
1997 SL1
One more question... if the diff pin is blown would it still be able to shift and drive? Because it does shift and drive with no issues; at least around my yard. I didn't attempt anything above 2nd gear, but 1st, 2nd and reverse seem to function okay. I do not want to drive more than I already did, but I'm just curious.
Past:
1995 SW2 - Cynthia
2000 SW2 - Ruby
2004 Vue - Jade
1996 SL2 - Ursula
Current:
Old 11-23-2019, 10:44 AM   #5
Zeebins
Zeebins's Avatar
If only a piece of the diff pin broke off, you would still be able to shift at least somewhat. The transmission is dead either way though weather it was the whole pin or just a piece. There should be an obvious hole if it broke but you can also take out the vehicle speed sensor and see if it's still there.
http://www.saturnfans.com/forums/showthread.php?t=96588
97 SL2, auto, 116K miles
Powered by Plastic
Add to Zeebins's Reputation
Old 11-24-2019, 01:32 PM   #6
hholbein
1997 SW2
Very sad to hear your story from a fellow Oregonian! A partially dislodged diff pin could have worn/knocked a hole in the transmission case, or perhaps this guy cracked the cast aluminum transmission casing by high-centering it on a rough Forest Service road.
You can easily check how much ATF was lost by looking at the dipstick close to the battery tray.
Let me know how you get on.
Add to hholbein's Reputation
Old 12-03-2019, 06:44 PM   #7
ratwhisperer
1997 SL1
So yes you folks were definitely correct, there is a big hole in the tranny, and I believe it's the diff pin I have a hookup for a rebuilt tranny from B&R auto wrecking for $100, so I think I'll do that and attempt to fix it myself, and then clean the poor thing up and see how it goes. Thank you!!
Past:
1995 SW2 - Cynthia
2000 SW2 - Ruby
2004 Vue - Jade
1996 SL2 - Ursula
Current:
Old 12-03-2019, 07:08 PM   #8
bluesl2
bluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of light
bluesl2's Avatar
Sorry for your situation, it hurts having to be the nice guy I know. At least the title is in your name still. You are going about fixing it the right way putting a used transaxle in it, that's the cheapest for certain. Next time though tell the clown to get a loan through a bank, they take monthly payments too.
Add to bluesl2's Reputation
Rate the quality of this post and help bluesl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-04-2019, 01:34 PM   #9
People like that tend to have terrible credit and no credit cards, and have also burned all their bridges with other friends and relatives (after borrowing money and never paying it back, taking advantage of their kindness, being thoughtless with borrowed things, etc)
I'm glad your car wasn't more damaged by this guy
Transmission question Steve_Bier S-Series Tech 6 10-29-2010 07:39 PM
Transmission question sisjake S-Series General 3 05-26-2006 10:09 AM
Transmission Question buyobuyo L-Series General 7 02-06-2005 10:54 PM
Transmission Question lentinman S-Series Tech 14 09-01-2004 03:10 PM
Transmission Question? GC01SL2 General Saturn Discussion 2 02-25-2003 12:47 PM
