Old 08-26-2014, 06:54 PM   #1
Au Ra Vue
Au Ra Vue is on a distinguished road
Au Ra Vue's Avatar
2006 VUE Red Line
2007 AURA XE
Default 2007 Aura power steering leak
Leak takes about a week or so to get low so I haven't been the quickest to fix it, but I did take a look to see where it was coming from. Right at the base of the steering column, where it column and the rack meet.
Anyone ever have a leak there? Is there a seal or something common there?
I'll post pictures later when the car is home here.
Thanks in advance for any help.
*10/11/14 lost my timing belt virginity
*formerly Vue in Ontario
Add to Au Ra Vue's Reputation
Rate the quality of this post and help Au Ra Vue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Au Ra Vue is offline   Reply With Quote
Old 03-16-2015, 08:09 PM   #2
NateHale88
NateHale88 is on a distinguished road
Default Re: 2007 Aura power steering leak
Bringing back this old unanswered post. I have this exact same issue. It appears to be profusely leaking power steering fluid from where the intermediate steering shaft goes into the steering rack. Anybody know if this is fixable by a deal or new iss or seal will fix it??
Add to NateHale88's Reputation
Rate the quality of this post and help NateHale88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NateHale88 is offline   Reply With Quote
Old 03-16-2015, 09:55 PM   #3
billysvue
I've fixed power steering leaks in the past just by sucking out the old fluid( bad fluid causes the leaks-hint) in the res. a few times( followed by replacement and driving for a day or two,) repeating several times more until the color of the fluid cleaned up.
Once you're at that point, some steering fluid STOPLEAK is added to the system after enough is drained to create room. SHould stop the leak if it hasn't got too bad.. Beats the price of new parts if it gets you down the road for a couple more years.
And I did just that on several cars.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 03-16-2015, 10:00 PM   #4
billysvue
What engine? This one?
http://www.tonkinonlineparts.com/sho...ssembly=860533
WHere on the diagram?
HOpefully it's just a loose hose clamp on reservoir hose to pump.
Doesn't mean you can loaf and let the old fluid stay.
'17 Suby Forester
Old 03-17-2015, 07:40 AM   #5
gpartrid
gpartrid is a jewel in the roughgpartrid is a jewel in the roughgpartrid is a jewel in the roughgpartrid is a jewel in the rough
gpartrid's Avatar
2008 AURA XR
2008 SKY Red Line
I discovered a power steering leak a few months after I bought my AURA back. It was leaking from under the engine on the driver's side as evidenced by the spot in my driveway. Apparently something to do with the lines? Dealer repair was covered under my CPO BTB warranty. Haven't had a problem with it since.
2008 AURA XR
Ocean Mist
Sunroof
Loaded!
Built: 07/19/07
2008 SKY RL
Silver Pearl
Black on Black
6 Disc w. Monsoon
Chrome Wheels
4 Pedals
GMPP Turbo Upgrade & CAI
Built: 09/20/07
Add to gpartrid's Reputation
Rate the quality of this post and help gpartrid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-17-2015, 12:10 PM   #6
NateHale88
Woops sorry for not specifying what year and engine.
2008 Aura Xe 3.5l V6.
It gets new fresh fluid quite often as it is leaking pretty darn bad. It for awhile was just needing to be topped off every month or so. As of late it is every few days.
The leak doesn't appear to be coming from a line as that would be a simple fix for me. It is right where the steering intermediate shaft goes into the rack. So right where the column leads down through the firewall and into where it connects into the rack. Not sure if a seal can go bad in there or what but its pretty well soaked down there and I can visibly see fluid seeping from out the top.
Worse comes to worse I will order a new Rack and replace it myself but was hoping for an easier alternative.
Thanks for the assistance guys!
Old 08-08-2015, 12:00 PM   #7
mog703
mog703 is on a distinguished road
so did you ever find out the problem? seem to be having the same issue. can you help?
Add to mog703's Reputation
Rate the quality of this post and help mog703 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mog703 is offline   Reply With Quote
Old 11-13-2019, 09:48 PM   #8
TroubleFree
TroubleFree is on a distinguished road
I found to have the same issue today when inspecting it. The leak is very slow but boy one small leak after another.
I'm beginning to think the aura has many weak points for leaks in general.
Add to TroubleFree's Reputation
Rate the quality of this post and help TroubleFree reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TroubleFree is offline   Reply With Quote
Saturn Aura XE 2007 with Radiator Leak Dron Aura General 11 01-19-2019 11:54 AM
Power Steering Recall on 2007 ION cam Support Forum for Canadian Saturn Owners 1 08-10-2010 11:36 AM
Power Steering Leak TSB RobJG L-Series Tech 1 01-19-2010 11:45 PM
2007 ION loss of power steering? Ortega flyer Ion Tech 8 05-23-2009 06:24 PM
power steering leak/steering rack question Gadweller S-Series Tech 9 11-19-2005 03:18 PM
