Old 01-20-2009, 10:17 PM   #21
mjkiefer
mjkiefer is on a distinguished road
Default Re: Battery drain
Took my car to the Saturn dealer today. They told me what I suspected thanks to the wealth of information on this site-bad ignition switch. Quoted me around $215.00 to repair. I told them if they weren't going to fix it for free I'd pay for the part and do it myself. My only concern is having a small enough tool to get the t15 screws out that secure the switch. I haven't physically seen how tight of a space the switch is set in the steer column. Can they be taken out with a screwdriver with a star bit or would that be too big? I don't really know until I get in there unless I have some advice from others. Thanks.
Oh..........I'm a little concerned about the relearn process. If it doesn't work, can I install my old switch back to use again or will it have to be "relearned" as well? This is for a worse case scenario and I HAVE to take it to the dealer for them to program the switch. Thanks again.
Add to mjkiefer's Reputation
Rate the quality of this post and help mjkiefer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjkiefer is offline   Reply With Quote
Old 01-21-2009, 08:42 PM   #22
mjkiefer
I wanted to thank all who replied to my posts over the past couple of days. I installed my new ignition switch this evening with minimal problems-the relearn process didn't go as planned the first time but it finally worked. Thanks for all your advise. I saved the wife and I $200+. Next it's on to a motor for the driver's side window-they wanted $300+ for that! My car only has 30,000. Way too early for parts like this to be malfunctioning.
Old 01-04-2019, 05:59 PM   #23
SilvrEagle
SilvrEagle will become famous soon enough
Parasitic drain is my guess. I just bought a 07 Aura that has this problem. After extensive troubleshooting today I found the following drain when key is off and all doors closed:
.72 amps - radio (pulled radio fuse (right center console) for this)
.28 amps - Pulled fuse 16 in trunk (garage door opener, digital radio receiver, & remote control door lock)
.20 amps - OnStar (pulled OnStar fuse (right center console) for this)
.13 - ignition
.23 - cluster/theft
.13 airbag battery
So from 1.7 amps to .49, so I hope my battery issues are solved now... Can live with all these pulled, but want to troubleshoot the radio issue further, my wife does want her radio back...
Add to SilvrEagle's Reputation
Rate the quality of this post and help SilvrEagle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SilvrEagle is offline   Reply With Quote
Old 11-13-2019, 04:30 AM   #24
licmarcos
licmarcos is on a distinguished road
licmarcos's Avatar
2006. Are you still in warranty? 3 year 36,000 miles.
Add to licmarcos's Reputation
Rate the quality of this post and help licmarcos reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
licmarcos is offline   Reply With Quote
Battery Brain: product to prevent battery drain davesaturn Ion Tech 19 04-13-2008 08:19 PM
Drain on battery? meseville S-Series Tech 6 04-09-2008 09:59 PM
Campaign for battery drain mcvue 2008 Vue 18 02-26-2008 09:51 AM
Battery Drain -- Ignition?? JoshM20 S-Series Tech 6 10-29-2007 09:16 PM
'93 SL1 New Battery Drain SilverRush S-Series General 1 06-20-2006 09:44 PM
