Old 07-02-2012, 11:50 PM   #1
Yngpreach
Yngpreach is on a distinguished road
Yngpreach's Avatar
2000 L-Series 3.0L Sedan
Default Im out of options and $$$
I bout a 2000 Saturn LS2 1 owner w/ 104000 miles roughly 3 years ago. It now has 140000 miles now and a Beautiful car. I have two problems with this car.
1. Im only getting 245 miles per tank of gas, weather I drive it on the highway or in the city.
Here is what I have done. Timing belt & water pump replaced @ 108000, Fuel filter changed, cabin air filter, under the hood air filter changed, oil is changed every 3000 miles. Throttle Body & MAS has been cleaned out, tires are rotated and balanced every other oil change. Spark plugs changed, and fuel injection cleaner has been used and I still only get 245 miles per tank of gas.
2. PROBLEM TWO.
Im having a big issue of this car cranking but not turning over. It's happening now more than ever. One day it wont start. I will let it sit for a couple days, come out to the car and it will start right up, i can drive it for a few days and then the same thing will happen a again. I will have it towed to my mechanic and it will start for him. I pick it up, i can drive it for a few days, same thing happens again. I will try to start it for 3 days straight, NOTHING! I have it towed to the dealership, it starts for them and they tell me nothing is wrong with my car.
Im tired of spending money on tows, diagnoses and Im sick of looking like an idiot. Some please give me some insight.
Last edited by Yngpreach; 07-03-2012 at 12:00 AM.. Reason: added additional information
Add to Yngpreach's Reputation
Rate the quality of this post and help Yngpreach reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Yngpreach is offline   Reply With Quote
Old 07-03-2012, 03:09 AM   #2
Default Re: Im out of options and $$$
Which engine is this?
Old 07-03-2012, 03:17 AM   #3
Chazberry
Chazberry's Avatar
1995 SW2
Originally Posted by Yngpreach View Post
2. PROBLEM TWO.
Welcome aboard. I'm thinking this is the 3.0L V6?
My first thought - an intermittent Crankshaft Position Sensor can give you these symptoms.
You also might do better re-posting this in the L-series Tech section.
Add to Chazberry's Reputation
Old 07-03-2012, 08:25 AM   #4
Yngpreach
Yngpreach's Avatar
This is the 3.0 V6
[/B]
Old 07-03-2012, 09:24 AM   #5
As mentioned, add the engine and model to your personal profile so it pops up under your name. And search the L-series tech threads about intermittent crank position sensor faults.
We have members confusing L-series with S-series, one engine for another, etc., and we wind up playing twenty questions.
If this is a cps issue, all starting attempts will flood the engine without a start. Whatever the outcome, try starting without throttle and if the engine doesn't fire up, hold the pedal to the floor for all subsequent starts - this tells the ecm to shut off injectors while starting to dry out the engine and allow the spark to work instead of shorting from soaked plugs.
The cps is next to the oil filter. There are many 'experts' that don't recognize intermittent failures. Here on Saturnfans its a recurrence across a few models with the same symptoms.
Old 07-03-2012, 11:35 AM   #6
Yngpreach
Yngpreach's Avatar
thanks
Old 07-04-2012, 01:43 PM   #7
Chazberry
Chazberry's Avatar
1995 SW2
To test the CKP, check the resistance. A good one reads 900-1000 Ohms across the terminals.
Old 12-07-2018, 05:35 PM   #8
Mkharris
Mkharris is on a distinguished road
This helps so much. We have replaced this sensor 3 times already. However it has never caused our car to do this. So we just simply figured it was something else.
Add to Mkharris's Reputation
Rate the quality of this post and help Mkharris reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mkharris is offline   Reply With Quote
Old 12-15-2018, 09:55 PM   #9
markwood007788
markwood007788 is on a distinguished road
I will miss the Saturn client benefit philosophy the greater part of all. Up until now, the approved specialist co-op has not satisfied my desires. One would believe that they would take something that did work and add it to their plan of action. IT appears that GM and their merchants simply need to delete all hints of Saturn. Much appreciated Charlie for keeping Saturns memory alive. It is much valued. Cheerful New Year to all.
Add to markwood007788's Reputation
Rate the quality of this post and help markwood007788 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
markwood007788 is offline   Reply With Quote
Old 11-13-2019, 04:28 AM   #10
licmarcos
licmarcos is on a distinguished road
licmarcos's Avatar
Add to licmarcos's Reputation
Rate the quality of this post and help licmarcos reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
licmarcos is offline   Reply With Quote
Sky options? Green98SC2 Sky General 26 03-30-2006 01:28 PM
Options Dj_Xao L-Series General 2 01-15-2004 11:55 AM
Must have Options SW2Muck General Saturn Discussion 25 09-03-2003 09:44 AM
What options? KJB Vue General 3 07-01-2003 06:46 PM
Options LWZen Ion General 13 11-29-2001 10:02 PM
