#1 | ||||
![]() Join Date: May 2018
2009 VUE 2.4L
![]() On a saturn vue 2009 2.4l 4t45e transmission has anyone run a cross a error code C0103
I,m usi g obdclick reader
#2 | ||||
![]() Some sites are better than others. One, https://obdii.pro/en/code/C0103 seems to be accurate and covers many vehicles. Subscribing to alldata.diy or Mitchell may be wiser if you're going to be a diyer and want the best info possible. Both online sites present service manuals second to none.
AutoZone, from members here, have updated their readers to decode abs errors. It might help to ensure the error code is valid, comparing your reader to another. Check your local AutoZone for their reader's ability to decode abs errors before going.
#3 | ||||
2009 VUE 2.4L
![]() thank you for the reply autozone came up with the same but couldn,t tell me what iy was there reader just said it might be the abs , i,m going to check the wiring today thanks again
#4 | ||||
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2012
2003 VUE 3.0L
![]() c0103 is right front wheel speed sensor. oriellys code readers should pick that up. i rented an autozone code reader and it does abs, srs and cel stuff. nice unit
#5 | ||||
![]() Join Date: Oct 2019
![]() Problem is controller area network wiring bus and modules. SAE - Generic codes, which have a '0' as their second digit to indicate they are common to all makes and models of vehicles. These are the codes that are required for basic emissions fault diagnosis.
Cleared out a code 19 and car runs great...Now I have a code 26 93 SL1 automatic. | Pickleperforman | S-Series Tech | 5 | 05-01-2014 01:06 AM |
F/S Actron cp9580 code connect scanner/ code reader | ShawnV | S-Series General | 0 | 06-13-2013 05:25 PM |
P0410 code, changed ECTS, code back | mattwithcats | S-Series Tech | 1 | 06-24-2011 07:40 PM |
Need my paint code, 96 sc2 black/gold metallic (I'm missing the trunk panel w/code) | DJboozeAlot | S-Series General | 3 | 03-18-2011 10:26 PM |
check engine code 11, coolant hot light flashes code 23, 95 SL2 | 2003MercMaraude | S-Series Tech | 2 | 10-23-2009 06:17 PM |
