#1 | ||||
![]() ![]() ![]() Join Date: Aug 2017
![]() I bought a set of aftermarket wheels for my Astra so I need to reset the TPMS. I have one of the tools to do that but i can't get the car to go into learning mode. I followed what I thought was the correct procedure. Turn the ignition to the on position but don't start the car and then press the lock and unlock buttons on the key fob simultaneously. But nothing is happening. Is there a different procedure for the Astra or for a manual car?
#2 | ||||
![]() ![]() ![]() ![]() Join Date: Nov 2007
2008 Outlook XR
2007 AURA XR
![]() Not sure but astra does not use gm tpms system. Think that procedure is for gm cars. Thinking maybe you need a tool .
#3 | ||||
![]() ![]() Join Date: Mar 2009
2009 Astra XR
2008 Astra XE
![]() There is no tool required. As long as you bought the correct tpms sensors the car will self learn the sensors while driving above 15mph for a couple miles. The astra uses a passive sensor system where the car monitors the pressure but not at a specific tire, it won't tell you which tire is low just that there is low pressure.
... 09 Vauxhall Astra XR3/STD 18" Team Dynamic MonzaR rims Eibach Sportline, Whiteline BHR75Z swaybar and EBC Rotors CD30 Mp3, Insignia jets, vxR surround, sharkfin antenna, Spoiler, Tint
#4 | ||||
![]() ![]() ![]() Join Date: Jul 2017
![]() Did anyone manage to figure out how to reset the TPMS in case the Saturn Astra does not auto reset? I am just tired to look at the yellow sensor light on the dash. Thanks!
#5 | ||||
![]() ![]() ![]() ![]() Join Date: Jun 2013
2008 AURA XE
![]() Based on this....It auto resets
http://www.saturnfans.com/forums/sho...60&postcount=7 ... 2008 Saturn Aura XE 3.5L 4 spd 2000 Saturn SL1 1.9L SOHC (Retired)
#6 | ||||
2009 Astra XR
2008 Astra XE
![]() It auto resets, chances are that you have a dead TPMS sensor. I've already replaced all of mine when the batteries failed 3 years ago
#7 | ||||
![]() Thanks for the advice! But I never had any issue with the sensor, before changing two tires in the front and moving the best remaining two in the back. It this is indeed the case, I guess I will have to wait until I change the other two tires to replace all sensors.
#8 | ||||
![]() Is there info in the owner's manual on life expectancy of tpms batteries. General info says no more than ten years but recommendations are to replace sensors when replacing tires. Calculation of tire life in years can determine when to replace sensors to maximize their use while avoiding dead batteries and adding costs to sensor replacement from needlessly dismounting a tire for sensor replacement.
#9 | |||||
2008 AURA XE
#10 | ||||
2008 AURA XE
![]() This video explains checking Tire Pressure Monitoring System (TPMS) Battery Information
https://www.youtube.com/watch?v=KwYLlh1PQu4 ... 2008 Saturn Aura XE 3.5L 4 spd 2000 Saturn SL1 1.9L SOHC (Retired)
NEWBIE here again- still learning | GPCBAKER | S-Series Tech | 8 | 06-09-2011 06:13 PM |
High speed wiper mode active when in Retained Accessory Power mode | MJD112379 | Aura General | 15 | 07-25-2008 07:24 PM |
Learning about cars... | Serpico | General Saturn Discussion | 2 | 06-25-2007 02:23 PM |
The learning curve... | The Critic | S-Series Tech | 6 | 10-18-2006 05:08 AM |
Learning | karinhesed86 | General Saturn Discussion | 3 | 02-01-2006 08:25 PM |
