Go Back   SaturnFans.com Forums > Site Information > Community Center > Introductions & Greetings
Old 10-02-2019, 12:42 AM   #1
Cbrackin
Cbrackin is on a distinguished road
2004 VUE 2.2L
Default Crank no start I'm very confused
I recently purchased a 04 Vue 2.2 5speed it needed a clutch I had never owned a Saturn so I said why not it was something to do rather than sit in the house well after the exciting time putting the cluch in and after putting everything back together it cranks but won't start I have seen the same issue in the group over and over but mine seems a little different and it has me stumped everything was fine before the tear down to replace the cluch it ran like a top but after putting it back together it will crank but won't start most post I have seen are saying that the security light is on but mine isn't when you switch it on the gas gauge will jump and go right back down and I can't hear the fuel pump all the warning lights that are on are the gas light the engine light and the car with a wrench in it all on the left side of the dash any help would be appreciated
Add to Cbrackin's Reputation
Rate the quality of this post and help Cbrackin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cbrackin is offline   Reply With Quote
Old 10-02-2019, 10:00 PM   #2
Default Re: Crank no start I'm very confused
Without punctuation marks, your post reads as one run on sentence. Please use periods(.) and commas(,) where needed.
First, did you check all wiring for damage when replacing the clutch? Second, did you check every fuse for blown ones? Don't guess, check.
Under normal circumstances, when turning on ignition, all instrument panel lights cycle on then off, leaving brake/oil/seat belt/battery light on as part of lamp tests. This also tells you the pcm and bcm are operating. The bcm, airbag and abs module turn on indicators. The fuel pump runs for about two seconds then shuts off if the engine isn't started. Locate the fuel rail test valve and depress the test valve and see if fuel sprays out (cover with a rag as pressure should shoot fuel).
No Start No Crank, No idea where to start magician22773 S-Series Tech 8 03-30-2014 09:01 PM
Crank but no start FredTheMonster L-Series Tech 1 02-12-2014 03:38 PM
03 ion no crank no start! joffrion79118 Ion General 3 06-27-2013 06:48 AM
Won't start and confused. texasboy S-Series Tech 6 10-07-2012 02:41 PM
Very Confused with my 1998 SL... Intermittent No-Start tulsavw S-Series General 7 08-17-2009 06:42 PM
