#1 | ||||
![]() Join Date: Jan 2007
1993 SC2
![]() What are the symptoms of a bad CPS besides not starting when warm?
Will it idle rough at operating temp? Will it run rich? Will it throw a code 45? ... "it's not that i like to pick on Hondas, but it's so easy..."
#2 | ||||
![]() Generally when the crank position sensor fails the engine doesn't run. The computer thinks the engine has stopped turning so it turns off the fuel.
#3 | ||||
![]() Join Date: Nov 2006
![]() I don't think so...
If its running rich at start up... the first item to look at is the ECTS.. Your code 45 is an EGR issue...
#4 | ||||
![]() Actually a code 45 indicates a rich condition. Main cause of is a bad coolant temp sensor.
... A lousy day in paradise is still a day in paradise.
#5 | ||||
1993 SC2
![]() the ECTS and connector is new. EGR and every other sensor on the car is new, cant figure this out
#6 | ||||
1993 SC2
![]() is it possible my coil packs are not firing hot enough?
#7 | ||||
![]() Join Date: Aug 2005
1993 SW2
![]() Did you install a Saturn ECTS? Are the spliced pigtail connections good? (That's where I'd look first if it was me.)
... 1993 SW2, 1996 Dodge Cummins
#8 | ||||
1993 SC2
![]() I got a Autozone ECTS, and the connections are good. I can't figure why it runs rich. Only when warm, when cold, it runs great, it's almost as if the ECM isn't changing the amount of fuel from startup to operating temp.
#9 | ||||
![]() ![]() Join Date: Jul 2005
![]() It really sounds like you have either the wrong sensor or it is not connected properly.
There are two sensors in the head of a 91-95. They look very similar but are very different. 1. The ECTS (Saturn part# 21025106) is the one with the two wire connected to it. It is usually in the lower part of the head. 2. The Temperture Gauge sensor (Saturn part# 21020124) is the one with the single wire connected to it. It is usually in the upper part of the head. The connectors are keyed different but can be connect to the wrong sensor. (Yea, I did this once) Also the variable resistance level is totally different between the two sensors. Last thought. Is your IAT sensor connected? With an open IAT the engine thinks that it is freezing outside and runs very rich. Really get terrible gas milage too. ... "When you stop to fill up on oil, don't forget to check the gas" 98 SL2 MT 213K+ Daily Driver 38+ mpg 97 SL2 AT 150K Original Owner 95 SL2 MT 220K+ My Saturns have BRASS ones!
#10 | ||||
![]() Does the FAN kick on when you expect it to?
#11 | ||||
1993 SC2
![]() i have a manual fan. but it used to.
Crank Position Sensor | pyranite | Vue Tech | 11 | 05-03-2007 07:31 PM |
crank position sensor 2000SL1 | donlashway | S-Series Tech | 6 | 09-28-2006 07:11 PM |
Where Is The Crank Position Sensor Located | Mike1969 | S-Series Tech | 2 | 07-13-2006 01:12 PM |
crank position sensor test | mbkustom | L-Series General | 0 | 02-15-2006 06:27 PM |
Crank Position Sensor | 1991SL | S-Series Tech | 4 | 03-27-2002 01:06 PM |
