Old 04-03-2006, 01:59 PM   #1
clemtwist
clemtwist is on a distinguished road
Default Clutch hydraulic system problems
Well I got my 96 dohc engine into my 95 saturn SC2 (thanks for the help guys). In the process I installed a new clutch. So my problem is that I got my engine/transmission all back together and I go to drive the car and I try to pump up the clutch. At first it is very stiff, I almost could not push it in and then it kind of popped and got really easy to push in and out like it had to pressure to it. So sure ennough I can see brake fluid coming out of the transmission rapidly! So I ended up pulling the slave cylinder out of the bellhosuing and the little rod on the end had broken off and was sitting in the bottom of the transmisson. My question is did I install something wrong or maybe my clutch hydralic system was due for a change with 164k? My clutch hydralics seemed to be working perfectly before I begun the engine swap.
Add to clemtwist's Reputation
Rate the quality of this post and help clemtwist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
clemtwist is offline   Reply With Quote
Old 04-03-2006, 04:11 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: Clutch hydraulic system problems
That happened because you didnt line up the pin correctly. Its supposed to go into a little indentation on the clutch fork. If its not alligned correctly, the pedal will be stiff at first, the pin will pop off and down into the tranny. If you realize this right away, you wont damage the slave cylinder. Looks like you may of pressed the pedal a few more times and damaged the lower part of the slave cylinder. A new slave cylinder will have allignment tabs on it so this wont happen again. But you still have to get that pin out of there. It not really all that hard to do.
To get th pin out if you havent already, jack up the car and remove the flywheel cover, and stiffening bracket. Also remove the battery, battery tray, intake, and the upper and lower tranny mounts. I may of removed the exhaust down pipe too, but cant remember. Then loosen the four tranny bolts. Remove each bolt then reinsert it and only thread it in about 1/2 inch. Once all four bolts are loose and threaded in a little bit, pull on the transmission until the it bottoms out on the heads of the bolts. Then lower the passenger side of the car, leaving the drivers side as high as you can get it.
Now get under the car and look behind the flywheel with a flashlight. Hopefully you can see the pin now. With the tranny pulled out of the way, there should be enough room to manuver the pin out.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 04-03-2006, 04:54 PM   #3
clemtwist
Thanks for the reply Mike. Do you think that I got dot III brake fluid all over my clutch and inside my tranny? Do you think I will need to remove the transmoission to clean out all of the fluid that may have sprayed every where?
Old 04-03-2006, 05:10 PM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
Personally, I'd get the pin out and with it open spray a couple cans of brake cleaner in there. Let it dry and bolt it back up. If you're lucky it'll be ok, if you're unlucky, you'll have to pull it apart and clean it. I'd go the easy way first and see what happens.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 04-03-2006, 08:31 PM   #5
twosaturns
twosaturns's Avatar
I would think that the fluid just puked out and dripped down. and, the clutch disc is covered by the pressure plate anyway, so I doubt you got any on the disc itself.
btw, you're going to HATE yourself when you see the price for a new hydraulic setup.
Add to twosaturns's Reputation
Rate the quality of this post and help twosaturns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
twosaturns is offline   Reply With Quote
How To: Clutch Hydraulic system with pics ShawnV How-To Library 26 08-17-2016 03:25 AM
Q about hydraulic clutch system MikeNW S-Series Tech 13 12-22-2011 09:11 AM
Bleeding clutch hydraulic system MikeNW S-Series Tech 2 06-03-2009 01:43 PM
Help ! Air in Hydraulic Clutch System GlennWerner S-Series General 2 12-06-2007 10:54 AM
98 SL2 clutch hydraulic system Boodah S-Series Tech 2 05-15-2007 01:40 PM
