Old 03-23-2006, 10:58 PM   #1
2002SaturnMan
2002SaturnMan is on a distinguished road
2002 SL1
Default 1998 SL1 horn wont work on steering wheel or keychain remote -checked fuse under hood
Well I did a bit of searching and reading, and I found a really good thread http://www.saturnfans.com/forums/sho...ight=Horn+dead
but I'm not sure it's going to help me figure this out.
We purchased a 98 SL1 yesterday and I noticed the horn wouldn't work. I have a 2002 SL, so I know a "little" (I stress "little") bit about Saturns. I checked the fuse under the hood it looked good, but I replaced it with another 10 amp fuse. Still the horn doesn't blow when I press the steering wheel button, or the button on the keychain remote.
I read in the other thread that inside the car by the passengers feet that there's another fuse box, but I haven't looked in it yet. In my manual, or my Hayes repair book nothing tells me whats inside the fuse box by the passengers feet. Is there something there that might be my problem?
I know you guys said in the other thread to make sure it's grounded and that the wires are ok, but I have to admit (please forgive me), I'm not really that knowledgeable about all the stuff under the hood. I'm great with tearing desktop computers apart and rebuilding them, I've just not gifted when it comes to cars.
Don't get me wrong, I can change the oil, air filter, spark plugs, and front brakes but that's about it. I need to learn more about these cars, because my wife is getting a 1997 SL2 in the next couple weeks (if the deal goes through).
So any suggestions on how I can fix this and not have to take it to a dealer would be appreciated.
Go easy on me, and don't use too much technical jargon. Thanks!
2002 SL1, manual, SOHC (VIN 8) with 179,300 miles sold 8/29/14 (great car!).
Former - 1994 SL 212,000 miles (great car!)
Step daughter HAD 1998 SL1, Wife HAD 1999 DOHC (VIN 7) SL2
Add to 2002SaturnMan's Reputation
Rate the quality of this post and help 2002SaturnMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2002SaturnMan is offline   Reply With Quote
Old 03-23-2006, 11:01 PM   #2
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
Default Re: 1998 SL1 horn wont work on steering wheel or keychain remote -checked fuse under hood
there could be a loose connection, short, or your horn is blown
i'd be careful with the '97 because there is a slight problem with the fuel pump not being able to spin up to pressure fast enough, i'd get in the car, turn the key to RUN but not START, put seatbelt on, then start car, so that the pump has enough time to spin up to pressure. Good luck!
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 03-24-2006, 01:43 AM   #3
wolfman
wolfman's Avatar
The horns on the 96' and UP cars have the horn relay built into the horn. If the fuses are all good, odds are the horn itself is at fault.
You will need: Automotive type test light (Walmart $8~10 if you don't have one)
To check:
Locate the horn. (Below/behind driver's side headlight not easy to see or get to)
It will have three wires goingi into it.
1 will have positive power all the time
1 will have ground all the time
1 will have NEITHER
With the "dead" wire probed with a test light hooked up to battery positive, have someone press the horn button on the wheel. If the test light lights up, the relay IS getting a ground signal from the horn button and the horn itself is shot. (Replace horn)
Add to wolfman's Reputation
Old 03-24-2006, 02:08 AM   #4
mad_nigerian
mad_nigerian is on a distinguished road
mad_nigerian's Avatar
1997 SC1
dude it most likely the horn, i drove my saturn for like a year without the horn cos i assumed it was an electrical problem, i won't even lie, i loved yelling at the people in front of me, but only during traffic, when i got cut off all i could do was stare. I found my horn when i took off the front bumper, replaced it and BAM!!!!! that was it, so check it out,
Add to mad_nigerian's Reputation
Rate the quality of this post and help mad_nigerian reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mad_nigerian is offline   Reply With Quote
Old 03-24-2006, 01:40 PM   #5
2002SaturnMan
2002 SL1
Thank you.
What is the going price for a new horn if we need one?
Old 03-25-2006, 03:40 PM   #6
2002SaturnMan
2002 SL1
Thank you very much for your help. I'm sorry to bother you!
I went Walmart and they didn't know what a "automotive type test light" was. I explained what I was going to use it for and they told me that I would have to go to a speciality store for something like that. Anyway, I'm wondering if you could post a link to what one of these things look like. It doesn't have to be at Walmart. I'll just go find one once I know what the look like.
Also, I went to a junk yard today (first time ever). It was a lot of fun. I found a bunch of Saturns that people REALLY stripped for parts. Anyway I was only looking for that handle thing that goes in the roof above the back seat passenger door. Got one for only $2.00. I saw so many other neat things that I'd like to go back and check out. If I ever get in a accident and need a new headlight or taillight I'll sure get one there. Oh yes, we also got two nice Saturn mats for only $5. I'll need to clean them a little, but I bet they will look like new!
I have a Haynes Saturn S-Series 1991 to 2002 manual and I'm trying to find the horn in the book, but there's nothing in the index under "horn". Anyone know where in the book it might be? Do you think I might be able to find a replacement horn in the junkyard?
Thanks again everyone for your help! :-)
To check:
1 will have NEITHER
Old 03-25-2006, 04:02 PM   #7
andy_95sl2
andy_95sl2's Avatar
you can get one from the junkyard no prob, but you may have bought a non-working one so be careful!
here's a test light...
Old 03-25-2006, 05:22 PM   #8
2002SaturnMan
2002 SL1
Thank you. I'll look for one on my next time to Walmart or an auto parts store.
Old 04-01-2006, 09:04 AM   #9
2002SaturnMan
2002 SL1
Three questions,
Is there a link that I can see where the horn is located?
Will the "dead" wire just be hanging there?
Approximately how much $$ is a new/used horn?
Thank you!
Old 04-02-2006, 10:11 PM   #10
2002SaturnMan
2002 SL1
Thanks everyone. Especially Wolfman and XSaturn3X.
I found the test probe at Advanced Auto Parts for $2.48. Hooked it up like Wolfman said and found that the wiring is fine, but the horn must be DOA. Now I just need to buy the correct horn. They had some for $11.48, but they had 2 terminals.
When I search their website they have http://www.partsamerica.com/ProductD...pe=856&ptset=A this one for $36.99, but it doesn't say how many terminals it has.
Where can I find a 3 terminal horn?
Thank you!
Took IGN#1 Fuse out and now 1998 SL1 runs?!!! whitesg S-Series Tech 2 01-14-2009 08:12 PM
Remote door locks wont work JohnASmith S-Series Tech 8 12-19-2008 07:31 PM
sc2 alarm went off last night now remote wont work & car wont start kre8ive_kustomz S-Series Tech 1 03-27-2007 08:46 PM
why wont aftermarket horn work? irondiezl3 S-Series Tech 4 01-05-2007 03:04 PM
Cruise and Horn do not work on Steering wheel..need help dschwer S-Series General 5 03-03-2006 12:07 PM
