Old 03-03-2005, 01:18 PM   #1
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
Information Complete Overhaul Tool list
NECESSARY TOOLS:
- Metric rachet set 1/4" & 3/8" (6 point metric sockets)
- 1/2" torque wrench (ft lbs)
- 3/8"-drive torque wrench (in lbs)
- 3/8 torx bit set (from t10 to t50)
- Metric open end wrench set
- engine hoist (if doing out of car)
- engine stand (if doing out of car)
- piston ring compressor
- cylinder hone
- Metric tap & die set (craftsman part # 52348)
- 21mm for the crank bolt.
- Breaker bar for crank bolt
- measurement tools (caliper, Feeler gauges , plastigauge, etc)
- engine assembly grease (Lubriplate 105)
- vaseline (oil pump primer)
- Large rubber mallet for breaking free RTV gasket seals
- Torx E-7 external socket for the manifold studs
- oil seal puller
- RTV remover
- new oil (4 qts) and filter
- Anti-freeze (if you aren't re-using your old stuff)
- Permatex RTV (gray or ultra black)
- Blue Loctite threadlocker
- Anti-sieze paste
- PB Blaster to help free frozen/rusted fasteners
- Razor blades, gasket scrapers, and/or Scotch Brite pads to remove gasket material, rust, and deposits on gasket surfaces
- Utility knife to cut stubborn hoses
- Other basic tools, screwdrivers, pliers, crowbar, etc.
- Funnel for draining/filling liquids
- Ziplock sandwich bags, Sharpie pens, masking tape, and/or small parts bins for labeling & storing small parts & fasteners when removed
- LOTS of shop rags and/or shop towels!
- Simple Green pump spray bottles (or another similar brand) for degreasing parts
- Disposable plastic brushes for cleaning/degreasing parts
- Dielectric grease
- SEVERAL cans of carb cleaner
- Electrical connection cleaner for cleaning/degreasing sensor connectors
- Mini Mag light
- Parts pickup tools
- Bucket of CHEM DIP parts cleaner to soak the pistons and rods in overnight
- Rubber gloves
- Mechanix gloves to minimize bruised/cut fingers & hands
- Safety goggles, splash goggles
- Hose clamps (screw type)
- 4 ft 3/8" nylon rope (if you want to do the rope trick)
- 3/8" hose pieces to cover the rod bolts when removing
That just about does it. These parts can be found at your local auto store, sears, and wal-mart. That's where I picked up mine.
Thanks to everyone who helped me compile this list:
Razorbak, Mars_volta, sierrap615, saturner, sorry if I missed anyone.
-96 SC2 gets 35 mpg mix city/hw.
Add to sps SOHC's Reputation
Rate the quality of this post and help sps SOHC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sps SOHC is offline
Old 03-03-2005, 01:32 PM   #2
sps SOHC
sps SOHC's Avatar
Default Re: Complete Overhaul Tool list
Oh man I forgot the two most important things!
Confidence and Patience. If you don't believe you can do it then you probably can't, don't get discouraged. Be patient, it's a virtue.
AND STAY ORGANIZED!
Also you will need a friend to help you out at times.
sps SOHC is offline
Old 03-04-2005, 12:06 AM   #3
sierrap615
sierrap615's Avatar
let me also add:
the engine hoist will need a slider bar or slant bar.
30MM drive axle nut socket
drain pan, and some bottles to take the oil and coolent to be recycled
for the measurement tools include a mircometer and t-gauges
i beleave the torque wrench will need to read up to 159 ft-lb, an inch-pound torque wrench will also come in handy.
a cheater bar may be needed for the crank and axle nuts (basicly a thick pipe that will fit over your breaker bar.)
i personally would would also use some 1/2" sockets, but thats not necessary. a set of deep wells and rachet extentions also come in handy.
the cylinder hone should be 2.25" IIRC
a spark plug gap tester(please don't tell me you are reusing the old spark plugs on your new engine?)
a crank pulley puller may or may not be needed, as well as a strap wrench.
a wire cutter, if properly used, can help pull out any plastic retainers.
zipties
2 coat hangers or zipties for hanging brake claipers
a hex head socket will be needed for the oil rail, i'm not sure what size
a few more quarts of oil for lubing bolts, honing cylinders, ect...(dyno i'm told works better for rebuilds, wait a wait 3k or 6k miles before using synthetic)
more lights
a piston ring installer/cleaner (or instead, the rings can be installed by hand with the right method and the old piston rings can be used to clean the slots.)
propane torch to heat stubborn bolts
various sizes of wood boards
Hanyes, Chiltons, the Saturn FSM, and Saturnfan's how-to section will all come in handy too.
a camera to help remember wire routing and such.
safety items - first aid kit, fire extinguisher, ect...
sierrap615 is offline
Old 03-04-2005, 12:26 AM   #4
Razorbak
Razorbak's Avatar
3.5" diameter bottle brush hone
Add to Razorbak's Reputation
Razorbak is offline
tool size list 98SaturnSL1 Suggestion Box 1 08-16-2010 05:18 AM
Tool Wish List DevilDogMech S-Series Tech 4 03-03-2008 08:04 AM
Overhaul TOOL list...any additions? sps SOHC S-Series Tech 38 03-03-2005 12:39 PM
Engine overhaul parts list...anything else? sps SOHC S-Series Tech 75 02-23-2005 01:46 PM
complete powerwindow overhaul... petdmc S-Series Tech 8 02-09-2005 07:10 AM
