Old 11-12-2019, 02:12 PM   #1
I-4
I-4 will become famous soon enough
I-4's Avatar
Default Front subfame corrosion protection
Got a corrosion free front sub frame assembly from down south. My original lasted 25 years, the last 10 with oiling and fluid film sprayed inside. With it's seams, folds, joints, etc., what would you use to protect the subframe?
Just oil
POR 15
Rustoleum paint
Powder coat
Hot dip galvanized
Feel free to add any other method.
My thoughts, with POR 15 and Powder coat, corrosion can start under the top coat or at a seam, and not be detected for a period of time, while the corrosion has it's way with the steel. Hot dip galvanized would, at first look, be the way to go if you can find someone to do it, and at a price point.
I went with 4 coats of Rustoleum gloss black paint, with Nuxudol 700 cavity wax sprayed inside the box sections. Which is also the least expensive, and I did it at my own time and pace. So my question is, what would you choose and why?
No doubt, the subfame will now outlive me even if I did nothing.
Add to I-4's Reputation
Rate the quality of this post and help I-4 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
I-4 is offline   Reply With Quote
Old 11-12-2019, 04:32 PM   #2
hholbein
1997 SW2
Default Re: Front subfame corrosion protection
Buy a can of FluidFilm and give it a proper douching.
https://www.fluid-film.com/
Works quite well on keeping the crusties at bay, according to Salt Belt experts like Eric O. on the South Main Auto Channel!
Add to hholbein's Reputation
Old 11-12-2019, 09:02 PM   #3
Waiex191
Waiex191's Avatar
The oil filter does an amazing job of keeping the passenger side rust at bay. I put oil in the driver's side at my oil changes now.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-13-2019, 12:27 PM   #4
Claybury
Claybury will become famous soon enough
Claybury's Avatar
Waxoyl.
Either the brand name or the diy stuff.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Add to Claybury's Reputation
Rate the quality of this post and help Claybury reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Claybury is offline   Reply With Quote
corrosion in the other markets Jet Sky Astra General 28 06-05-2008 08:19 PM
Corrosion issue. hit_n_run S-Series General 4 06-18-2007 09:45 AM
Battery Corrosion? What is the Cause? Tiger S-Series Tech 10 11-10-2006 12:41 AM
Front end protection... WorldOfJohnboy Vue General 15 07-12-2005 09:31 AM
Corrosion Protection?? ION Ion General 10 04-27-2003 06:37 PM
