Old 10-29-2019, 04:21 PM   #1
mjollnir79
mjollnir79 is on a distinguished road
Default Would this be enough to keep the engine stable while replacing crossmember/subframe?
Using the 1 ton crane from HF. How much does the engine weigh? less than 1000lb right?
Add to mjollnir79's Reputation
Rate the quality of this post and help mjollnir79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjollnir79 is offline   Reply With Quote
Old 10-29-2019, 04:25 PM   #2
SC2Sick
1995 SW2
Default Re: Would this be enough to keep the engine stable while replacing crossmember/subfra
Aren't the legs of the crane under the car? Right where you need to be to perform the task?
sixthsphere.com owner
2002 Saturn SL2 - RHD
Add to SC2Sick's Reputation
Old 10-29-2019, 04:42 PM   #3
mjollnir79
Yeah, but we got it up plenty high. We're using larger 6 ton jack stands
Old 10-29-2019, 04:52 PM   #4
SC2Sick
1995 SW2
I've done several of these frame swaps. It really seems like the way you're trying to do it it'll be in your way.
Use some 2x4s if you don't want to buy the support bar
https://www.harborfreight.com/1000-l...bar-96524.html
Old 10-29-2019, 05:11 PM   #5
RobertGary1
Yea, way more than enough. However use your HarborFreight coupon for the support fixture. It straddles the upper frame (top of the fenders) and supports the engine.
-Robert
Old 10-29-2019, 06:58 PM   #6
mjollnir79
I didn't even know about the support bar. I plan on returning this thing anyway. It's missing the castors, and the support beams on the side seem messed up, oh and also missing the lock washers. Plus it's not long enough anyway. can't remove or do a engine swap with this/ As for it getting in the way two of us will be doing it.
Old 10-29-2019, 08:11 PM   #7
Waiex191
Waiex191's Avatar
A 2x4 and some rope would set you back about $5. Plus you could use them for something else after.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-30-2019, 09:46 AM   #8
mjollnir79
Yeah that was the first place, which I should have stuck with, until I found this thing.However the problem I ran into when trying to get the new subframe up was the middle nuts. Since the car is up in the front with larger 6 ton stands, I'm thinking the engine and everything is tilted making it impossible for everything to line up. Getting 2 more 6 ton stands and putting the whole car up should even everything out. This job is a pain in the rear.
Old 10-30-2019, 10:13 AM   #9
A 2x4 isn't stable enough. Need the 3.75" vertically for strength but then it flops over at the slightest touch. I only had pine 2x4's, the 1.75" vertically left the board far too floppy/droopy...even a pine 4x4 should be perfect.
Engine is around 220lbs (+/- 10lbs), trans is around 75lbs...well under 1/4 ton total weight.
Old 10-30-2019, 12:28 PM   #10
mjollnir79
What about my theory on bolts from the tranny not lining up to the subframe? Engine/tranny hanging out of place since not level?
We have 4x4 but so far it's hanging from the crane, as well as some wood and jack stand under the car while it sits until fFriday.
Old 10-30-2019, 12:36 PM   #11
SC2Sick
1995 SW2
What if you just removed the couple of other connectors and just pulled the whole engine out, lined up your frame, then dropped it back in? If you have a crane it should be simple
Old 10-30-2019, 12:55 PM   #12
If the top engine mount is in and it's just the transmission mount not lining up...that's a PITA to line up normally. Manhandle the engine/transmission around until it fits. You'll have to loosen the mount on the cradle so it has some wiggle to it.
Going with SC2Sicks's idea, there might be enough slack in the coolant hoses to just drop the engine onto the cradle/ground without undoing anything; once bolted to the cradle you can lift the entire assembly into place. I've not tried it that way, there could be other hang-ups like the transmission cables or something else.
Old 10-30-2019, 12:56 PM   #13
Waiex191
Waiex191's Avatar
I believe you are over thinking this. You will be able to muscle things around and get everything to line up.
Bryan Cotton
Old 10-30-2019, 01:38 PM   #14
mjollnir79
Yeah we'll give it another shot on Friday or Saturday. Hopefully I don't mess up my arm any more. Pulled a muscle or something, but not while doing this.
Old 10-30-2019, 11:53 PM   #15
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
I used the Harbor Freight support bar when I did mine a few months ago, it worked well. I pulled the fenders back though because I didn't want to chance the weight cracking them.
97 SL2, auto, 116K miles
Powered by Plastic
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-31-2019, 12:38 PM   #16
mjollnir79
Yeah, if I knew it existed I would have done this as well.
What do you think is a quick way to paint to protect it from future rust? It is 99% rust free now.
Old 10-31-2019, 03:02 PM   #17
Waiex191
Waiex191's Avatar
I oil the driver's side of mine when I do an oil change. The filter oils the passenger side.
Bryan Cotton
Old 10-31-2019, 03:28 PM   #18
trottida
trottida's Avatar
It doesn't get better than POR15 followed by something to protect the POR15 from UV (anything in a rattle can).
https://www.por15.com
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
trottida is online now   Reply With Quote
Old 10-31-2019, 09:52 PM   #19
Zeebins
Zeebins's Avatar
I used Rust Bullet on my new one. It's a rust inhibitor like POR15, but its also UV resistant. It seems to be holding up well so far
Powered by Plastic
Old 11-01-2019, 07:10 AM   #20
mjollnir79
Anything that I can spray on without the need to stand?
Will a 2001 DOHC S Series engine cradle/subframe fit my 2002 SL1 with a SOHC engine?? Doug427 S-Series General 3 11-29-2018 12:10 PM
Engine subframe replacement wi111y S-Series Tech 1 12-09-2013 09:05 AM
radiator mounting in replacing subframe ( '93 vs later years) NDtruck S-Series Tech 1 07-14-2010 09:40 PM
Replacing Front SUbFrame in 95' SL DevilDogMech S-Series Tech 8 08-14-2007 12:07 PM
Replacing An Engine Cradle Subframe? Matt42 S-Series Tech 10 02-05-2007 08:56 PM
